ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Oct 29, 2016 at 10:44 PM
    #661
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I did. I cantacted Marie because someone mentioned they got a better price whit her. I was price checking. I was referring to your comment on bundling.
    Bennett707 likes this.
  2. Oct 30, 2016 at 8:24 PM
    #662
    TaylorU
    TaylorU [OP] KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Haha not gonna delete the other vendors. I personally have only purchased directly through ADS in town and from Maria at Headstrong and I was so thrilled with my service from Headstrong, that I even wrote a vendor review here a couple of years back. I certainly would purchase from them again!
  3. Oct 31, 2016 at 9:49 AM
    #663
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much everyone for the nice comments and support! I really have the best customers!!
    Biscuits likes this.
  4. Oct 31, 2016 at 12:12 PM
    #664
    Lava rocks
    Lava rocks Well-Known Member
    Hilo,Hi.
    2000 Sr5 xcab 4x4 v6 auto
    HeadStrong Off-Road likes this.
  5. Oct 31, 2016 at 12:32 PM
    #665
    HeadStrong Off-Road
    Sure did. I actually have been working on it for a little bit. Had to check various shipping prices since you are in Hawaii. You should get the PM soon.
  6. Nov 1, 2016 at 1:33 PM
    #666
    Shortman5
    Supercharged TRD
    Called DSM about a spanner wrench for the c/o. they said you need a wall mounted spring compressor in order to adjust them otherwise you would damage them. does anyone have any experience with adjusting them yet?
  7. Nov 1, 2016 at 1:40 PM
    #667
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Mine adjust super easy on the truck with a pin punch.
  8. Nov 1, 2016 at 3:48 PM
    #668
    Shortman5
    Supercharged TRD
    How many inches of lift are you guys getting over stock (21") with these out of the box?
  9. Nov 1, 2016 at 6:03 PM
    #669
    Mtnflyer
    Mtnflyer I'm big in Japan
    Las Vegas
    I had mine ordered and installed locally to match my Deaver pack in the rear. I actually asked for a rake which gives me 2.5 in the front with 3 in the back. It's barely noticeable and will hopefully account for any settle in the leaf pack as well. I can always crank them up if I need.
  10. Nov 1, 2016 at 6:20 PM
    #670
    Shortman5
    Supercharged TRD
    Well what concerns me is that I was told by DSM that to adjust them you need to remove them and use a wall mount spring compressor to preload them or they can be damaged. Unlike my Toytec BOSS that I can easily adjust with the tires on. I like to sit 3 inches up front. I've adjusted my current setup 4-5 times to get the highet I want and account for driver lean.
    Anybody put more preload on them on the truck?
  11. Nov 2, 2016 at 2:35 PM
    #671
    Lava rocks
    Hilo,Hi.
    Wow that's no Bueno if u gotta remove and have a w/m compressor. Sounds like the same thing bout what was said bout the ARB/OME BP-51
  12. Nov 2, 2016 at 2:51 PM
    #672
    Squeaky Penguin
    Brett
    Yes. I jack it up, pull the tire, pull the uniball through bolt, and then they can be adjusted easily with a pin punch.
    I first tried without pulling the uniball through bolt, which works up unitll you get to the spot that's missing a hold due to the pinch bolt.
  13. Nov 2, 2016 at 5:16 PM
    #673
    TaylorU
    Taylor
    Flagstaff, Arizona
    I've never put more preload on, only took it off. But it should be the same exact thing, meaning you shouldn't need a compressor. At least that's what I've been told from everyone I've ever talked to. I've also told people to do it that way, and no one has told me it didn't work?
  14. Nov 5, 2016 at 2:26 PM
    #674
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    HELP NEEDED
    I'm trying to adjust my 2.5" coilovers and can't seem to get it to turn more than half a turn before damaging my spanner wrench or elongating the adjustment hole.
    I've loosed the collar and dropped the spindle from the UCA.
    What else am I missing?
  15. Nov 5, 2016 at 2:56 PM
    #675
    rmepilot
    Rob
    Huntsville, AL
    I appreciate the response.
    It makes no sense that these are not adjustable on the vehicle. By using spring compressors, I was able to get 3/4 turn, but no further.
  16. Nov 5, 2016 at 2:57 PM
    #676
    rmepilot
    Rob
    Huntsville, AL
    Uniball through bolt, at the bottom of the shock?
  17. Nov 5, 2016 at 3:05 PM
    #677
    Lava rocks
    Hilo,Hi.
    R the shocks new or have mileage already on them? I would spray the threads down with some type of lubricant like Teflon . I think he was referring to the spindle and uca bolt on ur last ?
    This is to rmepilot
  18. Nov 5, 2016 at 3:09 PM
    #678
    rmepilot
    Rob
    Huntsville, AL
    New
  19. Nov 5, 2016 at 3:10 PM
    #679
    rmepilot
    Rob
    Huntsville, AL
    Already dropped the spindle from the UCA
  20. Nov 5, 2016 at 3:18 PM
    #680
    Lava rocks
    Hilo,Hi.
    I don't know if the ceramic coating that is suppose to be coating the shock could be causing the threads to bind as I have no experience with these as of yet, but have been looking into purchasing a set . My experience are with icons and sway a way's and found that a bit of lube does help especially on the threads and where the springs contact the upper and lower spring perches , it allows them to slide .
