ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Sep 14, 2017 at 7:15 PM
    #1081
    dplank7
    dplank7 Well-Known Member
    Dan
    Tampa Bay
    2015 SR5
    ADS is the bees knees! Lol. Gotta get rid of mine though because I need an SUV, gettin a T4R
  2. Sep 14, 2017 at 7:20 PM
    #1082
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Nice!
  3. Sep 14, 2017 at 7:34 PM
    #1083
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    For sale?
    wheeliest and Nimble9 like this.
  4. Sep 15, 2017 at 7:16 PM
    #1084
    dwaltdtx
    dwaltdtx Well-Known Member
    David
    DFW, TX
    Are they brand new?
  5. Sep 15, 2017 at 7:23 PM
    #1085
    dplank7
    Dan
    Tampa Bay
    2015 SR5
    Only 2.5kish miles on them, so pretty close to it. Feel free to PM me
  6. Sep 28, 2017 at 7:08 AM
    #1086
    Dagostino480
    Dagostino480 Well-Known Member
    Colton
    2014 Tacoma TRD sport 4door
    Bad ass air freshener
    anyone rocking 285/70/17 on a 2.5 ads lift? Got pics?
  7. Sep 28, 2017 at 7:16 AM
    #1087
    dplank7
    Dan
    Tampa Bay
    2015 SR5
  8. Sep 28, 2017 at 7:36 AM
    #1088
    mopar2
    mopar2 Well-Known Member
    Franklin TN
    beers@1600 and Biscuits like this.
  9. Sep 28, 2017 at 3:13 PM
    #1089
    ahbot
    ahbot Active Member
    MGM 5th Gen 4Runner
    lots
    Any running the ADS that came from Kings or Icons? I'm looking to upgrading my set to ADS or Kings.
    17SandTaco likes this.
  10. Oct 4, 2017 at 4:12 PM
    #1090
    Fox2011PM
    Fox2011PM "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    I know this is a couple months old, but are you saying the slotted shims can be added without removing the center pin and installing a longer pin? I have installed Allpro Expos and had 3 degree shims in my old setup, and I need to add them to the Expos, but I thought I would need a longer center pin in order for it to "seat" in the axle leaf spring perch. So I ordered new shims and a new 4" replacement center pin. So I am looking at having to clamp the spring pack, remove the pin and install new pin and shims. But if I can avoid that and just "slide" a pair of slotted shims in without replacing the existing center pin, it would make my life a lot easier. Can you clarify this? Thanks Marie!
  11. Oct 4, 2017 at 4:53 PM
    #1091
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    So you would need the center pin head lengthener installed on the center pin in order to add in the shim. Some times the center pin provided with the leaf pack is long enough to accommodate the head lengthener and shim and sometimes it is not. If it is not then you would also need a new center pin as well. Some add the center pin head lengthener and longer center pin (if needed) prior to installing the new leaf pack on the truck. By doing this they can save themselves the added heartache of having to take the pack off of the truck in the future in order to add shims. IF this is not done prior to installation of the leaf pack then the new center pin head lengtheners and potentially new center pins would have to be installed prior to being able to use the shims. Which means the pack would have to be taken off the truck in order to add these parts. Again once these parts are installed you do not need to take the pack off of the truck in order to add, remove, or change out the slide in shims.
    G.T. likes this.
  12. Oct 4, 2017 at 5:03 PM
    #1092
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Thanks, that answers my questions. You're always helpful
  13. Oct 5, 2017 at 10:26 AM
    #1093
    HeadStrong Off-Road
  14. Oct 5, 2017 at 5:11 PM
    #1094
    Trdduluth7688
    Trdduluth7688 Well-Known Member
    Mario
    GA
    2017 Tacoma trd pro (white)
    None
    Marie is awesome. Extremely impressed. What a great company!
    ADS Extended 2. 5 Remote reservoir with compression adjuster coilovers (650lb spring) ADS 2. 5” Remote reservoir rear shocks with compression adjusters (standard travel) Camburg 1. 25" Uniball Upper Control Arm HS 3-leaf add-a-leaf
  15. Oct 5, 2017 at 5:32 PM
    #1095
    HeadStrong Off-Road
    That is very sweet of you. Thank you so much for this and for your business, we truly appreciate it!! :cheers:
  16. Oct 10, 2017 at 10:40 AM
    #1096
    baachou
    baachou Well-Known Member
    Glendale, CA
    2015 Taco Supreme
    Man, I was hell bent on getting Kings until I saw this thread. Now I don't know what I want. It sounds like, between Kings and ADS, it's sort of a "you can't go wrong" situation?
    rob1208 and TACOVRD like this.
  17. Oct 10, 2017 at 11:52 AM
    #1097
    Trdduluth7688
    Mario
    GA
    None
    It's all subjective. Get what your gut tells you and you're comfortable with!
  18. Oct 10, 2017 at 11:57 AM
    #1098
    baachou
    Glendale, CA
    2015 Taco Supreme
    "going with your gut" is problematic when you regularly suffer from analysis paralysis. Also I don't know too many other people with aftermarket shocks.
  19. Oct 10, 2017 at 3:02 PM
    #1099
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    you can't go wrong with either, pick your favorite color
  20. Oct 10, 2017 at 3:28 PM
    #1100
    Dagostino480
    Colton
    Anyone crank your ads up to 3"? does it affect ride quality?
