ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Jul 25, 2018 at 8:54 PM
    #1461
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I can’t speak from a 1st Gen perspective.
  2. Jul 25, 2018 at 9:35 PM
    #1462
    TacomaTravis208
    TacomaTravis208 Member
    2017 Blue Tacoma Turd 44
    -Softopper -OME 888 Coils w/ Bilstein 5100s -HS 3 Leaf AAL w/ Bilstein 5100s -255/85/16 Cooper Discoverer ST Maxx - 1.5" Wheel Spacers -Steel Braided Brake Lines -OME Carrier Bearing Drop Kit
    This is a question for the third gen guys. I just ordered the extended travel, 700# coil kit with Dakars. I would like close to 3 inches of lift. For anyone that is running around 3 inches of lift, what is your thread count on the driver and passenger side? Thanks!
    riz_atx likes this.
  3. Jul 25, 2018 at 10:27 PM
    #1463
    TacomaTravis208
    If you dont mind me asking, how many threads do have showing to achieve being leveled with your Dakars?
  4. Jul 25, 2018 at 11:49 PM
    #1464
    scleaf
    scleaf Well-Known Member
    Torrance, California. USA
    2013 Silver Tacoma TRD 4x4
    SaBellCo's Tailgate Lock :), Cable mod
    On my 2nd Gen I went with the Dakar HD pack but took out the third leaf to make it a medium pack. Not quite level but I want to add the rear and front bumpers to the setup.
    The ADS Clickers with 700's seem to ride super nice with 12 clicks on them on the road. I did add preload to the driver side as I had about 3/8 difference in ride height. Already have all the armor from front to rear.
    Though I cannot speak to the 1st Gen, I do not have any regrets and love the ride on and off road.
  5. Jul 26, 2018 at 10:01 AM
    #1465
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Depends on the model year and overall trim of the truck too.
    Basically it all comes down to how much the truck weights and how much more weight is being added. A 2001 2wd 4cy manual tranny weights a lot less then a 2018 4x4 v6 auto so if they are both adding around 200-250 lbs of up front weight the base truck is vastly different. That is where it gets confusing because people tend to overlook which trucks have what on it so each build can be unique in general.
  6. Jul 26, 2018 at 5:50 PM
    #1466
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Possible to get rear 2.125"s with a remote resi instead of piggy back?
  7. Jul 26, 2018 at 9:34 PM
    #1467
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Just placed my order today with @HeadStrong Off-Road for extended travel w/res and 600 lbs coils so we will see how it does! :D
  8. Jul 27, 2018 at 12:36 PM
    #1468
    scleaf
    Anyone with ADS adjustable resiviors and 700's care to share your adjustment settings for when you are flying through the desert or anywhere else off road?
    TACOVRD likes this.
  9. Jul 27, 2018 at 12:55 PM
    #1469
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    What do you have for weight up front?
    I need to replace 6112’s and trying to decide between 650 and 700 lb springs. I’ve got a plate bumper and plan on a winch.
  10. Jul 27, 2018 at 1:02 PM
    #1470
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    If we are flying, like over 35 MPH, then im usually at 15-max clicks of compression dampening. If we are rock crawling or going slow over technical terrain, im usually at about 10-12 clicks. Driving around on the street, i usually also run 5-10 clicks. Every once in a while ill put it at 0 clicks but not very often. I like taking speed bumps without slowing down at all so 10ish is a good spot for me.
  11. Jul 27, 2018 at 9:01 PM
    #1471
    scleaf
    What springs do you have?
  12. Jul 28, 2018 at 7:07 AM
    #1472
    riz_atx
    Sohail
    Spicewood Texas
    700#
    scleaf[QUOTED] likes this.
  13. Jul 29, 2018 at 3:29 PM
    #1473
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    wide open for daily use/slow bumpy stuff. all the way closed for high speed stupid stuff
  14. Aug 3, 2018 at 10:08 AM
    #1474
    HeadStrong Off-Road
    1 of 2 pallets of ADS shocks ready to be stocked. We know waiting sucks and so we always do what we can to stock product.
    Bertw192, DrFunker, presta24 and 14 others like this.
  15. Aug 3, 2018 at 12:06 PM
    #1475
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  16. Aug 3, 2018 at 12:07 PM
    #1476
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    :drool::drool::drool::drool::drool:
  17. Aug 3, 2018 at 1:03 PM
    #1477
    riz_atx
    Sohail
    Spicewood Texas
    The set I got has to be the best mod done to my truck to date! Cant beat that ride quality
    scleaf and desertrunner24 like this.
  18. Aug 3, 2018 at 1:10 PM
    #1478
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Mobtown armor I assume?
    Comatose and HeadStrong Off-Road like this.
  19. Aug 3, 2018 at 3:12 PM
    #1479
    slomoe
    slomoe Well-Known Member
    Stuart,Fl
    2011 Tacoma DCLB TRD Sport 4x4
    Wet Okole, Maxxis Razor (285x70x17), Bilstein 6112, RXT's Fn 5star
    BCFB76A7-0902-4C95-91E9-687837A8DB3B.jpg Got these couple wks ago. Thanks @Headstrong . Waiting for everything else to get here then the install will commence. YEEEWWWWW! I am Hoping the 650lb coils aren't to much for stock front end. Will see.
    Bot_Chu, Bridge4, riz_atx and 2 others like this.
  20. Aug 4, 2018 at 5:28 PM
    #1480
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Hopefully picking up a 1st Gen in the next couple of months and I plan on more ADS for that. Love my ADS setup on my 3rd Gen!
