ADS Off-Road Racing Shocks - Information, Pictures, & BS Thread
Discussion in 'Suspension' started by TaylorU, Aug 23, 2014.
  1. Oct 2, 2018 at 4:15 PM
    #1821
    Quadabaum
    Quadabaum Well-Known Member
    2017 Tacoma TRD OR 4x4 DCSB
    265/75R16 Falkens, ADS 2.5" Stage 3 Suspension, Go Fast Camper
    Thanks, I was going to get some wheelers superbumps but I wanted to flex it and figure out if I will need spacers or not.
    TACOVRD[QUOTED] likes this.
  2. Oct 2, 2018 at 4:52 PM
    #1822
    nartmot
    nartmot Well-Known Member
    Can you let us know what bump stops you go with and if they require spacers? I have the same shocks going on and I want to order everything up before I start.
  3. Oct 2, 2018 at 5:06 PM
    #1823
    Quadabaum
    It might be a month or so before I do that. I have some other stuff to order and we have a trip planned for 10/26.
    nartmot[QUOTED] likes this.
  4. Oct 2, 2018 at 6:19 PM
    #1824
    SpeySquatch
    2016 TRD OR DCSB
    Your trucks looks ideal and superb. I’m doing the fronts on Thursday. Looking forward to it.
    Hope to get 2.25” from my current 1.5” OME.
    Try DOT 4 brake fluid next time you change. It’s like $3 more per bottle and has a 100 degree higher boiling point than Dot 3... I have boiled my fluid with Dot 3.
    Quadabaum[QUOTED] likes this.
  5. Oct 3, 2018 at 9:56 AM
    #1825
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Try to adjust the hose so it doesnt kink like that...
    CR2014Sport and PNW Explorer like this.
  6. Oct 3, 2018 at 10:02 AM
    #1826
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
  7. Oct 3, 2018 at 10:06 AM
    #1827
    rayofsi
    rayofsi Well-Known Member
    4runner kits take a while.. when i ordered my 5th gen kit, it took a while..
    the front reservoir brackets... had to be cope-saw copied from icon brackets.
    dtaco06[QUOTED] likes this.
  8. Oct 3, 2018 at 11:52 AM
    #1828
    BankrupTaco
    BankrupTaco Well-Known Member
    2021 Tundra SR5 4x4
    Looking to get a lift from ADS. Wanting to raise 3". Any inputs, ideas, or how-to's on this? Pics if you got them too. Thanks :headbang:
  9. Oct 3, 2018 at 11:58 AM
    #1829
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Call Micah @Downsouth Motorsports he will take care of you
  10. Oct 3, 2018 at 12:53 PM
    #1830
    SpeySquatch
    2016 TRD OR DCSB
    3” on a third gen is doable, but will be the absolute max you want to compress those springs. Getting extended travel shocks with new UCAs will help
    BankrupTaco[QUOTED] likes this.
  11. Oct 3, 2018 at 5:05 PM
    #1831
    riz_atx
    riz_atx #bigpermtaco #teamBP
    Sohail
    Spicewood Texas
    ‘16 4x4 DCLB GFC Locked, Geared, Tuned
    C4Fab/RCI/BAMF, ADS, 4.88, Lockers, OVTune
    Even with extended travel shocks, the coil shouldn’t be less than 11”, ie 3” preload. That’s the max recommended by ads. The extended travel give one more inch of droop only. They all have 14” springs usually.
  12. Oct 3, 2018 at 5:09 PM
    #1832
    SpeySquatch
    2016 TRD OR DCSB
    Yes 14” with no preload or compression. You are correct I just measured mine
  13. Oct 3, 2018 at 6:47 PM
    #1833
    SpeySquatch
    2016 TRD OR DCSB
    Compressing the spring (preload) 1” is a 2” lift with ADS shocks
    ready6delta and BankrupTaco like this.
  14. Oct 3, 2018 at 7:08 PM
    #1834
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    That's generally how all shocks are, not just ADS. Lift is dictated by the spring, not the shock.
  15. Oct 3, 2018 at 7:09 PM
    #1835
    SpeySquatch
    2016 TRD OR DCSB
    Dang...was hoping we were special
    BankrupTaco likes this.
  16. Oct 3, 2018 at 7:10 PM
    #1836
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    We are, that shock body, internal and construction is top notch...
    dtaco06, slomoe and Quadabaum like this.
  17. Oct 3, 2018 at 7:12 PM
    #1837
    SpeySquatch
    2016 TRD OR DCSB
    ready6delta, Toyotico and Quadabaum like this.
  18. Oct 3, 2018 at 7:13 PM
    #1838
    SpeySquatch
    2016 TRD OR DCSB
    I read that ADS coilovers are progressive compression and digressive expansion.
    T or F?
  19. Oct 3, 2018 at 7:14 PM
    #1839
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    I know I owe you a picture of my truck but it has bird shit on it right now. Sorry!
    SpeySquatch[QUOTED] likes this.
  20. Oct 3, 2018 at 8:01 PM
    #1840
    Quadabaum
    This worked out dead nuts for me. I am at 1" preload driver, 7/8" passenger and have 2" lift up front. That is with no extra weight though, except for rtt on the bed and full tank of gas.
