Advantage and Disadvantage of UCA's (Brands)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ballon78, Feb 11, 2009.
  1. Feb 11, 2009 at 4:52 AM
    ballon78
    ballon78 [OP] Well-Known Member
    Amesbury, MA
    06 CC SR5 TRD
    Come to the conclusion that if i want my truck with 5100's and rear TSB to ever handle good again, with the bf mud terrains that i need UCA's even with the 1.75 lift.
    There are a handfull of companys out there, maybe people can right what they like about each and why.
    I'm leaning towards the Light Racing, only because of the sealed ball joint, i dont do any off roading, so i like the idea of a non open misalignment joint. My truck will never see crazy angles.
    Are there any other UCA's that have traditional ball joints, But still work and get alignment caster/ camber perfect after install?
  2. Feb 11, 2009 at 6:22 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    This is a good question. I'm interested to thoughts of those who have aftermarket UCAs as well.
  3. Feb 11, 2009 at 6:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The Light Raceing UCA has had issues in the past. They say they are fixed as of now. They are a stronger UCA than stock, but the Ball joint is not much different than factory.
    Camburg and Total Chaos are much stronger desigs than the LR. They use a Uniball and, though they are not "Sealed", I havent heard of any issues with it being a problem. The Camburg uses a harder material in their Uniball, and it can lead to becomeing noisey. I have had my TC Under water, and actually had some concrete harden on it, as well as exposed to mud, sand, etc. and it has been unafected. No noise, or unusual wear. With a Uniball UCA, changing the Uniball is as easy as removeing a "C" clip, and pressing the old one out, and pushing a new one in. the Uniballs are "Military Grade" so they are not going to be harmed by exposeure to the elements.
  4. Feb 15, 2009 at 8:43 AM
    Snyperx
    Snyperx Seniore Marcos
    Might want to add the All Pro UCAs to the list. They seem to have almost identical specs to the TC UCAs. and they are cheaper.
  5. Feb 21, 2009 at 3:59 AM
    Y0TA
    Y0TA Well-Known Member
    Zac
    Central MT
    05 BLK TRD Sport 4X4
    I would like to know some opinions on the all-pro's too. i know i have heard of them breaking with hard riding, but what about the around town mall cruiser. are the all-pro rebuildable too? i am not going to be doing much off-roading so what should be better, the Light Racing or the All Pro? Both have a price that catch my eye. ahhh...so many questions and so many different opinions, but i really dont know which one to go with. :help:
  6. Feb 21, 2009 at 5:59 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I havent heard of anyone running All Pro UCA's that didnt complain about them being noisey.
  7. Feb 21, 2009 at 6:33 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    i have the light racing just for that reason,dont wheel it or dont plan on it cause its my dd.i have a jeep to play in.like chris said they did have problems with them in the begining but they corrected that so im told.i liked the price as well and very functional to.good luck,i dont think you will go wrong for the lruca.later
  8. Feb 21, 2009 at 8:27 AM
    Snyperx
    How long have you had them? Do you like them so far? I am at a point where I am trying to determine what my next upgrade should be. My truck is also my DD, but I plan on doing some mild wheeling with it as well. Nothing to extreme. I would love to get the TC UCAs, but I keep thinking it might be overkill for what I truly need. Also they are close to $700 which is a big turn off for me. So I am trying to decide what matches my needs. I am really having a hard time making up my mind.:help:
  9. Feb 21, 2009 at 8:35 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well, how long are you gonna or planning on keeping your truck? If for a long time, Get the TC's. Worth the price of admition. ;)
  10. Feb 21, 2009 at 9:06 AM
    Snyperx
    I am hoping to have the truck for 200k miles. The thing is will the TC UCAs be a good match for the 5100's at 1.75" or are they not even needed? I have thought about taking them to 2.5" to level the truck out a little more.
  11. Feb 21, 2009 at 9:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The TC's will be fine for a 1.75 lift, and if you ever lift it to 2.5, your still covered.
  12. Feb 21, 2009 at 10:26 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I am running TC's on mine, kept the stock ones after the lift and ride was poor. Went to TC and WOW what a difference, no alignment issues again, plus I don't know about the other companies but TC has grease fittings.
    Well worth the funds in my book.
  13. Feb 21, 2009 at 11:58 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
  14. Feb 21, 2009 at 12:39 PM
    Snyperx
    Thanks Toku. The TC's seem to be the most popular. Would be nice to have more information on the LR UCAs as well as the All-Pro UCAs since they are close to what I would be willing to spend. $700 for the TC's that are basically going to give me a more precise alignment seems a bit crazy. Wish Wheeler's still had the TC's for $569.:(
  15. Feb 21, 2009 at 1:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Give wheelers a call. Im pretty sure that they will give you a discount.
  16. Feb 24, 2009 at 7:57 AM
    Snyperx
    I doubt they would discount the TC's from $669 to $569.
  17. Feb 24, 2009 at 5:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Never hurts to ask. Tell them Obama sent you. ;)
  18. Feb 24, 2009 at 5:26 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    since i lifted my CO's and all, I havent had any noise from my AP's. still havent found any tri flow to put on them yet either though
  19. Feb 24, 2009 at 5:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Useing PB blaster, you wont have any noise. BUT, It will alow dirt and crap to build in and around the uniball, eventually leading to its destruction.
