Advantage TorzaTop Review
Discussion in 'Product Reviews' started by NAYo2002, Apr 19, 2010.
  1. Feb 8, 2012 at 7:31 PM
    #61
    RandyL
    RandyL Active Member
    Yakima, WA
    2000 ExtraCab V6 5-speed
    Good info here, thanks to all for posting. I plan to go with either the TorzaTop or the Hard Hat. Other than the roughtly $300 price difference these days is there a weight difference between the two? Also, just how strong is the Hard Hat, could you walk on it for example?
  2. Feb 16, 2012 at 7:47 PM
    #62
    nelly.hartley
    nelly.hartley Member
    Lewis, Colorado
    1963 VW Crew Cab
    Thanks, this was helpful.
  3. Feb 17, 2012 at 4:05 AM
    #63
    penguins_cc
    penguins_cc Well-Known Member
    Will
    Bellevue, WA
    Timberland Mica Limo!
    Perkins Performance Sliders, Warn 9000, Brute Force Fab front & rear bumper, OME/Dakar lift, full ATO skids and hi-lift mount, satoshi, Wet Okoles, illuminated 4x4 switch, Diff Breather.
    You can't walk on it. I wouldn't even let my 30lb daughter sit on it. I would assume there is a weight difference between the two models. The material that makes the Hard Hat 'hard' is basically some wood (maybe 1/4 think? I don't know for sure). It's a good compromise between light weight but 'hard'. It's fairly easy to carry the Hard Hat by myself so I wouldn't think the difference is too much.
  4. Feb 21, 2012 at 4:29 PM
    #64
    Doc35
    Doc35 Well-Known Member
    Doc
    Virginia
    2012 DC MGM TRD Sport Prerunner
    Just got mine and installed it today, same thing. The two closest to the tailgate and the one on the right forward are parallel to the side, the one on the left locks at a 90 degree angle. I laid under there fiddling with it for a while and decided it worked so I left it alone. I find it odd though.
  5. Mar 1, 2012 at 3:46 PM
    #65
    Doc35
    Doc
    Virginia
    Email Advantage, apparently some covers we're sent out with the wrong latches, they'll send you the proper ones. No charge of course.
  6. Mar 2, 2012 at 9:25 AM
    #66
    dahumphries
    dahumphries Member
    Ric
    DC
    09 Tacoma TRD Off-Road
    Thank you...the cover works great, but it's more of an annoyance than anything else. I've emailed Advantage. I'll follow up with their response.
    v/r,
    Ric
  7. Mar 2, 2012 at 9:31 AM
    #67
    Doc35
    Doc
    Virginia
    They sent me two of the correct latches, they were stand up about it.
  8. Apr 5, 2012 at 4:06 PM
    #68
    Doc35
    Doc
    Virginia
    Follow up on the Advantage Torza Top, I received the top with incorrect front two latches. After contacting Advantage and explaining the problem they sent me two different latches. I spent considerable time attempting to change the latches with no luck. I worked with "Cori" at Advantage, once I experienced problems switching out the latches he/she no longer responded to my emails. I eventually asked for a refund of my purchase price or returning the cover for repair, I've yet to receive a response after several weeks. I'd recommend not purchasing this cover due to my experiences, purchase at your own risk.
  9. Feb 18, 2013 at 5:42 PM
    #69
    Lwolf777
    Lwolf777 Well-Known Member
    Pj
    Brooklyn
    Dbl cab. SR5, Barcelona red
    Hey guys just installed the primier cover, seems to not fit right. There is a small gap on middle of tail gate, and the rubber strip is longer on right side of the gate. Has anyone else have this problem? Thanks
  10. Mar 10, 2013 at 7:08 PM
    #70
    RonW
    RonW Member
    Ron
    Virginia
    Tacoma Dbl Cab . . . Black
    I've had the Advantage Torzatop on my Taco for about a month, and am happy with it. I opted for the premiere fabric . . . it's basically the same material as what is used to make convertible tops. It looks good and seems to be holding up well. I take it through a drive thru car wash at least once a week. Other than a few drops, no water gets in the bed. Easy to install, easy to remove. I'd purchase it again.
  11. Apr 12, 2013 at 10:09 PM
    #71
    lpfm1990
    lpfm1990 Well-Known Member
    Brian
    Newfane NY
    13 tundra dbl cab rock warrior
    trd duals
    after looking at this thread, i was about to buy a new one, but held off, ended up finding a used one on craigslist dirt cheap :D i have the 5 foot bed, and it mounted up easy, and it looks to have the same clamps as the op's but, i didnt have to remove the end stops, i have about 1-2 inchs before i even get to them?!?! but so far, im very happy with this cover, looks good, seems to be of good quality and all!
  12. Jan 16, 2014 at 5:51 PM
    #72
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    So this tonneau hooks into the rail with no brackets at all? I really don't want brackets in the rail system like so many other trifolds have
  13. Jan 16, 2014 at 8:36 PM
    #73
    penguins_cc
    Will
    Bellevue, WA
    Correct - it uses the existing rails with no additional hardware needed. When you remove the tonneau, no hardware remains. Even when the tonneau is installed, you can still use the rails with the OEM hardware.
  14. Jan 16, 2014 at 8:58 PM
    #74
    AR15xAR10
    Thank you VERY much. I'm pretty much sold!!!
    Thanks again!!
  15. Jan 21, 2014 at 5:34 AM
    #75
    dahumphries
    dahumphries Member
    Ric
    DC
    Realistically, you can install or remove in less than 2 min...super easy, no tools necessary.
  16. Feb 9, 2014 at 8:22 AM
    #76
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Long Term review......
    I've owned this Torza top for almost as long as I've owned my truck. I'd say, this top is probably close to 7 years old. It's been on the truck for the entire time. It's been parked outside the entire time. The top has been kept clean, I apply vinyl protectant on it.... And in the winters, I always brush the snow off (to keep the weight off it).
    As many of you know.... this winter has been brutal. This has been the worst winter for south eastern PA .....it's been brutally cold and we've had shit-tons of snow. Just last week, we had about 5" of snow and 1" of ice on top. It knocked trees /branches over and 55,000 people were without power (including myself). As usual, I cleaned off the truck and cleaned off the heavy snow/ice off the tonneau cover. Never noticed anything....
    Until, my husband noticed a hole in the vinyl just yesterday. We thought we may have poked a hole in it while hauling trash last week..... but upon closer inspection, the vinyl has become brital and the hole is more of a 'wear thru/crack thru;. I also saw a couple other faint holes were beginning.
    These holes were located near or above the cross beams. So perhaps, over the years of folding the vinyl in those spots (cross beams) along with the being exposed outside and especially....this frigid cold winter & ice storm..... my vinyl has given up.
    I'm bummed - as I absolutely LOVE this top.
    I'd love to buy a new one - but, we just signed an offer to buy a new house. Sooooo.....the priority goes to buying 'new house' kinda things. I'm very very curious to know if I can repair this somehow and get a few more years out of it
    (until I'm ready to buy a new truck ;) ) I'll be researching.
    Just thought I'd give some feedback. I'm sad..... :( My truck is getting old .... (like me).
  17. Feb 10, 2014 at 3:57 PM
    #77
    Pbtaco
    Pbtaco Member
    Contact advantage 10 year warranty on the vinyl tarp.
  18. Feb 10, 2014 at 3:58 PM
    #78
    AR15xAR10
    Thats what i thought. I'm seriously wanting one of these when i ditch the cap.
  19. Feb 10, 2014 at 3:58 PM
    #79
    Pistol Pete
    Pistol Pete Go Pokes!
    Eric
    Oklahoma
    2016 MGM DCSB OR 4x4
    Clazzio leather seat covers, CBI T3 front, SOS sliders, SCS Ray10s, 285/75/16 Duratracs, debadged, extra bed D-ring tiedowns, Advantage TorzaTop, OEM bed mat, custom center console organizer, Husky liners, remote start.
    That's what I thought as well.
  20. Feb 11, 2014 at 4:09 AM
    #80
    Janster
    Jandy
    Lancaster, PA
    Thanks!! I didn't know about the 10 year warranty!
    And here it is....
    http://www.advantagetruckaccessories.com/pdfs/AT_Warranty_May13_Page1.pdf
    I've saved just about every other receipt for everything I've ever bought for the truck - but wouldn't you know it? I can't find the receipt!! I had this installed locally, so here's praying they can vouch for me!
    I'm debating whether I should contact the shop directly or call Advantage first. I know one of the guys who works at the shop and we go thru him directly. He might be able to push the issue for me.... (better than I could).
    I'll let you know how things go!
