AdventureTaco - turbodb's build and adventures
Discussion in '1st Gen. Builds (1995-2004)' started by turbodb, Apr 4, 2017.
  1. Sep 15, 2020 at 3:57 PM
    #3261
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Mine's 2g and I pretty much feel like someone yelled "this guy wants A/C!" and someone sprinted to another line and grabbed what they could.
    The hard lines are bent at such an awkward angle, there's every chance they will bend.
    turbodb[OP] likes this.
  2. Sep 16, 2020 at 6:43 AM
    #3262
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    Well I don’t mess with auto A/C much- don’t need it up north, just enough to make the defrost work correctly. That said it does sound kinda like a slight over charge, like Zane says your operating pressure(hi side) is directly related to the ambient temperature. I would have to track down my factory manual (hope it’s not at the cabin) to decipher the color codes and what they mean. Factory pressures should be a good baseline. Download a R134A pressure/temp chart that will be useful. The basic rule of thumb is hi side should be at least 30F higher than ambient temperature it can be higher, but I would think that it shouldn’t be any more that 40-50 higher, a slight undercharge isn’t a bad thing.
    Auto a/c is a lot different in that the units have huge capacity- it’s a poorly insulated steel and glass box so sizing is all over the map.
    One question how long did you evacuate the unit-pull vacuum? I personally prefer to pull a long vacuum and do a decay test to see how dry it is. Usually a minimum of an hour, every little bit helps.
    The oil is hygroscopic, so it absorbs water. You use a vacuum pump to remove the moisture which will cause issues in the system, water will boil off in a 28” vacuum at 70F or so
    So dehydration is important. Never been a fan of dye but it probably works for auto.
    Mostly I work on commercial stuff, so refrigeration vs auto a/c is like peaches and nectarines, similar but different.
    Best of luck.
    turbodb[QUOTED][OP] likes this.
  3. Sep 16, 2020 at 7:18 AM
    #3263
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    #3 the lighting is so cool on that one
  4. Sep 16, 2020 at 8:16 AM
    #3264
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Thanks man, all good info. I pulled a vacuum with a vacuum pump operating for 40 minutes or so at 30", and then let the system sit for another hour to ensure no leaks. All seemed to check out. I too am leaning towards a slight overcharge, which is why I evacuated a bit - things seem a little better, so my hope now is that there isn't some intermittent leak somewhere (when things get bumped just the right way or something) that's going to leave me with another chase to find the culprit.
    Thanks for the vote! So interesting how people choose different ones!
    Arctic Taco[QUOTED] likes this.
  5. Sep 16, 2020 at 12:03 PM
    #3265
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    #2 is my favorite.
    #1 is a close second
    #3 I prefer the sun not on the truck so its more a part of the back ground and the Bright sun rise on the mountain pulls my focus like in pic #2.
    Really I have no eye for pictures and all of the ones you post look great to me.
  6. Sep 17, 2020 at 8:11 AM
    #3266
    turbodb
    Dan
    PNW
    AdventureTaco
    Replacing the PCV Valve
    One of the easiest - and often overlooked - maintenance jobs on a Tacoma or 4Runner is replacing the PCV valve. This is a one-way check valve that allows blow-by crank case combustion gases back into the engine to be combusted, rather than vented to the atmosphere (where they would cause pollution).
    As a check valve, the part is quite simple, but over time the spring in the check valve can wear out, and the grommet that holds the PCV Valve onto the engine can harden due to constant heat/cool cycles. With the parts costing only a few dollars, and the entire job taking less than 30 minutes, let's get started.
    First, pick up the following:
    And, you'll only need a few tools:
    • 10mm socket
    • A set of picks
    With everything in hand, get started by - if you have one - removing the air box on the intake hose by loosening the hose clamp with a 10mm socket.
    Once the air box is removed, you'll have great access to the PCV valve. Use a shop rag to clean around it and avoid getting crud in your engine, and then wiggle it out of the grommet.
    Follow the hose connected to the PCV valve and note where it re-enters the intake manifold. You won't actually be able to see the end of the hose, but it simply fits around a metal nipple, so once you find the end, pull straight down and the hose will release.
    The last piece to remove is the grommet. This is often the trickiest part, since the grommet may crumble as you start to remove it. Be careful, and use a set of picks to remove it from the top of the engine; retrieving any small bits that fall down as you do with a pair of needle nose pliers.
    Then, push in the new grommet!
    With the new grommet in place, first insert the end of the hose that enters the intake manifold by feeling for the metal nipple and sliding the hose over it. Again, you won't see this operation, but it's easy enough to do by feel.
    Finally, insert the PCV Valve into the end of the PCV hose, and then press the PCV Valve into the grommet.
    That's it! Replace the air box, and you're done.
  7. Sep 17, 2020 at 8:23 AM
    #3267
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    So your saying this should be done as preventative maintenance? Won’t the truck throw a code if it sticks?
  8. Sep 17, 2020 at 8:34 AM
    #3268
    turbodb
    Dan
    PNW
    AdventureTaco
    It's preventative in that if you wait to do it until the valve ages (and ultimately sticks to throw a code), then the grommet has also aged. An aged grommet is more likely to disintegrate - getting bits of hard, cracked rubber down into the engine - when you try to remove it. Rather, by replacing the two every 50K miles - and you might as well do the valve at the same time since it's cheap - you don't have to worry about getting that crap in your engine.
  9. Sep 17, 2020 at 8:35 AM
    #3269
    Dan8906
    Daniel
    Concord, California
    Gotcha, that makes sense. I’m sold on the idea!
  10. Sep 17, 2020 at 8:38 AM
    #3270
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Its failure can cause poor running conditions which make it worth replacing prior to failure.
    turbodb[OP] and Dan8906[QUOTED] like this.
  11. Sep 17, 2020 at 8:45 AM
    #3271
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Is that the standard interval? that seems too frequent.
  12. Sep 17, 2020 at 10:00 AM
    #3272
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Just an FYI for those looking to do this toyotapartsdeal.com has these cheaper by about 50% but shipping will probably take longer than Amazon. I'm looking at $37.64 shipped to the east coast. But thru my local dealership parts online I'm at $35 shipped
  13. Sep 17, 2020 at 2:30 PM
    #3273
    turbodb
    Dan
    PNW
    AdventureTaco
    Not sure; probably has a lot to do with conditions, etc. I figure for most folks, 50K miles is several years and so a good time to do it. Could you stretch it to 90K and do it with the Timing Belt? Probably...though the first time I did a timing belt was 18 years after having the truck, hahahaha. So ummm...
    Yeah, I link to the 'zon so that people can get stuff easily, but looking up at your Toyota dealer is always a good way to go if you can. :thumbsup:
    BYJOSHCOOK[QUOTED] likes this.
  14. Sep 21, 2020 at 9:12 AM
    #3274
    turbodb
    Dan
    PNW
    AdventureTaco
    Olympic-Sized Views to Obstruction Point
    Summer is a great time in the state of Washington. While much of the rest of the year might be dreary and gray, the long days and clear air between mid-July and September are nothing short of perfection for getting out to enjoy the mountainous terrain in the western part of the state.
    And this time, we were headed as far west as we could go - all the way to the Olympic Peninsula, for an epic hike along one of the highest ridges around.
    Keen to get the trip off to a good start, we made a quick stop at Family Donut - a new shop we'd recently found - for some of the best donuts I've ever eaten. It's a good thing too, because about 15 minutes later we were parked - the engine off - waiting for a ferry to take us across the Puget Sound.
    It turns out that someone the-opposite-of-smarter than me had made the decision to reduce the number of ferries running on the weekends in the middle of summer. We ended up waiting over three hours for our ferry to arrive.
    One can't complain too much on a ferry however - the views are always so nice as you glide across the water.
    Oh look, there are the other two ferries that run this route. Still operational on the less-crowded weekdays, it turns out. (What?!?)
    Hungry again, we made a quick stop for lunch before heading up Deer Park Road towards the campground and trailhead that we'd call home for the next couple of days. Already, things were looking up - literally - as the mountains we'd be exploring rose in the distance!
    Now, one of the reasons we'd made an early start was that the campground we were going to - Deer Park - is a no reservation location with only about 20 spots. With amazing views, it fills up quickly, even on a Sunday night. And, perhaps predictably as we pulled in just before 5:00pm, everything was full.
    Dang.
    Bummed, we pulled into an overflow parking spot and weighed our options: we could head back down the eight mile dirt road and find a wide spot in the road to set up (a dusty) camp; we could head home and try again some other time; or we could see if someone with a spot would let us share.
    A bit awkwardly, and with my face covered in a mask, I approached the folks staying in what is arguably the best spot in the campground. A quick look at their reservation ticket showed that they'd been there for a couple nights, and this was going to be their final night before heading home.
    Well, it turns out that Carol and Rick (of Edmonds, WA) couldn't have been nicer. After a brief chat, they were happy to let us park in front of their car and open up the tent on our 4Runner. They even invited us to join them around their camp fire (we didn't, since we didn't want to intrude), and to put a tag on the site marker reserving it beyond the end of the their stay!
    As @mini.turbodb scampered off to explore, @mrs.turbodb and I unfolded our chairs in the shade and pulled out our Kindles for a couple hours of relaxation, with a pretty nice view.
    If you find yourself reading a good book here, savor it.
    Having eaten a very late lunch just before heading up to camp, we all decided that dinner wasn't really necessary, and as the sun started to get lower on the horizon, we figured we should gain a little elevation to take it all in. The road behind camp wound up Blue Mountain - a perfect place to enjoy the display.
    This looks amazing. What you can't see are the gnats! Luckily, they were concentrated at this rock outcropping.
    With the sun below the horizon we made our way back to camp just as a heavy rain shower started! We'd checked the weather prior to the trip and there was no precipitation predicted, but hey, at least we hadn't deployed the tent yet!
    The rain didn't last long at all - perhaps 5 minutes - and in the end, it significantly reduced the dust, which was perfect. We just hung out in the 4Runner, @mini.turbodb already in her cozy little bed.
    With hugs goodnight, we climbed out of the truck to set up the CVT, and were immediately distracted by the main storm, a distant several miles to the north. Lightning - and plenty of it - illuminating the sky as the storm tracked eastward.
    The dozen or so other folks around us also noticed, and it was a bit humorous to see all of them packing up and talking in hushed tones about the safety of being "out in the open" when the storm was so far away. We chuckled as we unfolded the tent on the roof of the 4Runner and confidently climbed in, as other campers considered the "safest" place to go in these dangerous times.
    We knew, the safest place to go was "to sleep." :rofl:
    The Hike
    The next morning we were up bright and early - our alarm set for 5:50am, so we could pack up and roll out of camp by 6:15am. We did this as quietly as possible so as not to wake Carol and Rick, and we left a couple chairs and our kitchen box to hold camp while we completed our trek.
    The trailhead was less than a mile away, and after a quick breakfast, lunch making, and setting up of todo(link)the solar panel to keep the fridge running through the day, it was time to set off for Obstruction Point.
    This is no short hike. At a little over 15 miles round trip, it was going to be a trek for all of us, and I'd warned the small one about this several times in the preceding week.
    "I'm going to need you to do your best complaining," I told her. "I'll be sure to point out the most difficult sections as we come to them, so that you can strive for overachievement in those sections. Don't disappoint me!"
    Of course, we'd also promised amazing sights, and even as we started down through the forest, the morning moisture in the air made for great views.
    "Hey kiddo," I called as she ran ahead, "I just want to point out to you that this part is downhill now, but when we're all tired and ready to be done, this last section is going to be uphill and steep! I need you to whine as much as possible at that point, OK?"
    That got a good laugh.
    The first mile and a half of the trail makes its way along a forested ridge, and in the cool morning air we found plenty to keep ourselves entertained. A toad, hopping along, found its way from my hands to those of the child, squeals of joy escaping her lips as it sat for a moment before hopping off into the brush.
    A rock, embedded in a tree by an explorer before us, now claimed to be "thrown" into position by hers truly.
    And a rabbit - just the right size for a dinner and a half - clearly used to hikers that posed little threat as it continued to much away even as we were within a few feet.
    These are the things that keep a 10-year old entertained, any desire to complain or ask, "How much longer do we have?" forgotten for a moment in the excitement!
    As we reached the two-mile mark, we began to break out of the trees. There was still much "up" to go, but now it'd be with views that extended as far as the eye could see.
    At this point, the only way to tell the story of the hike is to continually repeat myself as to the splendiferousness of the views, and the grandeur of this special place. It was enough to keep us all going and entertained for another couple hours and several more miles, stopping now and again (and again, and again) for photos along the way.
    A beckoning trail.
    The Straight of Juan de Fuca, and Victoria, Canada.
    This world is a beautiful place.
    Winding along a ridge.
    Giantess.
    Perspective is everything.
    <p id="videoContainer1" class="full-width-container">https://www.youtube.com/embed/a2rQegdr3SM</p>
    As it neared 11:00am, and right around 4 hours and 5 miles of hiking, we decided it was time for lunch. We'd reached the apex of the trail at, and therefore the best views. With no one else in sight, we climbed to the top of the ridge, the wind strong enough to instill a bit of fear in the ladies as they looked over the edge.
    Up, up, up...
    ...and a long way down.
    Lunch was delicious. Turkey with avocado on sourdough, with a side of chips and plenty of water - we all counted ourselves lucky for the meal @mrs.turbodb had put together for us before we set out on the excursion!
    Our bellies full, it was my turn for a ridge-line shot. The trail - winding off into the distance along the ridge - the path we'd travelled, and would travel again on our way back to camp.
    Seriously man, just be normal for once.
    And with that, we headed back. Sure, we'd only made it five-and-change of the 7.6 miles to the end of the trail (which is itself another trailhead for the same excursion in the opposite direction), but we'd done it with almost no complaints from the kiddo.
    Pushing on the last couple miles, and the risk that would entail - well, as any parent knows - there was no righter decision than to turn around here. :rofl:
    With a few reminders to @mini.turbodb that I was, "Disappointed in the lack of whining so far," and expected her to, "Make up for it on the way back." we set off once again, most of the trail downhill for our return trip.
    It was late afternoon when we found ourselves back in camp. Through the day the solar system had kept the fridge cool (though, there was some drama in this regard, which I'll share in a later story) and we now found ourselves the sole, lucky, residents of the best camp site in Deer Park. @mrs.turbodb promptly laid down for a nap while @mini.turbodb and I read our books.
    Dinner of taco-rittos with loads of guacamole were ravenously eaten, and soon we were seated around the fire ring with marshmallows and chocolate. It was - to say the least - a great way to end what had been our most ambitious family hike to date!
    We Were Not Ready to Head Home
    Having woken up quite early on the previous morning, we had no reason to climb out of bed before 8:00am when we woke up the next day. Fog had rolled in to the valleys overnight, but there was no lack of sun up here in the heavens.
    A leisurely breakfast, and packing up of camp ensued. Even at that, it was probably only an hour or so before we were ready to go... except that we weren't. None of us - @mini.turbodb included - really wanted to leave this fantastically serene place, especially now that the campground had cleared out and we nearly had the place to ourselves.
    So, we decided that one more - short - hike was in order. We'd head up the same road behind camp that we'd witnessed the sunset from a couple days before, and hike to the top of Blue Mountain, taking in the 360° views one last time.
    Parking of the gods.
    The sun wasn't in the best position to capture much of what we saw, but it was as though we were surrounded by a fluffy comforter of puff. Tentacles of the stuff reached in amongst the fingers of the mountains, their high ridges and peaks towering majestically above the cover.
    Even taking the hike slow and savoring the views, it was still before 10:00am when we pointed ourselves downhill and headed for home. As what might be the last family outing of the summer - school is starting soon - it was definitely one of our most fun. And that bodes well for the memory of small children, and their desire to get out when spring turns to summer once again, and the opportunity to get out and camp presents itself!
    SuperBad, digdug1, SIZZLE and 15 others like this.
  15. Sep 21, 2020 at 9:22 AM
    #3275
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Nice to see not everything is on fire.:fingerscrossed:
  16. Sep 21, 2020 at 10:36 AM
    #3276
    turbodb
    Dan
    PNW
    AdventureTaco
    Yeah, no big fire over there this year. This was before the west coast was ablaze though :(
    Dan8906 likes this.
  17. Sep 21, 2020 at 4:28 PM
    #3277
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    Again. Thank you.
    This post really made my day. What an awesome trip!
  18. Sep 21, 2020 at 6:54 PM
    #3278
    Stxxx
    Stxxx Well-Known Member
    2009 Tacoma TRD
    Looks beautiful! I miss that area, gonna add this trip to the list.
  19. Sep 21, 2020 at 8:54 PM
    #3279
    turbodb
    Dan
    PNW
    AdventureTaco
    So glad you enjoyed - always nice to put a smile on a face! I too have days where reading someone's report gets me excited, or at least re-energizes me for whatever else I have to do that day that isn't exploring!
    It's a great hike, I highly recommend it. August is the perfect time, though if you find the right day in June, and there's still a bunch of snow (but it's warm), that can be magical.
    Arctic Taco likes this.
  20. Sep 24, 2020 at 11:24 AM
    #3280
    Arctic Taco
    Denali Park, Alaska
