AdventureTaco - turbodb's build and adventures
Discussion in '1st Gen. Builds (1995-2004)' started by turbodb, Apr 4, 2017.
  1. Jan 18, 2021 at 12:00 PM
    #3541
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    So I completely bled-flushed the clutch master and slave, and things are much better. The fluid in there was super dark too, so was nice to get that switched out. Actually, I was surprised how dark it was compared to my brake fluid, which generally stays pretty clear as far as I'm concerned. Will be interesting to monitor over time.
    Thanks all! @ian408 @CowboyTaco @rpowell25 @Blackdawg @Winkle99
    Dan8906, CowboyTaco, Winkle99 and 2 others like this.
  2. Jan 18, 2021 at 12:31 PM
    #3542
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    It’s hydrophobic meaning it absorbs water or moisture. It’s one of those things you’d flush on a time based schedule, not mileage. Every couple of years is about right.
  3. Jan 18, 2021 at 12:33 PM
    #3543
    turbodb
    Dan
    PNW
    AdventureTaco
    Yeah, I totally get that. My surprise is only in that the brake fluid (which hasn't been flushed in even more time) was much cleaner and hasn't seemed to absorb as much moisture.
  4. Jan 18, 2021 at 12:35 PM
    #3544
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    That’s weird. I’d flush them as well.
  5. Jan 18, 2021 at 3:22 PM
    #3545
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    really? Cause..didn't you bleed them when you did the tundra brakes? And the real axle bearings?
    Digiratus likes this.
  6. Jan 18, 2021 at 3:28 PM
    #3546
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That's what I was thinking too.
  7. Jan 18, 2021 at 4:37 PM
    #3547
    turbodb
    Dan
    PNW
    AdventureTaco
    Of course I bled them, but I never flushed, and never bled more than a couple tablespoons. The brake reservoir is a lot bigger too, and since I always use vacuum caps over the ends of the brake lines to prevent fluid loss, the volume I changed was small.
    Of course you were. :p
  8. Jan 18, 2021 at 5:31 PM
    #3548
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    ..i am no expert in anything, but i think 'hydrophobic' means hates water and therefore repels water molecules. hydrophilic would be water loving and therefore accepting of water molecule into the fluids molecular make up. maybe hygroscopic is the term here..for this fluid?
    Arctic Taco and turbodb[OP] like this.
  9. Jan 18, 2021 at 6:07 PM
    #3549
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Bit by auto correct. But you are right.
  10. Jan 18, 2021 at 6:53 PM
    #3550
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    My theory on the clutch fluid is that the stroke of the pedal (@ the master cylinder) and throwout lever (slave) is longer than travel in brake master cylinders and wheel cylinders/calipers, so there is more seal wear contributing to the dark color. But I've never actually looked at the dimensions to verify that. All I know, is that every hydraulic clutch vehicle I've owned seems to show dark clutch fluid sooner than the brake fluid.
    turbodb[OP] likes this.
  11. Jan 18, 2021 at 7:11 PM
    #3551
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    There's some wear and tear but the greatest change comes from temperature, moisture, and UV exposure. If you're running larger tires on stock brakes, chances are good you're seeing reduced life through heat.
  12. Jan 18, 2021 at 7:49 PM
    #3552
    Digiratus
    Roaming the PNW
    The RedHead
    :crazy:
  13. Jan 18, 2021 at 7:50 PM
    #3553
    turbodb
    Dan
    PNW
    AdventureTaco
    I'm quite confused. :confused: It seems you're picking on me?
  14. Jan 18, 2021 at 8:07 PM
    #3554
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I may know of the campsite you speak of or at least the general vicinity. I didn't experience any yellow jackets but I can understand why they'd be there with the way some campsites are left. I was fortunate to only have ants when I made camp there. Just keep things off the ground.
    Those are good people who have been adventuring around for many years. They have inspired many of my trips. Quite funny I discovered some source material online one time and asked him about it. He whimsically noted that the resource wasn't exact and that searching was still in order even when in the general area of any glyphs. He was quite surprised I was able to track it down. I've not met them in person but hope our paths cross one day. I messaged them some clues so it wouldn't be out on the net. I was recently in the general area of the "three boulders". With limited daylight on the winter solstice and another destination taking priority the boulders have to wait for another trip. They are quite far from socal. I need to return just to photograph the road signs in that region as they differ than similar ones I've seen closer to home.
    LOL glad your search proved to be fruitful. It's an amazing place and definitely worth the hunt. I have many more to find.
    Astounding report and photos. Apparently I didn't even scratch the surface on my one trip to the Funerals. Definitely need to do more hiking there. Hopefully no one wants that rusted wheelbarrow and it is still there when I seek it out. I'll try to recreate your photo.
    d.shaw and turbodb[QUOTED][OP] like this.
  15. Jan 18, 2021 at 9:25 PM
    #3555
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    It's easy to feel like that.
  16. Jan 18, 2021 at 9:42 PM
    #3556
    turbodb
    Dan
    PNW
    AdventureTaco
    As do I; more than you, I am sure. Which is why I'm heading back, again. My first return didn't go so well...
    ...though even after this mishap, we had a fantastic time looking around for something that turned out to be much smaller than I'd imagined.
    Thank you. I suspect that you'll find the wheelbarrow, hopefully in the same place. From my research, it's been there - almost without moving - for years. Removing it would take quite the effort - something you'll understand even more once you reach it! ;)
    ...for all of Death Valley.
  17. Jan 19, 2021 at 10:03 AM
    #3557
    turbodb
    Dan
    PNW
    AdventureTaco
    Into the Narrows - Loose Ends #2
    High up on a ridge in the Funeral Mountains, we'd gone to bed with a gentle breeze blowing through the tent. It'd been chilly, given the time of year and our 4800' elevation, but not too bad - until midnight anyway, when the wind picked up. With gusts up to 15mph, the 32ºF air meant that wool caps, burrowing, and earplugs were in order as the tent buffeted around us for the remainder of the night.
    The silver lining in it all, were the clouds that were blown in, and as I climbed out of the tent just after 6:00am, I hoped to catch some color in the sky as I donned all the warmest clothes I'd brought on the trip!
    While not the most dramatic sunrise I've ever seen, the pinks and purples always cast such an amazing glow on the landscape that they are surely an experience to savor. Rather than climb back into the tent - as has become a habit, especially when @mrs.turbodb is on a trip - I found a sheltered area below the ridgeline to simply enjoy the show.
    Forty minutes later, the sun crested the horizon and soon @mrs.turbodb was on her way down the ladder - cognizant of the limited daylight and knowing that we had another full day ahead of us.
    Our camp spot far up the middle fork of Echo Canyon had several things going for it: its position on the ridgeline, the associated views, and the fact that it was nestled at the end of an old mining road - mine shafts and ruins scattered over the landscape. All unprotected, it meant that we had to be careful walking around at night - but it also meant that we had plenty to explore as we enjoyed cereal and fresh berries for breakfast.
    An old headframe and several extremely deep, vertical mine shafts, lined our faint road.
    Our poking around took a bit longer than I think either of us thought it would, and it was 7:30am before we finally pulled out of camp - happy to be in the confines of the cab, where the heater could help take the bite off the still-breezy-and-cool morning air!
    We didn't have far to drive - less than a mile to be certain - before our first stop. When scouting this location in my pre-trip route planning, I'd noticed an extremely green patch of land nearby that could only mean one thing: copper mine. There's something about finding a bright green rock - the copper patina such a distinctive color - that's alluring, especially to @mrs.turbodb, and as we hiked the small summit to the waypoint I'd marked, it was clear that this spot was going to be a winner.
    We had no details on the mine that once worked this area, but the amount of copper ore here was - for us - jaw-dropping. Sure, it wouldn't hold a candle to larger copper mines, and it was surely smaller than the Copper World Mine we'd visited on our Mojave Redemption trip, but the greens were so vibrant - we just kept picking up piece after piece to show each other in glee.
    We also knew where we'd camp if we ever find ourselves in the area again as evening is approaching. The views aren't quite what we had further up the ridge, but how could we pass up a green fire ring?
    After gawking for several minutes in the early morning sun, we retreated from the summit - back to the Tacoma waiting below. Once there, we didn't have far to go - as retraced our path down Echo Canyon - before we reached the narrow dry fall that we'd encountered the evening before.
    No longer trying to find camp before dark, we had a few more moments to savor this interesting couple hundred feet of road, and I took full advantage.
    If you're a fan of Death Valley and have explored some of its more popular routes, you may be familiar with Steel Pass and the narrow falls in Dedeckera Canyon. The best way I can describe this hundred-foot-or-so section of Echo Canyon is the narrowness of Dedeckera, with about 2-3 times the height of the tallest fall there.
    Through the narrows, the remainder of the canyon was a walk in the park for a vehicle like the Tacoma, and we made good time - having already explored the Inyo Mine the previous evening. Naturally, we made a few stops here and there as captivating views presented themselves.
    This is not historic. Seriously people, show a bit of respect.
    The floor of Echo Canyon varies in width, with the upper canyon - both above and below the steep dry fall - being wider the thin rock layers packed one on top of the other before being mashed into various shapes by the geological pressures of time.
    The middle of the canyon tightens up - never narrower than 25 feet, but with walls towering above, it can feel narrower. This is the section where Eye of the Needle Arch decorates the center of the wash, a great place to climb up for a birds eye view of the dramatic surrounding.
    From the narrows, it's a slalom down the bottom of the wash and out the alluvial fan to CA-190 where we headed north just a couple of miles to Furnace Creek. Our stop there was short - just long enough to renew our annual America the Beautiful pass - before crossing the street to Texas Springs Campground - the jumping off point for our main attraction for the day.
    You see, our plan was to spend more than 50% of the daylight - some four hours or so - on what we hoped was an epic hike up the Funeral Canyon, deep into the Funeral Mountains. Promising a nearly 1-mile long slot canyon, climbable 7- to 20-foot dry falls, as well as badlands and hoodoos, we knew that this could be a special place.
    What we didn't know - as we set out up the alluvial fan - was that we'd have the entire thing to ourselves for the day!
    But, I'm getting slightly ahead of myself in my excitement to tell the story. Before heading out, I oriented the truck so the windshield was facing south, and setup the solar panel to keep the batteries topped off as the fridge worked to keep our food chilly. Even with the partly cloudy day, this worked a treat, generating over 200W of power in the time we were gone.
    While I did that, @mrs.turbodb prepped lunch - something I'd envisioned eating on our return, but that we decided, smartly, to take with us into the canyon.
    Only then did we set off up the alluvial fan, our pace quick in the well-worn burro trail - an 8+ mile round trip, with 1700' of elevation gain in front of us.
    It was about half a mile in that I realized I'd forgotten my Fitbit, and I jogged the round trip back to the truck to grab it - the thought of losing credit for those miles more than I could bear. :rofl:
    I caught back up to @mrs.turbodb as she reached the badlands - a little less than 1.5 miles up the alluvial fan. The East Coleman Hills, these yellow mudstones are draped with a veneer of dark-brown rubble, the remains of several tunnels that have been bored into their base still visible all these years later.
    We paused only briefly to take in the scenery around us before continuing on. Even with nearly two miles behind us, we still had more than a mile to go up the alluvial fan before we even reached the narrows that marked the beginning of the Funeral Canyon. Already though, we could tell that we were in for a treat.
    Even before reaching the narrows, sections of the wash began to rise up and sink down around us - the tall fanglomerate walls towering dozens of feet above our heads. The enormous amounts of water needed to form these structures is hard to fathom, especially in a place as parched as Death Valley.
    We are but specks in this vast landscape, as @mrs.turbodb sits on a small pile of rocks at the bottom of an overhanging dry fall.
    A little more than one hour and fifteen minutes into our trek, we'd covered the 3+ miles to the start of the narrows, and found a rock in the middle of the wash on which to eat our lunch. It was still just a little before noon, but we figured that much of the hard work was behind us now - no reason to keep our rumbling bellies waiting any longer.
    Even with a partly-cloudy day making for flatter-than-normal colors, it was still a brilliant canyon as we approached the narrows.
    Eager to see what lay ahead, our lunch was a quick one - the anticipation of the slot canyon a little further up the wash, more than we could bear to postpone. We headed into the narrows, dramatic walls with cavernous carvings drawing us forward around each subsequent turn.
    The walls at this point were primarily burnt orange in color, but a closer inspection showed them to be made of a kaleidoscope of rocks, each one embedded as though surrounded by cement.
    Through this part of the wash, water had carved its way through the fanglomerate, creating sweeping overhangs that would have kept us shaded even in fullest of sun.
    And then we entered a side canyon - our ultimate destination for this stroll. It was here that we'd experience the dramatic slot canyon, the grainy surfaces of the walls bristling with sharp, colorful stones. Not much grows in this section of the canyon, some places never receiving direct sunlight. Even on the brightest of days, I'm sure that this perpetually dim canyon - its towering walls hollowed by rushing water, chokestones wedged mere inches above our heads - creates wondrously unsettling spaces. It is a mysterious underworld that inspires respect and silence. With no advance warning of what lies ahead, the suspense is constantly kept alive.
    Not everything is easy-going in the slot. Expectedly, chokestones make passage more difficult, but there were only two spots where we really had to resort to climbing. The first was only a few dozen feet into the slot, where the aptly-named Tunnel Fall required a couple climbs of 10 feet or so in order to continue on.
    A class-4 climb through the tunnel only adds to the excitement.
    The second climb was a bit more difficult - perhaps 15 feet up a rather steep, slightly overhung fall that was more of a concern coming down than going up. But the reward for each of these was well worth it, as we continued up - and eventually out of - the slot canyon.
    At the top of the slot, the landscape changed dramatically. Here, above the last dry fall, the fanglomerate ended suddenly, revealing yellow, red, and green hills even more colorful than we'd seen in the lower canyon. What a treat!
    Soaking it all in, the canyon continued only another quarter mile or so before ending - for us - at a 60-foot tall wall known as Chimney Fall. I'm sure some make it past this point, but without ropes and a bit more experience, this was the end of the line for us!
    Sort of.
    We still had half the hike to go, simply in the opposite direction from which we'd come. And that's a great thing about slot canyons - the view in the opposite direction is always a new experience, the Funeral Slot Canyon being no exception!
    Eventually of course, we reached the mouth of the slot, and then the mouth of the narrows, before treking down the alluvial fan that had ushered us into this spectacularly private experience only just across the street from one of the most populous areas in the entire park! We made good time on the way down, stopping only to empty our shoes of pebbles and admire the views around us.
    We reached the Tacoma three-and-a-half hours after setting off, having kept up a reasonably good pace for the 8-mile journey, especially when factoring in the fact that we stopped for lunch along the way!
    Not that our pace hadn't taken a bit of a toll; we were both ready to get off our feet and spend a bit of time letting the truck do the work of moving us along - a good thing given that we had a 75 miles of pavement to cover on the way to a place I'd been wanting to visit for nearly three years.
    So, it was back onto CA-190, where we headed north and then west over Towne Pass into Panamint Valley. This section of road was familiar, having just travelled it - for the first time - only two weeks earlier on our way to the Nadeau Trail. But this time, we didn't stop in Panamint Valley at all - not even for fuel - instead, we continued west, winding our way up towards and past Father Crowley Point.
    It was here along CA-190 that we were treated to a fly-over of two F-16s, their engines roaring as they banked down into Panamint Valley. It was a bit of a surprise, really, given that Star Wars Canyon was just one ridge over, and is likely a more popular route!
    Even having gotten an early start on the day by exploring Echo Canyon the evening before, having made great time on our hike, and having travelled the speed limit on pavement for nearly 90 minutes, we found ourselves turning north on Saline Valley Road just after 3:45pm - a mere 45 minutes before the sun would drop below the horizon.
    And so, there would be no exploring Hunter Mountain or Hidden Valley today - we'd be lucky to reach our planned camp spot by dark. But that was fine by us - we'd enjoyed ourselves thoroughly, taking the time we needed to explore what was around us as it presented itself. Plus, we still had another day to immerse ourselves in this spot I'd been trying to get to for nearly three years.
    But hey, that's another story...
  18. Jan 19, 2021 at 10:13 AM
    #3558
    ETAV8R
    ETAV8R Out DERP'n
    Just the basics
    You found the stone waves. I knew you would. That's a neat, albeit easily accessible, place. The photo of your broken camera hurts my soul.
    turbodb[QUOTED][OP] likes this.
  19. Jan 19, 2021 at 10:15 AM
    #3559
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    Time to upgrade to a Sony mirror less system!
  20. Jan 19, 2021 at 10:24 AM
    #3560
    sawbladeduller
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    ..such an interesting trip. this was this past november? always amazed at your total milage on a trip like this.
