AdventureTaco - turbodb's build and adventures
Discussion in '1st Gen. Builds (1995-2004)' started by turbodb, Apr 4, 2017.
  1. Jan 1, 2018 at 6:49 PM
    #341
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    80,000 miles of adventure
    December 31, 2017
    Well, this happened yesterday. Definitely racking up the miles faster than I used to, but there are a lot of good miles to go!
    Dan8906 likes this.
  2. Jan 1, 2018 at 8:24 PM
    #342
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    How has your MPG changed?
    I am at 4.10 (I think) and 285/70/17 and 210-220 miles/tank.
  3. Jan 1, 2018 at 9:48 PM
    #343
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Jeez. Even I get 230-250 a tank with 255/80r17s on 4.10 and a damn auto.
  4. Jan 1, 2018 at 10:06 PM
    #344
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    I had the pizza cutters also and got the same 210-220 miles per tank...
  5. Jan 1, 2018 at 10:25 PM
    #345
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well lay off the skinny pedal :p
  6. Jan 1, 2018 at 10:56 PM
    #346
    turbodb
    Dan
    PNW
    AdventureTaco
    I was curious about this as well; I'm planning a post where I lay out MPGs over the life of the truck, because I realized about 2 weeks ago that I've been doing it wrong all this time and that my amazing gas mileage after the new gears was all pure malarky. Of course, all the mileage tracking I've done for the last 18 years was pure malarky as well. Except for 3 weeks when I had big tires and my 4.10 gears.
    Currently, with 4.88's and 255/85 R16s, I'm getting about 265 miles per tank, but my trip odometer says a bit over 300 miles.
    Yeah, so we're similar. I'm getting a bit better than you, but that's because I drive like an old fart, and you drive like you stole it. :luvya:
    Seems low to me. Lot's of other extra weight on the truck? Could be that you've got a bad fuel mix. I've heard that the MAF sensor, or maybe O2 sensors could be good things to clean/replace in that case. And make sure your air filter is good and clean.
    Or this. You might be driving like Monte.
    Blackdawg[QUOTED] likes this.
  7. Jan 2, 2018 at 12:17 PM
    #347
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    I just replaced my Bank 1 air/fuel sensor as it was throwing errors at the most inconvenient (Read as Moab between Fins -n- Things and Seven Mile Rim).
    When the CEL was lite, mileage was 150/tank.
  8. Jan 2, 2018 at 10:06 PM
    #348
    turbodb
    Dan
    PNW
    AdventureTaco
    Good news - rear locker still works. Even better news - I had the guys at JT's leave the front locker un-wired because I wanted to do that myself. Finally got around to doing it when I was visiting family in California last week, so now the front locker works too! Let's go on a trip. South.
    Thank you sir!
    :cheers:
  9. Jan 3, 2018 at 8:25 AM
    #349
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    How far south?
    :spy:
  10. Jan 3, 2018 at 9:34 AM
    #350
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Ha! South? Like Desert south?
    GHOST SHIP likes this.
  11. Jan 3, 2018 at 10:19 AM
    #351
    GHOST SHIP
    GHOST
    :spy::spy:
  12. Jan 3, 2018 at 12:57 PM
    #352
    Digiratus
    Roaming the PNW
    The RedHead
  13. Jan 3, 2018 at 1:36 PM
    #353
    gunny1005
    gunny1005 Well-Known Member
    Phoenix
    The 04945-35120 is the old part number, the 04945-0c030 is the new number, same part just different manufacture of the part.
  14. Jan 3, 2018 at 2:10 PM
    #354
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for the clarification.
  15. Jan 3, 2018 at 6:54 PM
    #355
    turbodb
    Dan
    PNW
    AdventureTaco
    Updating the Alcan Leaf Pack
    January 3, 2018
    When I got my Alcan leaf pack, I knew it was top quality. I really liked how the guys at Alcan asked what I wanted from the pack, as far as "every day" weight in the back, as well as "loaded" weight for adventures.
    So far, I've been really happy with how it has held the weight in the bed, provided a better ride than my OEM leafs (which were perpetually riding on the overloads and bump stops), and have given the truck back it's aggressive stance, even when loaded.
    Once I got bigger tires however, I got concerned that my wheels weren't centered in the wheel wells - they were further back than center. That didn't matter with stock tire sizes, but with 255/85R16's, I could tell that if the tire ever really stuffed, that I'd have some issues.
    So, over the last few months I've been flexing the back in various situations and then checking for clearance. I've never been able to get contact, but it's been close. I've also read up and talked to others who ran into the same situation - solving it via a center pin relocation plate or by getting the center pin moved forward ½-¾" on a custom leaf pack.
    And, it seems that there's no rhyme or reason to running into the issue - some trucks do, some don’t, even with the same leaf pack.
    I didn't really want to use a center pin relocation plate (the back end of my truck is already tall enough, and I don't love the drive shaft angle), so I talked with Alcan and they manufactured a new top+torque leaf for my pack that would shift the center pin forward ¾".
    Those showed up in mid-November, but of course, I had no time to install them, what with the holidays and whatnot. I'm a busy dude.
    With the holidays behind us however, I decided to make the swap today. It was a brisk 38°F out when I started, but sunny - not much more I could ask for! Before I got started, I snapped one last pic of the tire in the wheel well - definitely shifted back.
    Then, it was off with the wheel, and up onto the jack stands so I could remove the u-bolts and then ultimately the passenger leaf spring itself. My plan was to do the passenger side completely, then the driver side - that way, if I ran into trouble, I could always roll it into the garage for the night.
    The passenger leaf came out easily (probably just like the last time, but I knew what I was doing this time, so it seemed easier). When it did, I noticed that the perch for the leaf pack already had two holes in it! I wondered if I should just drill a third hole, ¾" forward of the center hole and use the existing leaf pack - but I decided against that, unsure if I'd be able to drill out the perch, or if the hole would be too close/encroach on the existing hole.
    I do still wonder what that rearward hole in the perch is for…it's too small for a center pin.
    So I proceeded to disassemble the leaf pack - an easy job with a couple of clamps - and then reassemble the pack with the new top and torque springs. While the curvature of the new leafs wasn’t exactly the same as the rest of the pack, I think that's just a matter of time - the weight on the truck will "mush" everything together.
    Then, it was back to the truck where I reinstalled the passenger leaf pack and ran into trouble. There was no way that I could pull the axle forward ¾" to align it with the center pin on the leaf pack - the u-bolts on the driver side kept the axle from moving that much. I could also tell that if I were able to rotate the axle, that the center pin wouldn't line up anyway - the radius created by pivoting the axle on the driver side would pull the perch too far toward the center of the truck.
    So I figured the only thing to do was to take off the driver side leaf pack as well. This presented me with a couple of "issues." First - I only had two jack stands, and they were supporting the frame of the truck. I was using the floor jack to support the rear diff and axle - fine when one side is fixed, but a bit "iffy" when both sides are free - 'cause that axle wants to tilt forward when it's not secured. Second, I wasn't sure how I'd move the axle forward if I wasn't pivoting it off of the other side - perhaps by pushing the floor jack a bit…but that too seemed iffy.
    Undeterred, I rigged up some ratchet straps, ropes, and a support block to keep the axle "in place" (or at least from rotating forward and falling to the ground) when I removed the driver side, and got out the high-lift to enable raising/lowing of the truck independent of the real axle.
    It all looked just a little bit sketchy to me, but - I figured - no sketchier than some of the trail repairs I've seen performed!
    Swapping the leaf's in the driver pack went just as smoothly as the passenger side and I got it mounted back up on the frame in short order. Then, it was time to attempt axle repositioning.
    To my surprise, I was able to simply push the floor jack forward the requisite amount and boom! Everything was aligned. Clearly, I've used all of my 2018 luck on day three of the year.
    With the center pins on both sides aligned, I was able to raise the floor jack to get the leaf packs fully seated on the perches, and then a bit higher to position the u-bolt plates correctly to install some u-bolts (and of course re-install the bump stops).
    With that, I torqued everything to spec (u-bolts: 97 ft-lbs; leaf pack front mount: 116 ft-lbs; leaf pack shackle mount: 67 ft-lbs) and reconnected the emergency brake before reinstalling the wheels.
    And then, I was done. And the tire is definitely more centered in the wheel well. Whether that makes a difference in the long run, I have no idea, but it makes me feel good. And I'm keeping the original top+torque leafs just in case.
  16. Jan 3, 2018 at 7:30 PM
    #356
    turbodb
    Dan
    PNW
    AdventureTaco
    I'd really like to get to Death Valley, but that's ~18 hours. Maybe doable in a 5-day trip, with 3 days of travel and 2 there. But I'm sure that's too far for @Digiratus (at least in 5 days) Maybe we won't have to go that far though (at least for a 5 day trip), if I can find something closer with reasonable weather - that's my research topic for the evening. Open to suggestions!
    Nice catch. When I got the shims, I got the -35120 part, and just copy/pasted the parts list for that thread to get a new quote. Didn't even notice that Gunny changed the part number there, but pretty cool that he did. Thanks again @gunny1005
    GHOST SHIP[QUOTED] likes this.
  17. Jan 3, 2018 at 8:18 PM
    #357
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    18 hrs is a two day drive man, 3 if you pee too much haha
  18. Jan 3, 2018 at 8:34 PM
    #358
    turbodb
    Dan
    PNW
    AdventureTaco
    I figure two days down because there's no point in doing it in one and then being totally dead the next day. And one day back because who cares if you're dead when we get back? :) So that's 3 days driving there/back, and 2 days there exploring.
    Speedytech7[QUOTED] likes this.
  19. Jan 3, 2018 at 8:49 PM
    #359
    Speedytech7
    It's worth the drive, I just finished uploading my pics to Flickr but haven't made any sort of story thread, probably just gonna dump pics. Ben made a story though in his trip log so you should check that out.
    turbodb[QUOTED][OP] likes this.
  20. Jan 5, 2018 at 9:22 AM
    #360
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    I don’t know if this was ever answered for you, just stumbled on your question after being linked over to this thread from a po there post. Check this out, it should work as a way to display data on the map without a second TNC.
    http://www.qsl.net/ja7ude/SmartPhone/w2aprs/indexe.html
