AdventureTaco - turbodb's build and adventures
Discussion in '1st Gen. Builds (1995-2004)' started by turbodb, Apr 4, 2017.
  1. Jan 17, 2018 at 6:59 AM
    #401
    cynicalrider
    cynicalrider #NFG
    Jersey
    It's most definitely the welds. Mine came from a heavy impact to the transmission skid in Moab too. Never ripped them out till then surprisingly enough. I never even seen it being an issue for anyone till it happened to me, then I saw everyone has the issue. :rofl:
    Dan8906 likes this.
  2. Jan 17, 2018 at 7:25 AM
    #402
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    hmm I feel like I should address this before it breaks. lol
    TacoBessy and Digiratus like this.
  3. Jan 17, 2018 at 2:00 PM
    #403
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I feel the same way. Now I'm wondering why they have never broken before.
    Maybe I'm not wheeling hard enough. :pout:
    Dan8906[QUOTED] likes this.
  4. Jan 17, 2018 at 2:03 PM
    #404
    Dan8906
    Daniel
    Concord, California
    OR, hear me out, we just pick better lines :fingerscrossed::rofl:
    Yetimetchkangmi likes this.
  5. Jan 17, 2018 at 2:05 PM
    #405
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If you believed that wholeheartedly you wouldn't have bought skids haha
    turbodb[OP] likes this.
  6. Jan 17, 2018 at 2:06 PM
    #406
    Digiratus
    Roaming the PNW
    The RedHead
    :D I like this idea!
    I'm still going to do a close inspection the next time the skids are off.
  7. Jan 17, 2018 at 2:06 PM
    #407
    Speedytech7
    Aren't they off for the winter still?
  8. Jan 17, 2018 at 2:09 PM
    #408
    Digiratus
    Roaming the PNW
    The RedHead
    The belly pan is off but the front one is on ATM. Will be coming off soon tho.
    Speedytech7[QUOTED] likes this.
  9. Jan 17, 2018 at 2:21 PM
    #409
    Dan8906
    Daniel
    Concord, California
    Sir you are right lol
    As will I, probably followed up with driving to my buddies to use the welder and throw a bead on it.
  10. Jan 22, 2018 at 5:18 PM
    #410
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Remember, aired down, I had about 4" of clearance on the De-Tour.
    Hahahaha! :rofl:
    In general, depending on how many attachment points your skids have, I think you can live without these points, so I'd only fix them if they break. These were definitely the "least important" points for my skid.
  11. Jan 24, 2018 at 10:02 PM
    #411
    turbodb
    Dan
    PNW
    AdventureTaco
    External Speaker for Ham Radio
    January 15, 2018.
    The Kenwood D710GA has been working well since it was installed. Transmission and reception seem good, the APRS has worked as expected, the display is nice (but not quite as nice as the Icom 5100A), and it's great having it securely mounted under the passenger seat.
    But the built-in speaker - that leaves something to be desired. With the Icom, I had no trouble hearing what contacts were saying, but even with the volume turned all the way up on the Kenwood, it's just slightly too quiet for me to parse what's being said.
    Luckily (and of course), there is an external speaker jack, so I figured I'd get a speaker and the problem would be solved. However, as I looked into speakers, I wasn't happy with any of them - they were all too big and bulky, and none of them had great "attachment mechanisms" (by which I mean they all wanted you to drill a couple holes in some part of your interior to install their mounting bracket).
    So I decided, why not build one myself? I could make the case out of some scrap maple, find a low profile speaker, and attach the whole thing to the driver side lower trim panel with some Velcro.
    So, that became the plan.
    I started with a 2" speaker that was only ¾" deep - an 8 Ohm HiWave BMR12. I hoped that its promise of full-range, would turn out to be close enough to true, and that it would be loud enough for my use.
    Next it was time to create a small box. Trying to keep weight and bulk down, the corners were the only real "interesting" part of this box - I needed something that would be strong despite the size, and so a box joint was the answer - lots of surface area for glue, and the joint itself would help keep the box square. I added a few corner blocks as well to accept screws that would hold the speaker in.
    The box made, it was time to drill for a grommet that would allow the speaker wire to pass through. This was done with a 3/8" forstner bit to recess the grommet, and then a 3/16" bit for the through-hole. Several minutes of pushing and prying later, and the grommet was installed.
    Next, I glued the back on. You can never have too many clamps when woodworking.
    Finally, it was time to finish the box with a couple coats of polyurethane and wire and install the speaker.
    As for installation - as I was looking around for a place to install, I realized that my seat covers provided the perfect answer. These covers also came with head rest covers that I didn't particually like when I installed them, but have since become invisible to me. Now, they'd provide the perfect location to stash the speaker!
    So, I pushed the speaker up into the back of the driver-side head rest and ran the wire down under the seat cover, under the center console, and directly to the Kenwood radio.
    I gave it a test, and it's loud. Perfect.
  12. Jan 24, 2018 at 10:26 PM
    #412
    Speedytech7
    Dig the little box for the speaker man, never been much good with the tree carcasses myself, metal let's me fuckup in a less destructive way haha. If you ever need a good source for little speaker odds and ends partsexpress.com is the best. I'm still trying to find a spot to mount my CB speaker, the usual places are too bothersome like above the head or a pillar. I refuse to put anything in front of the windshield and that makes it hard haha.
  13. Jan 24, 2018 at 10:28 PM
    #413
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Pffff..what is this? All the work and you didn't stain it??
    Im disappointed...
    :p
    Skyway and GHOST SHIP like this.
  14. Jan 24, 2018 at 10:44 PM
    #414
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    That's a lot of clamps :eek:
    That looks great though, and good idea mounting it behind the headrest!
    Crom likes this.
  15. Jan 24, 2018 at 10:56 PM
    #415
    turbodb
    Dan
    PNW
    AdventureTaco
    So strange - I think metal vs. wood are just what you're used to (or learned first?) For me, all my fuckups in metal feel so destructive. Wood, now that's more forgiving! hahahaha
    :luvya::luvya::luvya: Stain is for projects where something got messed up and don't want to see the wood and joinery. A clear coat, and then natural patina over time is the only stain for me...
    hahahaha, I may have added a few extra for the picture :anonymous:. I was pretty jazzed to notice the head rest myself. After using it for a few days, I think I may put it in the "side" of the passenger head rest, pointed towards driver.
    Skyway and 03 NIGHT TACO[QUOTED] like this.
  16. Jan 24, 2018 at 11:15 PM
    #416
    Blackdawg
    Monte
    Wyoming/St. Louis
    No way. You can save your ass in many ways with metal that you can't with wood.
    And fine then...wtf no clear coat!
    Skyway likes this.
  17. Jan 25, 2018 at 6:54 AM
    #417
    turbodb
    Dan
    PNW
    AdventureTaco
    Maybe one day I'll be as comfortable with metal as I am with wood, but for now at least, there's no way I could do some of the fine stuff with metal. Maybe I just need more tools! hahahaha!
    Oh, and I think you must have missed the part that said, "Finally, it was time to finish the box with a couple coats of polyurethane and wire and install the speaker." :p
  18. Jan 25, 2018 at 7:00 AM
    #418
    Blackdawg
    Monte
    Wyoming/St. Louis
    Tools always help. And practice haha
    Whoops...yes I did :anonymous:
  19. Jan 25, 2018 at 1:42 PM
    #419
    foy1der
    foy1der Well-Known Member
    W1FOY
    2017 OR DCLB
    I just installed a speaker for my v71a. I stuffed it up next to the overhead console. So far just sitting there with friction and the permanent magnet. I plan to find a better way to secure it, but damn it's cold outside.
  20. Jan 25, 2018 at 3:05 PM
    #420
    turbodb
    Dan
    PNW
    AdventureTaco
    Totally. 30 years of practice woodworking. Got a way to go with metal fab.
    Sometimes I wish I had that overhead console for a bunch of things...seems so convenient. But I like the simplicity of a first gen too.
