AdventureTaco - turbodb's build and adventures
Discussion in '1st Gen. Builds (1995-2004)' started by turbodb, Apr 4, 2017.
  1. Feb 22, 2018 at 8:39 PM
    #501
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You dont have as much rear lift.
    Well id just keep an eye and ear on it. CB drop would help the life of the the bearing.
  2. Feb 22, 2018 at 10:43 PM
    #502
    MountainN22
    MountainN22 Well-Known Member
    North East
    2000 Tacoma 3.4L SR5 Extracab 4x4
    Awesome! Just finished reading the whole thread.
    Build and adventure reports are really nicely done.
    Truck looks great.
    Subbed.
    turbodb[OP] likes this.
  3. Feb 26, 2018 at 9:59 AM
    #503
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Replacing the Speedo Gear
    February 21, 2018.
    How many miles do you have on your truck? If you're anything like me, you'll answer this by looking at your odometer, reading a number, and concluding that you have that many miles - 83,078 miles in my case.
    Like me, you're wrong.
    Your odometer is lying to you. And so is your speedometer. I covered why that is here - go read it. I'll wait. Speedometers, Odometers, and Gas Mileage – All Lies!
    OK, welcome back. Or not if you're like me and just skipped over that last link. Let me try to recap:
    All that means that I don't actually have 83,078 miles on my truck. I've actually got about 75,000 miles on it. Not that I'm planning to sell it any time soon ever. But as much as I want to hit the 500,000 mile club, I would rather that my odometer be correct - or at least as close as possible.
    To that end, I ordered the largest speedometer gear they make for a 2000 Toyota Tacoma - the 33-tooth model - to replace the 30-tooth model that was installed in the factory.
    It arrived, along with a new gasket and clip and I promptly set it aside while @mrs.turbodb and I drove several thousand miles down, through, and back from Death Valley.
    It was an epic trip. Don't miss reading about it here: Death Valley (Jan 2018).
    Now, several weeks later, it's time to install that gear, and hope that my speedometer reads slower than I'm actually going, and my odometer logs fewer miles than I've actually gone. You know, so the resale value of the truck is higher.
    The first step was to remove the skid plates, since the speedometer gear housing is attached to the transfer case, which is well-protected by the @RelentlessFab mid-skid. Six bolts and a floor jack, and I lowered the skid to find about 5 lbs of Montana, Wyoming, and a bit of Utah dirt that had hitched a ride back from The De-Tour (another epic adventure you shouldn't miss).
    The speedometer gear housing is secured to the transfer case with a single 10mm hex bolt, which was easily removed after I disconnected the plug for the sensor.
    With the bolt removed, the housing can be pulled out of the transfer case easily (if the o-ring hasn't degraded) and mine came out with a rewarding sucking sound, along with a few teaspoons of oil.
    Fingers crossed that losing a bit of oil isn't the end of the world here. At this point, pop out the spring clamp, and pull the old gear out of the housing. Again, you'll get a nice sucking sound as it comes out. It was rewarding enough that I did it a couple times .
    In order to fit more teeth (thus rotating more slowly to bring the mph and odometer readings down), the new 33-tooth gear has to have a larger diameter than the old 30-tooth gear - which it clearly does.
    As a bonus, it's also painted bright pink. And we all know, most ladies like pink. So if you install one of these, it's more reason for them to like your truck.
    The new gear slides right into the housing and is secured with the newly supplied clip. I also replaced the o-ring, though my original still seemed just fine, and was ready to re-install the housing assembly.
    Installation is simply the reverse of removal, and I found that the machining tolerances of the hole in the transfer case, and the speedometer gear housing were so close that it helped to wipe a bit of oil on the housing in order to get it to slide in (with a few gentle taps).
    I then re-attached the bolt ("tight") and plugged in the sensor.
    And then it was the moment of truth. Would my speedometer (and odometer) be accurate? There was only one way to find out - I started up the truck and headed out to I-5 to compare my GPS speed with my speedometer.
    Alas, it wasn't correct - but it was a lot closer. It now reads about 6% high (instead of 14%), which matches what the truck originally shipped with from the factory.
    So - at least on my truck, the following configurations result in nearly identical speedometer/odometer margins of error (~6%):
    And, other configs I've run:
    • ~0% error
      • 255/85 R16 BFG KM2 tires + 4.10 gear ratio + 30-tooth speedometer gear
    • ~14% error
      • 255/85 R16 BFG KM2 tires + 4.88 gear ratio + 30-tooth speedometer gear
      • 255/85 R16 Cooper ST Maxx tires + 4.88 gear ratio + 30-tooth speedometer gear
    So yeah, my odometer still lies, but I don't really care. Because it just makes the adventure "longer." :rofl::thumbsup:
  4. Feb 26, 2018 at 10:21 AM
    #504
    Krazyoakes
    Krazyoakes Well-Known Member
    Isaac
    Eugene, OR
    01 Tacoma 4x4
    Great Speedo-gear writeup, I’m going to do this when I get off work tonight!
  5. Feb 26, 2018 at 12:17 PM
    #505
    turbodb
    Dan
    PNW
    AdventureTaco
    Thanks! It's fun writing since I get to relive the doing!
    Well yes, in fact, irrelevant. But I still like my speedo to be right. Call me crazy. Oh, wait...you probably already do. :crazy:
    Nice! What are you switching from and to? I thought I was going from 31->33, ended up being 30->33. Not sure if that's because I had a MT vs. AT or what.
  6. Feb 26, 2018 at 12:42 PM
    #506
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Great write up! Do you happen to know the 30 tooth speedo gear part number? I have the 255/85 R16 BFG KM2 tires + 4.10 gear ratio and would like to have the speedo match the actual speed I am going. Thanks!
    turbodb[QUOTED][OP] likes this.
  7. Feb 26, 2018 at 1:01 PM
    #507
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Why not just use a Dakota Digital and have your speed match exactly to your GPS?
  8. Feb 26, 2018 at 1:14 PM
    #508
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    30 is the stock speedo gear. I used a 28 tooth to correct my speedometer for 33s and 4.10s.
    FWIW, I have 295/75/16s and a 33 tooth gear and my speedo is dead on per GPS. Surprised your still that far off with the 255s.
    Edit - and 4.88s
  9. Feb 26, 2018 at 1:29 PM
    #509
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Ah okay, I'm not super far off with the mph readings. Just about 4 mph off at higher speeds. Just enough to be annoying.
    MagicMexican likes this.
  10. Feb 26, 2018 at 1:36 PM
    #510
    turbodb
    Dan
    PNW
    AdventureTaco
    Seems like a reasonable plan! :thumbsup: I (sort of) wondered if I should stick with my stock gears when I saw the speedo was right on with the 255/85R16's. But then...gears are so nice. :D
    Here are the part numbers for all the combos. Also, keep in mind that MT/AT will have an affect as well so 30 may or may not be what you have/need. It'd be relatively easy to take the gear out, check out the number on it (or count the teeth), and then order the right gear to replace it. You want to move ~2 teeth for 4-5mph @ ~70mph.
    Automatic Transmission
    Manual Transmission
    As much as possible, I like to keep my electrical stock (at least, the stock part of my electrical, hahahahaha). Plus, the gear seemed really cheap and easy.
    Definitely interesting. I was right on - like dead on accurate with my 30-tooth and 255/85R16 KM2's and 4.10's. Of course the KM2's had ~25K on them...so not brand new.
    Delta00[QUOTED] likes this.
  11. Feb 27, 2018 at 12:07 AM
    #511
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What is your speed (indicated by the GPS) when your speedo reads 70 mph? Also, what are the RPMs for the same, in 5th gear?
  12. Feb 27, 2018 at 3:40 PM
    #512
    turbodb
    Dan
    PNW
    AdventureTaco
    The speed limit around here is 65, how am I supposed to get you these numbers? ;) :p Tomorrow, likely.
    99% sure I'm going to tell you the GPS speed is 66 mph when the speedo is at 70 mph; not sure about RPMs.
  13. Feb 27, 2018 at 3:52 PM
    #513
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    Why do I hear your post in my head in rain-man voice?
    DoorDing and DVexile like this.
  14. Feb 28, 2018 at 5:42 PM
    #514
    turbodb
    Dan
    PNW
    AdventureTaco
    OK, here are the numbers.
    Speedo @ 70 mph - GPS reads 66 mph, tachometer at ~2800 rpm
    Speedo @ 80 mph - GPS reads 76 mph, tachometer at ~3300 rpm
    Perhaps obviously, but I'll mention it anyway... obviously one/both of the numbers above are wrong, or more correctly - not completely accurate. That is to say, at 80 mph, there must be a larger difference between the speedo and GPS than at 70 mph. (since the ratio remains constant). So, it's likely that the GPS is rounding to the nearest MPH, and/or I am reading the speedo slightly incorrectly at a given speed.
    Net though - I'm somewhere about 6% higher on the speedo than reality.
  15. Feb 28, 2018 at 9:46 PM
    #515
    Digiratus
    Roaming the PNW
    The RedHead
    That is a little surprising. I would have thought ours would be more similar. We have a lot in common, 4.88s, 33 tooth with new 33's. I am not surprised your RPMs are higher (jealous) because of the overdrive ratios between the two transmissions is different. I wonder if your tires are just shorter/smaller circumference.
    FWIW, my speedo @ 70 mph - GPS reads 68 mph, tachometer @ 2500 rpm.
  16. Feb 28, 2018 at 11:04 PM
    #516
    Blackdawg
    Monte
    Wyoming/St. Louis
    the manual tranny is geared way lower.
    From my experience, the manual in 5th is about 400-500rpm higher at highway speed vs the manual.
    Arctic Taco likes this.
  17. Mar 1, 2018 at 6:46 AM
    #517
    cynicalrider
    cynicalrider #NFG
    Jersey
    Been subbed for a while, but wanted to thank you for this. Saw it in the detour thread and I think it' going to be an ideal location for me to relocate my winch solenoid.
  18. Mar 1, 2018 at 7:39 AM
    #518
    Blackdawg
    Monte
    Wyoming/St. Louis
    kinda makes for long cable runs for that..
  19. Mar 1, 2018 at 7:48 AM
    #519
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yeah that's also a concern. I won't know till I have the winch tonight but running out of ideas where I can stick it. Something tells me it won't fit on the winch, already needing to cut my grill a smidge for the winch housing.
  20. Mar 1, 2018 at 8:58 AM
    #520
    turbodb
    Dan
    PNW
    AdventureTaco
    Sure thing. For me, one of the few open spots up there under the hood. Really wish I had another spot too, for a future second battery.
    This is a great point. I know my winch came with 2ga wires between the solenoid and motor, and I was already worried about the load over the few feet of those cables. You'd want to run something like 1/0 or 2/0 welding cable if you were going to go as far as the firewall, I'd suppose. Not cheap.
