AdventureTaco - turbodb's build and adventures
Discussion in '1st Gen. Builds (1995-2004)' started by turbodb, Apr 4, 2017.
  1. Apr 2, 2018 at 12:25 PM
    #701
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Were they previously loctited or were you the first to do that?
  2. Apr 2, 2018 at 12:30 PM
    #702
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    They were not previously, but will be from here on out!
  3. Apr 2, 2018 at 12:32 PM
    #703
    Speedytech7
    Good call! I haven't touched mine since they were on the green truck and I used Blue Loctite then. Didn't have to take them out to put the spindles on the grey truck haha
  4. Apr 2, 2018 at 12:40 PM
    #704
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are they the originals from the factory.
  5. Apr 2, 2018 at 2:35 PM
    #705
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Glad that took care of it! And that is a nice looking u joint, way prettier than the Napa ones...
    I see what you did there...
  6. Apr 2, 2018 at 4:52 PM
    #706
    86scirocco16v
    86scirocco16v Mack of all trades
    Leavenworth, Washington
    '05 4.0 6sp overland
    Black this black that , 315-75r16 pro-comp A/T's , 285-75-r-16 treadwright gaurd dogs full OME lift with Dakar leaf spring pack, boss airbags, 4.88 nitro gears, dakota digital speedometer calibrator, tjm air locker, arb onboard air, spider tracks 1.25" wheel spacer, sport headlights, brute force fab hybrid front bumper, 6000k 4" led fog lights, 24" double row led reverse light, storm trooper shift knob, rebadged badg-less black mesh grill, Kenwood double din stereo, 400w Rockford 12” sub . Anytime fog lights. Oh yeah almost forgot the 2016 FourWheel camper fleet model for extra traction and a place to crash if you do get stuck or broke down. 2x160watt solar, mppt charge controller by blue sky energy. 3 deep cycle batteries 20gallons water, 6gal hot water, 3.5cf 2way fridge/freezer, 6gallon propane... just getting warmed up.
    I just recently had my differentials rebuilt with 4.88 gears and an air locker at JT's. Their service is on point and they have lots of stuff laying around to drool over... stoked to hear they are worth driving a shaky truck over the pass for as they are local for me.
    Digiratus likes this.
  7. Apr 2, 2018 at 9:59 PM
    #707
    turbodb
    Dan
    PNW
    AdventureTaco
    LBJs are the originals. So that's like 90% of 85K miles, given the 10% lie my odo and speedo have been averaging over the years.
    Totally, they are a great resource to have in our neck of the woods. I love showing up, and the fact that they let me watch them work, take pics, and joke around. Always cool projects going on there too!
  8. Apr 2, 2018 at 10:43 PM
    #708
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wow yeah you should go ahead and swap in new LBJ.
    Just do it.
    DoorDing and Digiratus like this.
  9. Apr 2, 2018 at 10:46 PM
    #709
    turbodb
    Dan
    PNW
    AdventureTaco
    When I got the u-joint, I also got two new LBJ's and a carrier bearing. My plan is to use them as spares for now, and swap them in next year when I also do timing belt and water pump and whatnot. Basically, try to get one more year of adventures out of the current ones; then, use them as trail spares.
  10. Apr 2, 2018 at 10:51 PM
    #710
    Blackdawg
    Monte
    Wyoming/St. Louis
    I...wouldn't chance it. Haha but that's just me.
    Given the state of your u joint...never know what the LBJ could be like.
    But hey..I am just skeptical about them..haha
    Its cheap insurance. And not a hard job to do. Seriously, you have the parts. Just do it now.
    DoorDing likes this.
  11. Apr 2, 2018 at 10:55 PM
    #711
    86scirocco16v
    I just installed a speedometer calibrator from Dakota digital to get my numbers right. It was super easy and cheap. I was off +18% with 315/75r16
    boostedka likes this.
  12. Apr 3, 2018 at 4:11 AM
    #712
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    Yeah I would much rather do it at home in the shop than struggling on the trail after it failed and I'm trying to get somewhere.
  13. Apr 3, 2018 at 7:59 AM
    #713
    turbodb
    Dan
    PNW
    AdventureTaco
    You're understandably biased, hahahaha! I looked for any type of play in them when I was down there and didn't see anything, and I'm not stressing them like you do on Frank with 35's.
    At least, that's my hope.
    In general, how many miles do you guys all put on a LBJ? And what percentage road/dirt?
  14. Apr 3, 2018 at 8:17 AM
    #714
    Blackdawg
    Monte
    Wyoming/St. Louis
    Mine let out at around 110k-115kish. I didn't own the truck until 96k but it was a safe bet it had seen a lot of dirt in its first life as a hunt truck and irrigation truck.
    For me, I don't expect to get any more than 30-50k out of a set these days from Frank. Obviously most of that is dirt miles. Igor I'll trade out every 70-90k, or hope too.
    Brett only got 3 wheeling seasons out of his last set before noticing play to put it in perspective. He has had some really high mileage dirt seasons though.
    I like to say for most normal folks to change them when you do a timing belt, which is every 90k. Better safe than sorry.
    Considering you have been putting more stress on the truck in the last few years. Id just swap them out. You already have the parts and it'll take maybe 2 hours to do. Use the old ones as your trail spares, not the news ones haha
    Because from my experience, if it fails and your at any sort of speed other than idling in 1st gear. You're gonna take the whole steering rack with you, the CV axle, brake line and god knows what else. Not a trail fix situation.
    DoorDing and BYJOSHCOOK like this.
  15. Apr 3, 2018 at 8:48 AM
    #715
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Good luck. You should at least check them.
    Like Monte said, I got three wheeling seasons out of mine last set of OEM LBJs, and haven't DD'd my truck for the last two. Just over 30k miles. I put a pry bar between the LCA and the ball joint, and the play was immediately obvious. One side had more than the other, guessing about 1/8". They probably wouldn't have made it through this season without failing.
    Blackdawg likes this.
  16. Apr 3, 2018 at 9:02 AM
    #716
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yeah im not talking bolt failing FWIW. Im talking the actual joint exploding.
  17. Apr 3, 2018 at 11:24 AM
    #717
    Digiratus
    Roaming the PNW
    The RedHead
    80K on a payment princes it is probably too soon. Wait for 90K.
    Now if you were actually doing challenging trails like say the trek out to the doll house and such or were planning more challening stuff like the Naches trail perhaps or even HITR, then it may not be wise to wait. :)
    I am not particularly biased, scarred maybe, but not biased.
    90K seems about right as a bare minimum, but not for what I do. I have 45K on the set I have now. I too am hoping to survive this upcoming season. Then a new set will go on next winter. My guess is the mileage by then will be ~55K.
  18. Apr 3, 2018 at 11:52 AM
    #718
    Speedytech7
    I just look at it cost wise, if there's any play at all I'm replacing them both, It's ~$200 and that's a whole hell of a lot cheaper and less of a pain in the ass than changing the rack, brake lines, UBJ, and possible wheel and frame damage. Mine have two seasons on them and I'm hoping they don't develop play in the third, but if they do then it's off to the trail spare bucket.
    I should say that 3/4 of this pair of joints' life has been dirt and second vehicle abuse scenarios.
  19. Apr 3, 2018 at 11:59 AM
    #719
    turbodb
    Dan
    PNW
    AdventureTaco
  20. Apr 3, 2018 at 12:01 PM
    #720
    adt7108
    adt7108 Well-Known Member
    Cookeville, TN
    Sweet - looks good!
