AdventureTaco - turbodb's build and adventures
Discussion in '1st Gen. Builds (1995-2004)' started by turbodb, Apr 4, 2017.
  1. Nov 20, 2018 at 3:24 PM
    #1181
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Sounds like I should start gathering parts.
    m3bassman likes this.
  2. Nov 21, 2018 at 7:16 PM
    #1182
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Can't hurt. Better safe than sorry
    Dan8906[QUOTED] likes this.
  3. Nov 22, 2018 at 2:59 PM
    #1183
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    Good trip man, been reading along when the kids allow it. I hope you got the cutter pin keeper in that LBJ after the picture.
    I think @Blackdawg nailed it I have been shooting for every 75k for major parts like that.
    turbodb[OP] likes this.
  4. Nov 22, 2018 at 9:00 PM
    #1184
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    If you're hard on them every oil change or after/before every trip. I'm seeing play in mine after less than 10k with oem ones.
    Squeaky Penguin and turbodb[OP] like this.
  5. Nov 22, 2018 at 9:02 PM
    #1185
    Reh5108
    Idaho
    BTW Dan, as always great reports! If I had a steering rack I'd be tempted to head to Utah this weekend. I'm getting an itch to visit the desert.
  6. Nov 22, 2018 at 9:30 PM
    #1186
    turbodb
    turbodb [OP] AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Thanks - I know they're long and can take a bit of time to read. Totally get working that around the kiddos! And yeah, the cotter pin got in there for sure! :thumbsup:
    Wow, 10K seems low. That'd be 3-4 new joints/year for me now. Pricey!
    Thanks, and I hear ya! I've got a couple more trips to post as well, but definitely getting the itch again. And for something warmer - so south it'll be!
    Reh5108[QUOTED] likes this.
  7. Nov 22, 2018 at 9:48 PM
    #1187
    Adude
    Pnw
    04 Double cab
    Good to see not letting that castle but back off. Being as a daily driver and strict about mechanical operations more then looks on a anything with a motor. I tend to go over all that stuff with every 2 month oil change. Putting it off always left me in a bad situation, I can still walk 10 miles to service. I will not put my kids in that situation, or leave them in the car and have something happen to me.
    Now I know why my dad did things the way he did.
  8. Nov 22, 2018 at 9:56 PM
    #1188
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just go to ACE, they'll have paint pens right near the welding supplies. Might I suggest bright yellow or red
    Adude and turbodb[OP] like this.
  9. Nov 22, 2018 at 10:38 PM
    #1189
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I found the one I use in the paint section of the local hardware store
  10. Nov 23, 2018 at 2:48 AM
    #1190
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not gonna matter once you're on a trip and they get dirty
  11. Nov 23, 2018 at 4:09 AM
    #1191
    Reh5108
    Idaho
    I think it's simply how hard I beat on the truck. I wouldn't be surprised if things in the front are bent but not enough to cause the lbj to bind.
    @Squeaky Penguin what did you get out of your last set?
  12. Nov 23, 2018 at 5:28 AM
    #1192
    Blackdawg
    Monte
    Wyoming/St. Louis
    This is why I'm going heims. Figure I beat on it hard enough and they should last as long but be stronger anyways.
  13. Nov 23, 2018 at 6:41 AM
    #1193
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Under 30k and they had quite a bit of play. Should have replaced them sooner.
    Current set has 11k on them and just a tiny bit of vertical play.
    We're not easy on our trucks. :D
    turbodb[OP] and m3bassman like this.
  14. Nov 23, 2018 at 8:57 AM
    #1194
    turbodb
    Dan
    PNW
    AdventureTaco
    I need to get one of these too. Been doing the same as @m3bassman which is a pain. Bright yellow for me, I think. Will be nice for marking when welding too! :thumbsup:
    :rofl: You're just :stirthepot::stirthepot::stirthepot:.
    Yikes. I sure hope I'm not ending up in the same situation as you guys - that'll be a lot of LBJs to purchase over a short period of time.
    Now that I have these on, and figured I'd be doing them every ~1-2 years or so, I was considering buying another set just b/c they are on sale with BF.
    Conicelli Toyota has them right now for $111.65 each with bolts (Left | Right). With their 10% off Black Friday coupon (BF10), that's $200+shipping, so $215 for me, which is about $20 cheaper than Camelback.
    jubei and m3bassman like this.
  15. Nov 23, 2018 at 10:32 AM
    #1195
    Squeaky Penguin
    Brett
    Ryan and I drive rather spiritedly offroad.
    Driving fast is what is so hard on them. Full bump to full extension dozens and dozens of time a day.
    Driving slower would certainly be easier on everything, but where's the fun in that?
  16. Nov 23, 2018 at 11:27 AM
    #1196
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Knowing both of you guys and having wheeled with you, this made me LOL.
  17. Nov 23, 2018 at 11:34 AM
    #1197
    turbodb
    Dan
    PNW
    AdventureTaco
    Hahaha.
    I definitely fancy myself a slow driver - though I've only got Monte, Mike, Ben, Zane, and @drr to compare myself to. And Mike keeps saying that I'm going faster every day. Probably true since the trip @mrs.turbodb and I took a couple weeks ago, she was yelping and holding onto the oh shit handle, and I was like, "what's wrong?" :rofl:
    Still, slower than the rest of the gang is all good with me, but it'd be fun to get out with you guys as well so I can compare speeds. Too bad we weren't able to meet up on the last trip for a couple days - would have been great!
    Adude likes this.
  18. Nov 23, 2018 at 11:41 AM
    #1198
    Speedytech7
    You'll get there, gonna make some great leaps here in a few days! I'll be the slow one soon enough in my 2ton Toyota tank as I get it all figured out for this kinda stuff again.
    turbodb[QUOTED][OP] likes this.
  19. Nov 23, 2018 at 11:48 AM
    #1199
    Squeaky Penguin
    Brett
    I was questioning your guys' pace as Monte was texting. :rofl: But I'm sure we're all meet up for a trip at some point here. :cheers:
    We left our camp somewhere on the smokey mountain road not far from where Left Hand Collet joints, out and backed Grand Bench, and made it to Alstrom with plenty of time to watch the sunset in one day.
  20. Nov 23, 2018 at 12:04 PM
    #1200
    turbodb
    Dan
    PNW
    AdventureTaco
    But but but, I don't want to get there. I like slower. Take in the sights, enjoy! Oh, who am I kidding - I know that if I'm to continue these trips, the speed will only pick up. hahahahaha
    Yeah, with the conditions we had, there's no way we were going to do that. But probably similar in good conditions. Oh man, I can't wait to post that part of the story. Was an interesting 24 hours. ;)
