advice and opinions needed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ope23, Apr 13, 2010.
  1. Apr 13, 2010 at 8:55 AM
    ope23
    ope23 [OP] Active Member
    andy
    Jasper,GA
    03 SR5 4X4
    window tint all the way around even the front windshield
    Ok so.... I tried to resolder the temp/compass 510 for my friends Yo that i'm working on.. But, the 510 is gone!! Dealer wants us to buy the whole piece and i'm determined to save with another resistor.. I have searched through every thread I could find and the soldering is easy it's finding the resistor at this point..
    Another think I was curious about is if anyone else has experienced the fan/temp control lights are blow as soon as I install them... At 7.00 a pop I was curious if there was something someone else has frequently seen...
  2. Apr 13, 2010 at 9:20 AM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | Access Roll-up Tonneau Cover, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat ---------------------------- | INTERIOR | Flyzeye V2W (Amber/White/Amber) Audio: Alpine CDA-117, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    For the temp/compass 510 resister just use one as close to 510 as you can get. Just read on this forum that another poster broke his and went to Radio Shack and bought a pack of 470 ohm resisters and it worked for him... I'd link you to it but I can't find the post... it's on here somewhere? You won't get the chip resister but it won't matter just solder the two ends to the two lead pads and you should be good to go.
    I haven't had the fan/temp light problem but I can tell you that you have a short somewhere in the wiring and your bulb is acting like a fuse... duh, I know, I'm stating the obvious. Sounds like you're gonna have to trace the wiring. I'd start at the fuse box... good luck
  3. Apr 13, 2010 at 9:32 AM
    ope23
    andy
    Jasper,GA
    03 SR5 4X4
    thanks man!!! I'll hit up the radio shack tonight....
    Yea, I figured it would be the needle in the haystack on that circuit... I'm hunting a diagram now... I was praying it would be a common problem...
    Thanks a ton for your help man!!
  4. Apr 13, 2010 at 11:21 AM
    478DblSport
    Byron, GA
  5. Apr 13, 2010 at 11:36 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
  6. Apr 13, 2010 at 11:42 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Actually, you can put a 500 and 10 ohm resistor in series instead of just approximating and it will work perfectly.
  7. Apr 13, 2010 at 12:24 PM
    ope23
    andy
    Jasper,GA
    03 SR5 4X4
    PERFECT............... Thanks a bunch..... Love this site and info provided... Thanks again for the help..
