Advice and opinions welcome: different models
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bryan459, Dec 6, 2012.
  1. Dec 6, 2012 at 1:52 PM
    bryan459
    bryan459 [OP] Well-Known Member
    We, parents, are getting son used Tacoma for college graduation. Very open to advice and opinions about years and pros/cons of different models.
    Any problem years?
    Any problem models?
    Wondering about buyers remorse over wrong model: regular vs access vs double cab.
    Gas mileage makes me lean toward reg and access, room for friends leans me toward double cab but will bed be too short?
    He's a young geologist so off-pavement and hauling rocks or granite slabs or ... could be in his future. He's likely to hit some dirt roads for camping/fishing, but doesn't appear to be an extreme off-road fan at this time. Barbecues, bikes and surfboards and ice chests and tents for cargo.
    I guess I should find out the weight of my boat since he might tow and launch that on occasion. So that raises the question of how much boat the tacoma can handle.
    Talk to me good people! I value your thoughts and want to spend our money wisely.
  2. Dec 6, 2012 at 2:04 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    07+ to avoid issues with the frame collapsing around the motor mounts.
    The automatic seems to be the transmission of choice behind the v6.
    Double cab short bed is great for carrying primarily people while still leaving room for stuff.
    Get an aftermarket roof rack (Thule or Yakima, and get the air deflector) for hauling the surfboards and bikes.
    Upgrade the rear leaf springs from the stock ones to avoid bottoming out with even a little weight in the bed. Stock leaf packs have 3 leafs.
    TRD Sport has a stronger ring-and-pinion setup relative to the TRD Off-Road, with the trade-off being a limited slip instead of a locker. He should be fine with the limited slip differential in the Sport model.
    Throw some Bilstein 5100 shocks on the truck for nice handling and everyone will be very happy with the setup. :)
  3. Dec 6, 2012 at 2:11 PM
    acdronin
    acdronin Well-Known Member
    V6 is really the only choice for towing, access cab gets better MPG than the double cab. Most folks prefer the auto tranny with the V6. 2007+access cab 4x4 Sport with some beefing of the rear leafs and Bilstein 5100's would handle everything you are describing
  4. Dec 6, 2012 at 2:13 PM
    Nixinus
    Nixinus Well-Known Member
    Oregon
    2010 4x4
    Double cab short bed or access cab sport 4x4 and you should provide him everything he could need. I would also skip the first two years of production (although my buddy has an 05 and the thing is solid). Since the depreciation is often negligable between 05-06 and 07-10, I would look for a newer low miles used Tacoma. FYI, I found a great deal at CarMax on my 2010 Sport 4x4 and then bought the platinum 100k warranty for under $900 (See thread here).
  5. Dec 6, 2012 at 2:14 PM
    acdronin
    Oh and by the way, we have a few geologists on this forum, once he has the truck he should join the forum!
  6. Dec 6, 2012 at 2:22 PM
    Nixinus
    Oregon
    2010 4x4
    You should sign him up now and get his post count up. Give him the keyes with a card that has his UN and PW :)
  7. Dec 6, 2012 at 3:36 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    couldn't have said it better myself. . .well, im sure i could have, but that would require an effort which i will not be applying. so, .. ok. :)
  8. Dec 6, 2012 at 3:44 PM
    SitkaSpruceMica
    SitkaSpruceMica Well-Known Member
    TC
    SE Alaska
    2013 SR5 4x4 I4 Auto AccessCab
    Access Cab 4x4 4cyl will probably provide the lowest total cost of ownership and fit the level of utility you are looking for.
    Auto trans so he won't have expense of replacing the clutch. Service it out front to back and he will be good to go. Later if he wants a double cab to haul friends or a V6 for power he should be able to take care of it.
    TC
  9. Dec 6, 2012 at 4:28 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    You dont need all the frills either of a TRD package despite what all these guys will say. lol. Have had a sport and an SR5, unless he plans on doing some heavy offroading or likes the look of a fake hoodscoop and some small creature things the SR5 looks nice and will serve just fine will also give you some wiggle room in price.
  10. Dec 6, 2012 at 4:31 PM
    aphex
    aphex Well-Known Member
    Pittsburgh, PA
    11 DC TRD OR
    Undercover Classic Tonneau, EGR Aerowrap Bug Deflector, Consolevault Custom Safe, Britax Boulevard 70 Baby Seat!, Retro TRD Shift Knob, Factory Bed Mat, Rear Leaf TSB, 265/75-16 BFG All-Terrain KO's, KMC Enduro Wheels, Front Bilstein 5100's set @ 0" w/ Toytec/Eibach Springs, Rear 5100's, TRD Grille Emblem, OEM Roof Rack, AntennaX 14" Billet Antenna
    ... or OEM roof rack, which I enjoy and seem to get a pretty good rap.
  11. Dec 7, 2012 at 6:00 PM
    bryan459
    Wow! Some great advice. The quality of the TacomaWorld forum seems enough to warrant the Tacoma over other makes. Read everyone's comments and appreciate all. The UN and PW suggestion with the keys seem like a great fun idea. Thanks. Will keep reading. This forum makes me wish I had use for a Tacoma. I might have to borrow his now and then.
  12. Dec 7, 2012 at 6:12 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Unless the truck has been in a flood just pick one you like.
    I like buying from private individuals; you can meet them, see how they've treated the truck and decide for yourselves. Be prepared to change the trans and diff oils right away and some nice high pressure gas shocks would be nice, too. :D
    Keep that oil clean!
    Good luck in your search.
  13. Dec 7, 2012 at 6:15 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    no matter what, your son's gunna be stoked. im jealous of the double cabs at times but know i made the right choice with the access cab. the short beds on the dcabs are just too. . . . . short.
  14. Dec 7, 2012 at 6:34 PM
    ZachMX
    this is why I traded in my double cab TRD sport on a newer 4wd access cab Sr5
  15. Jun 24, 2013 at 1:32 PM
    bryan459
    well, it's a done deal.
    We, because we could, tried to buy our son, the good one lol, a new tacoma, but he held his ground and said he wouldn't feel right taking a new car as a gift and stuck with used. He opted out of short bed double cabs and decided against 4x4, says he'll get truck of his dreams when he has a real job. So, after a lot of shopping around he went with 2004 (prefers 1st gen look) prerunner. It came with an amp and subwoofer and a shell. One happy kid/young man. Thanks for your feedback/input.
