Advice because I won't use my truck for 10 months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Jun 2, 2015.
  1. Jun 3, 2015 at 9:47 AM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    I don't understand why people are suggesting to fill the gas tank before it sits for 10 months, then you get home and have to drive with old gas for 300 miles. Why not let it sit with an 1/8 tank, get home, drive straight to a gas station and fill up with fresh gas?
    jmaack and bra[OP] like this.
  2. Jun 3, 2015 at 10:04 AM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Condensation
    bra[OP] likes this.
  3. Jun 3, 2015 at 11:00 AM
    Styx586
    Terrance
    Lake Elsinore, Ca
    Ah I see... :thumbsup:
    bra[OP] and patbegley[QUOTED] like this.
  4. Jun 3, 2015 at 11:12 AM
    zmw
    zmw Well-Known Member
    SATX
    2014 TXproBAJA
    none
    do not run it out of gas, you'd be far better FILLING the gas tank with as high an octane as you can find, find one with as little ethanol as possible as well. fill tires to max pressure, maybe a bit higher, put it on a battery tender, it'll be fine - better yet - if you have a friend/significant other that can start and or drive the truck for a mile or two every few weeks.
    However if you don't, it'll be fine, all these yahoos telling you to drain the fuel tank are crazy, unless you're going to pull the injectors and let them soak in WD40 and drip some oil in the cylinders, you're better leaving some fuel in the system.
    bra[OP] likes this.
  5. Jun 3, 2015 at 11:21 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    bra[OP] likes this.
  6. Jun 3, 2015 at 11:28 AM
    bucktales
    I use Bounce dryer sheets all over the interior, trunk and under hood areas when storing the Chebby.
    No rodents and the car smells like a brand new haircut, lol.
    bra[OP] likes this.
  7. Jun 3, 2015 at 1:45 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    umm, gas doesn't rot.
    it isn't old skool leaded gas with all sort of crap in it. a full tank ensure the vapors
    fill the entire tank making sure no outside air gets in
  8. Jun 3, 2015 at 1:47 PM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    powdered chili pepper works too, rodents won't cross it or go near it. keeps them
    outta my 4runner when I park it for a long time...without it I am always cleaning
    acorns out of the middle of the 5vzfe
    bra[OP] likes this.
  9. Jun 3, 2015 at 4:42 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Filling with high octane serves no purpose. That's just silly.
    93 will not keep longer than 87.
  10. Jun 3, 2015 at 4:47 PM
    bongwhisperer
    bongwhisperer Well-Known Member
    horn that plays "la cuka racha,"
    What were you competing in?
  11. Jun 3, 2015 at 4:48 PM
    jmaack
    Justin
    Helena Alabama
    Definitely.
  12. Jun 6, 2015 at 8:43 PM
    reastiebeagle
    reastiebeagle Well-Known Member
    Adam
    Seattle, WA
    I leave my truck sitting outside for 8 months every year. I don't do a damn thing except fill the gas tank full and lower my comprehensive deductible. Starts up and drives fine every time I get home. Been like this going on 6 years now.
  13. Jun 7, 2015 at 6:53 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Just a minor snag, other than that, everything went fine! LOL
  14. Jun 7, 2015 at 6:59 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    I'm curious as to why people suggest changing the oil BEFORE you park it for 10 months? What benefit does this offer? Then you have a bunch of fresh oil sitting in the oil pan, and if you are OCD enough to change it before you park it I would assume you would also change it upon your return home, so you're basically 'wasting' an oil change.
    Personally, I'd park it, maybe put the battery on a tender; and in 10 months I'd start it and drive on.
  15. Jun 7, 2015 at 7:59 AM
    #35
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    they change the oil before storage because there are acids in used motor oils and its best to take them out before letting it sit a long time
  16. Jun 7, 2015 at 9:52 AM
    #36
    TRDMastaTech
    TRDMastaTech Member
    David
    Carmel, CA
    07 TRD Yota
    Drain all fluids. ALL fluids. Vehicles that sit for long periods of time will often leak more than those in use. Gaskets and seals are not being lubricated as they normally would while running the vehicle. Drain all fluids, just like a motorcycle/dirt bike.
  17. Jun 7, 2015 at 6:42 PM
    #37
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    I agree with the above if your vehicle will be off the road for several years. The OP's vehicle will only be off the road for 10 months. While very effective, it just isn't necessary, IMO of course. Like many have said, clean it, change oil, take care of the fuel, battery and tuck her in.
  18. Jun 7, 2015 at 7:42 PM
    #38
    yesmar
    yesmar Well-Known Member
    Ramsey
    Harrisburg, PA
    A couple cars
    you have nothing to worry about op. clean it up, fill the gas tank so there's less room for condensation to build and disconnect the neg bat cable so it wont go flat.
    some of you guys are being pretty extreme, These aren't tires from the 1940's your not going to develop flatspots sitting for less then a couple years, and if you do get flatspots your tires probably needed to be replaced from age anyway.
  19. Jun 8, 2015 at 5:32 AM
    #39
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Park it, turn the key off take the battery out put it inside on a trickle charger. I have left cars for a couple of years.
