Advice for new taco that will be driven 5 miles a day?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scorp, Jan 2, 2022.
  1. Jan 2, 2022 at 7:49 AM
    #41
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    idling an engine is almost the worst thing U can do........
    driving such a short distance is not good = not using available HP & torque
    back in Muscle car days many would drive around very slow on idle & low speed circuits
    to save gas & belief l e s s wear/tear on the HI-Performance engine
    only after many miles & time when the engine was eventually torn down
    it became evident slow speed running was a definitve detriment
    i would own & USE the cheapest 4 cylinder throw away i could find
    .......U have 1000X the vehicle U need
    id also walk to & from work everyday
    U will live longer
    INSAYN likes this.
  2. Jan 2, 2022 at 7:51 AM
    #42
    Montana_Actual
    Montana_Actual ;)
    Ceramic coating and fluid changes are your friend. Instead of going for mileage you need to go by months for fluid changes. Every now and then you should definitely take it for a longer spin 30 or so miles or 30 or so minutes. This is to keep the fluids flowing and the moisture out (evaporation) and also keep the battery charged. That's going to be the hardest part, the battery.
    zoo truck likes this.
  3. Jan 2, 2022 at 7:58 AM
    #43
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    Bike to work and make the taco a weekend warrior.
  4. Jan 2, 2022 at 8:11 AM
    #44
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    I used to live 2.5 miles from my work, would ride the bicycle occasionally if the weather was nice, but it sucks in the pouring rain, blazing heat or cold. Kinda quit doing it because rather just do the cycling thing for recreation.
    Had a street bike too, thinking I would save money on gas…but didn’t really because I would take it out on long rides in my down time, plus it is the same thing as bicycles if the weather is shitty, sure you can dress for it, but a pain in the ass just to go such a short distance. Where I could run out in shorts and flip flops in zero degree weather and jump in the truck…
  5. Jan 2, 2022 at 8:14 AM
    #45
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You won't be doing that here. This morning's temperature was -12*F with windchill in the -20*F somethings..... When it goes below 0*F......its all the same....Fing miserable to me.
  6. Jan 2, 2022 at 8:20 AM
    #46
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    I love this post and it is so true. Time is the real killer
  7. Jan 2, 2022 at 8:26 AM
    #47
    Badname
    Badname Well-Known Member
    Socal
    2018 Tacoma Sport AT
    OVTune 2.0 premium Taco rail universal holder Falken wild peak A/T 265/65R17 Center console tray
    Get a golf cart.
    Montana_Actual and BalutTaco like this.
  8. Jan 2, 2022 at 8:29 AM
    #48
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I don’t live in an area where they salt the roads, so I’m no expert on undercoating. They use cinder rocks around here, which are so much better for cars, not to mention the lakes and other water systems. I don’t know why cinders aren’t used everywhere instead of salt. But I’ve read on here that the undercoat Toyota offers is especially terrible and it traps moisture between the frame and the undercoat shell, which leads to more rust and can be worse than if you did nothing at all. Fluid film seems to be the one most people use.
  9. Jan 2, 2022 at 8:32 AM
    #49
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I’ll echo all the others with the “bike” comment—unless it’s utterly unsafe.
    It’s such a short distance, and it’ll be good for your body and mind. I envy that commute. My shortest when I lived in NY was 5 miles, and that took about 35-40 minutes on bike even with all the bloody stoplights.
    DavesTaco68 and RedWings44 like this.
  10. Jan 2, 2022 at 8:36 AM
    #50
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    This is very true. However, I'd venture to say short trips where the engine never gets up to operating temperature is even worse. My Tacoma is the slowest vehicle I've ever had to get up to temp. Even with 10 minutes of warming up on a cold day I'll be about a mile down the road and it may just start reaching the "normal" temperature range but still not be at full operating temperature. A good rule of thumb I've always heard is that trips of less than 5 miles are horrible for engines.
    But yes, too much idling can be a bad thing as well. My work vehicles see a TON of idle hours. The main issues they have are related to the catalytic converters plugging up and other emissions sensors.
  11. Jan 2, 2022 at 8:36 AM
    #51
    SwollenGoat
    Sure you can, remote start and have the truck already warmed up and I can literally pull right in by the front door of work.
    Hell, it was -2 last night when I took the trash out in flip flops and shorts. Have done it even colder, just have to be quick about it.
    Malvolio likes this.
  12. Jan 2, 2022 at 8:40 AM
    #52
    SwollenGoat
    Our Trooper is 20 years old, purchased new, and spent most of its life doing short trips, only thing I had to replace on it so far was the starter and shocks. Think people worry too much. Just drive it…it is a machine they are supposed to make our lives easier.
    Out of all the vehicles I have owned this one warms up the quickest, the needle may not be at operating temp, but the heater comes on extremely fast, like within 2-3 blocks of the house, even my wife commented on it. Unless there is some sort of electric supplemental heater in there I don’t know about.
  13. Jan 2, 2022 at 8:40 AM
    #53
    Knute
    I AM the remote start. Shorts and flips......no fing way this time of year. Hot pants and sandals are for temps above 70*F.
  14. Jan 2, 2022 at 8:41 AM
    #54
    RedWings44
    Michigan
    I believe it comes down to $$$. In Michigan, I believe road salt is cheaper and they can only use that above certain temperatures anyway. Michigan has enough estimated salt to last the next 1000 years at its current use rate and I don't believe it has as easy of access to cinder.
    brian2sun[QUOTED] likes this.
  15. Jan 2, 2022 at 8:41 AM
    #55
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
  16. Jan 2, 2022 at 8:45 AM
    #56
    SwollenGoat
    LOL!
    I’ll run out there and start my wife’s vehicle for her, that will get you awake in the morning!
  17. Jan 2, 2022 at 9:07 AM
    #57
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I drive 4.5 miles to work...one way...I wouldn't ride a bike to work! lol
    In the morning, I let the engine run for about 1-2 minutes...nothing too long...even though the engine is still revving at about 1200 rpms. The instrumentation system takes about a minute to load on the dash display anyway. I engage "D" and release the foot brake and she takes off on her own...I steer her on my trek and away I go!
    Snow has yet to fall here in the TriState area but we are expecting snow at about 3am tonight. I'm thinking about putting some bricks from my yard that aren't being used and lay them in the bed of my truck...putting a liner (heavy plastic or tarp material) to line between the bricks and the new bed mat. (at the end of the bed by the gate)
    I have not considered putting any protectant in the undercarriage of my truck. I've never done that with any new vehicles I've purchased. The new Elantra we bought in 2017 here in Delaware was never coated and the underside has survived the past almost 5 years of ownership.
    Took my Taco for its first Scheduled MX oil change at just under 5K miles and am scheduled for the 10K mile MX in mid Feb.
    My Drive Pulse on the Toyota app has a current rating of 87 using the following factors:
    Fast Acceleration - 41
    Harsh Cornering - 166
    Harsh Braking - 43
    I'm guessing this is data started from when I took ownership/launched the app.
    Inspect your vehicle as often as you like...I do it because I admire my Taco and take pride in the little upgrades I've done.
    Take my testimony with a grain of salt. Everyone enjoys their Taco in their own special way.
    E
  18. Jan 2, 2022 at 9:09 AM
    #58
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Wife had a similar commute, 1.6 miles each way for years. I'd take her vehicle as often as I could and
    drive it on the highway a few times a month, get it up to 60-70 mph etc.
    I'm retired, zero commute, but I take mine out for a spin now and again, small 1-2 hour trips heading to
    the Superstitions or Tucson or where ever, camera at my side, exploring around. Buy yourself a good camera
    (Nikon!) and find an excuse to roam.
  19. Jan 2, 2022 at 9:11 AM
    #59
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    I’m like you at times, and other times I’m a road fool. So, use your instincts and check the service guide as the reference it is. Use the date references rather than the mileage.
    these are the statements I agree with. I try to run on the interstate for at least 10 minutes a week (helps get oil up to temperature to burn off oil crystallization). The oil/filter changes will do the rest. You will need to exercise that 4x4 at least once a month (all phases, including locker). It’s a use it or lose it item. I just take advantage of rainy mornings. Since your fuel consumption is low, remember to treat your gas with a storage treatment, so that ethanol doesn’t mess with your fuel system while sitting. That interstate run will help with this also, keeping the fuel injectors exercised.
    As for the rust/sand/salt protection, everyone here vacillates between FluidFilm and Cosmolene. I recall plenty of undercarriage car washes when I was traveling the north. Perhaps get a undercarriage wash head for your hose/pressure washer.
    Welcome and enjoy your TACO!
  20. Jan 2, 2022 at 9:29 AM
    #60
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    Short trips are just plain bad for a vehicle.. Get an electric fat tire bike and ride to work. How much time are you really saving driving 1.8 miles like maybe 5 minutes. Beside short trips like that are not good for the longevity of the truck, which you say you want to keep "forever". Short trips are also battery killers. It takes roughly 15-20 minutes for the alternator to regenerate the amperage used from one start up. There's sooooo much info on the web about this exact subject.
    .劉煒 and Malvolio like this.
