Advice for Prospective Buyer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 97RangerXLT, Jan 5, 2021.
If you could pick any mid-size pickup, which would you choose?
  1. Tacoma (duh!)
  2. Ranger
  3. S10 / Colorado / Canyon
  4. Frontier
  5. Other
Results are only viewable after voting.
  1. Jan 5, 2021 at 12:44 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    If you're looking for ease of service, then a V6 second gen is pretty easy to work on. The oil filter is right on top, the differentials and transfer case are super easy to swap fluids on. Since you're looking to go manual you don't have to fool with any special filling procedure like the automatic. Driveshaft U-Joints are greaseable from factory. Some of the other trucks you're considering are a pain to do just simple services. There are a couple repairs that are a pain in the ass, but that's any modern vehicle. If you can keep the rust at bay you'll have a solid truck. I will warn you at 100K you're at the life of the wheel bearings on these trucks (front and rear). I'd still have my 2009, but the underneath was slowly starting to get really bad. That and the automatic transmission was definitely on its last leg.
    FlyingWolfe likes this.
  2. Jan 5, 2021 at 12:47 PM
    97RangerXLT
    97RangerXLT [OP] Member
    Nick
    NoVA
    2013 ACLB 4x4 MT TRD Sport
    Stock so far!
    Excellent advice! I agree, although I do the PPI myself (my dad's a certified mechanic and taught me a lot). The only reason I care about mileage is that I plan on listing the truck on a car sharing site, which requires it to have under 110k when listed. If I weren't planning on sharing it, mileage wouldn't really matter to me.
  3. Jan 5, 2021 at 12:55 PM
    97RangerXLT
    Nick
    NoVA
    Stock so far!
    Thanks! That's exactly why I sold my Ranger. Oil changes were easy, but every time I'd fix one annoying issue, another would pop up. And nothing on that truck was designed well (except maybe the door panels, those came off and went back on easily).
    Good to know about the wheel bearings. Looks like they're easy enough to change out. I like the hub style units that just bolt right in!
  4. Jan 5, 2021 at 1:25 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Having owned a Chevy S10 and bunch of other GM products all I can say is that owning a Tacoma will cause your mechanic skills to atrophy. Fill with gas change the oil... fill with gas, change the oil. Unless you do mods this gets boring... but in a good way.
    Hyperbarics and FlyingWolfe like this.
  5. Jan 5, 2021 at 3:39 PM
    97RangerXLT
    Nick
    NoVA
    Stock so far!
    Sounds like exactly what I'm looking for! With the number of projects I still have and the number of people who routinely ask me to work on their cars, I seriously doubt my mechanic skills will be in danger.
    Raylo[QUOTED] and FlyingWolfe like this.
  6. Jan 5, 2021 at 4:53 PM
    Raylo
    MD, USA
    I see you are in NoVa... I am over here in MD... so there is salt. The older the truck the worse the potential issues. You know about the frame but some other stuff can be an issue eventually. I had to replace a portion of the transmission cooler hard lines where they go into the tranny. For some reason those got a lot rustier than the other hard lines and developed a pinhole leak that almost cost me a tranny. Luckily I noticed the first bad shifts and found and fixed the leak. This area is easy to inspect on the passenger side behind the front wheel. As a data point my truck is a 2009 bought in November 2008 and this just became an issue this past fall.
  7. Jan 6, 2021 at 4:47 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    I was stationed in Portsmouth VA for five years and moved back home to Maine in the winter 'salt belt' and am less then 10 miles from the ocean.. One word: Woolwax. :thumbsup:
  8. Jan 6, 2021 at 9:14 AM
    97RangerXLT
    Nick
    NoVA
    Stock so far!
    Sounds like a good idea, but I'm not sure if I'd like having a film overtop of everything underneath the truck. Does it make maintenance and repairs less pleasant?
  9. Jan 6, 2021 at 5:17 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    As long as you dont grab the frame to drag yourself around on a creeper underneath it, its fine. Will probably suck with any major repairs but id rather deal with some black crap on my hands/gloves than a frame rusting in half personally. My damned chickens like to play under my tundra though and all have black tips on their tails from hitting the WW :rofl:
    Hyperbarics likes this.
  10. Jan 7, 2021 at 6:15 AM
    97RangerXLT
    Nick
    NoVA
    Stock so far!
    Thanks! I'm thinking it might be optimal to spray WW inside the frame and coat the outside with POR-15. That should give me the best of both worlds and not require annual recoating.
  11. Jan 7, 2021 at 6:18 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Frontier
  12. Jan 7, 2021 at 6:21 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Def not a 2012 bro!!!!! They have the limp codes from hell! Please please buy 2013-2015
  13. Jan 7, 2021 at 6:58 AM
    97RangerXLT
    Nick
    NoVA
    Stock so far!
    Thanks! The one I'm looking at is a 2013. This is the kind of advice I was looking for :)
  14. Jan 7, 2021 at 9:31 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Best advice ... test drive extensive
  15. Jan 7, 2021 at 4:20 PM
    #35
    BigKahunas15
    BigKahunas15 Well-Known Member
    Dan
    Prince George B.C, Canada
    Black 2015 TRD 4.0l 6MT
    Bilstein 6112 HD Dakar leaf pack CBI sliders and custom bed rack 295/70/17 Geolander MT G003
    Im on my 3rd Toyota truck. They really are great trucks. Here is my 2 cents on getting a 6MT tacoma. If youre comfortable driving a standard you probably wont have much of an issue getting used to it, but these trucks do not drive like a Honda civic by any means. They like to be shifted slow and accurately. You can shift them pretty quickly if you are that kind of person, but ive heard stories of bent shift forks due to aggressive driving. That being said, I think the same transmission was also put in the tundras, so I would think that these transmissions are well over build for the application. Ive never had issues with mine and I honestly like it quite a bit. The gearing is a good balance for on/off road driving (with stock gears) and I can get some pretty reasonable MPG with my 295 mud terrains. The clutch is a little bit dead but whatever, its a truck!
    I still prefer having three pedals :burnrubber:
    Kolter45 likes this.
  16. Jan 7, 2021 at 4:41 PM
    #36
    Kolter45
    Denver, CO
    I wanted 3 pedals.....but there’s no way the wifey could drive a standard in the snow. :boink:
  17. Jan 7, 2021 at 10:25 PM
    #37
    BigKahunas15
    Dan
  18. Jan 8, 2021 at 6:26 AM
    #38
    97RangerXLT
    Nick
    NoVA
    Stock so far!
    Thanks for the heads up! Nearly all my vehicles are manual, so I think I'll be fine :)
  19. Jan 8, 2021 at 6:32 AM
    #39
    Kolter45
    Denver, CO
    :smokertransformer: Hell yea!
  20. Jan 11, 2021 at 9:17 AM
    #40
    97RangerXLT
    Nick
    NoVA
    Stock so far!
    Thanks everyone! I am now a happy Tacoma owner!
    CJP4X2X2 and FlyingWolfe like this.
