Advice for re-key
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pnwadventure, May 11, 2022.
  1. May 11, 2022 at 10:22 AM
    Pnwadventure
    Pnwadventure [OP] Well-Known Member
    Kirkland wa
    2006 white access
    My 2006 ignition key cylinder finally bit the big one. Not too disappointed because I was down to my last key anyway. My final key was the valet key and didn’t open the door but would start her up until now.
    Most Toyota dealers quoted me crazy prices for new keys. I plan on removing the ignition key module and dropping it off to a locksmith for rekeying. I think I could get away with taping my valet key to the sensor to get around the chip
    Any advice or ideas would be greatly appreciated. Thanks
  2. May 11, 2022 at 10:32 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    A locksmith should be able to cut and program new keys much cheaper than the dealer.
    Raylo likes this.
  3. May 11, 2022 at 10:35 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    As long as you have a key with a good chip you could install a remote starter kit. Those include bypass modules to simulate the chip and let the truck start. But... you still need the key to drive it which would work as long as the key cylinder "run" contacts are still OK even if the start contacts are not.
    The other thing you could do is buy or borrow an XTool D7, D8 or I believe even the cheaper A30M or similar and program your own new keys. Might make sense depending on how much the stealership is asking... and if you want a good scan tool anyway.
  4. May 11, 2022 at 10:47 AM
    Pnwadventure
    Kirkland wa
    2006 white access
    Thanks for the quick replies. Great ideas
    Dm93 likes this.
  5. May 11, 2022 at 12:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Don't know if you're in the Seattle area but check out Bulger Safe and Lock in Lake City, they do good work
    Dm93 likes this.
  6. May 11, 2022 at 12:24 PM
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Not sure if this helps you out, but using techstream to pair up new keys is very easy to do. Although I think you need to have a working key to pair up the new ones, so you might be SOL.
  7. May 12, 2022 at 10:32 AM
    Pnwadventure
    Kirkland wa
    2006 white access
    I am in the Seattle area and have recently been driving by them daily for work. Thanks for the tip saved me from posting in nw forum
