Advice from the dealer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SeniorSpan, Jun 20, 2016.
  1. Jun 20, 2016 at 3:45 PM
    SeniorSpan
    SeniorSpan [OP] Well-Known Member
    Bob
    Colorado Springs
    23 TRD DCSB OR
    I just took my 2011 DC TRD OR (TX Pro) (71,000 miles) in for maintenance I could do (water pump, sep belt , and thermostat) but time was against me. While waiting for the work to be completed the shop tech suggested I have my brake fluid changed; I declined. I keep a constant check on fluids along with other gen maintenance checks. The brake fluid it the same color it was when I bought the truck new.
    So I question the tech as to why should I do that, he replied, after a couple of years brake fluid get moisture in it and should be changes. As far as I know moisture in brake fluid would turn it cloudy. Mine is clear.
    So, opinions on how often one should change the brake fluid please
    ChadsPride likes this.
  2. Jun 20, 2016 at 3:53 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Had a brake caliper lock up on another vehicle, because brake fluid moisture built up on the piston and rusted out. Brake fluid looked clean.
  3. Jun 20, 2016 at 3:55 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Very interested in what anyone with expertise thinks on this. My fluid is 8 yrs old and clear. I put a test strip in it and strip said it was fine. I'm a maintenance fanatic but I can't get motivated to change this fluid because of the above.
  4. Jun 20, 2016 at 3:57 PM
    george3
    New Jersey
    Just saw your post - "caliper" fluid clean - might be motivation
  5. Jun 20, 2016 at 4:17 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Canadian maintenance booklet calls out brake fluid replacement every 48 months as a hard requirement. There, no need to think on it. :)
    I let the dealer do it, though. Bleeding the whole system is too troublesome for me, especially on a TRD Off Road with the electronic brake valves.
  6. Jun 20, 2016 at 4:45 PM
    Pigpen
    Dan
    Northwest Montana
    I flush mine about every 3 years. If I'm over two years and doing a brake related project, I'll just do a flush while I'm at it.
  7. Jun 20, 2016 at 4:56 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    ...^^^... Did the dealer give you a price on the work suggested ??
    FWIW ... I am crazy on PM (Preventative Maintenance) and changing ALL fluids at or before maintenance schedules.
    With that said ... as some above have stated ... hidden problems could come up and you don't know it until it's too late.
    Let the "mechanic pros" give you the best advice ... but for me ... changing ALL fluids is the cost of doing business in a Tacoma and keeping you off the side of the road at midnight ... :eek:
  8. Jun 20, 2016 at 5:07 PM
    Pigpen
    Dan
    Northwest Montana
    Brake fluid is designed to absorb moisture. When under high pressure (braking) that water turns to vapor, which is compressible. This makes the brakes feel squishy and reduces braking performance.
  9. Jun 20, 2016 at 5:35 PM
    george3
    New Jersey
    Interesting - I don't remember seeing this in my Owners Manual but then I don't live in Canada.
  10. Jun 20, 2016 at 5:49 PM
    KenLyns
    Belly of the Beast
    I can confirm it is not in the US maintenance booklet, only in the Canadian one.
    The Canadian maintenance booklet is slightly less influenced by marketing. You see a few threads on TW questioning the "lifetime" nature of coolant and ATF. In the Canadian booklet, coolant is 5 years / 80,000 km (50,000 mi); ATF is 6 years / 96,000 km (60,000 mi).
  11. Jun 20, 2016 at 8:11 PM
    tacoma4
    tacoma4 Well-Known Member
    If you are comfortable changing the water pump, then brakes should be easy. Just do them one at a time and you shouldn't get any air in the system if you keep an eye on the reservoir. Even if it doesn't all come out just do it again in a year or two. Brake fluid is cheap
  12. Jun 20, 2016 at 8:13 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are you testing the fluid in the tank or a sample from the caliper bleeder?
    I would take a sample at the caliper.
    Get a pressure bleeder and do it yourself.
  13. Jun 21, 2016 at 4:48 AM
    SeniorSpan
    Bob
    Colorado Springs
    23 TRD DCSB OR
    I really appreciate the info filled inputs, thanks. I did test the fluid at the tank vs the caliper bleeder, so will make the check at the bleeder and if needed I do have a brake vacuum bleeder and will change out the fluid one wheel at a time. I believe the Toyota tech quoted $100 for the process and that included disposal of the old brake fluid.
    Thanks
    Bob
  14. Jun 21, 2016 at 5:07 AM
    FredSanford
    FredSanford Fish Eyed Heathen
    Close to Indy
    White 2010 Taco
    For a hundred bucks , they can do it.
    I've had the same question since I bought a BMW motorcycle a few years ago the factory has a system
    flush service interval as part of the service schedule. Not long after I bought the bike I took my Silverado to the Indy shop that I use for some other things that needed done and asked that that the flush the brake fluid. They pushed back with the argument that hydraulic fluid in a closed system doesn't need to be changed.
    I've never been satisfied with either answer. I'll have to check my Toyota manuals closer.
  15. Jun 21, 2016 at 5:53 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    A water pump should not be due for a change until it either explodes (metaphorically speaking) or your timing chain needs to be replaced, which I think is 200K (or is it 150K?).
    I do not change my brake fluid unless I'm having a problem with it. Is see no reason to mess with a sealed fluid system when, like you said, the fluid level and color is just fine.
    Stop taking your truck to a dealer. You are going to end up hosed on maintenance you don't need on top of cost.
    2000TRDTaco likes this.
  16. Jun 21, 2016 at 6:04 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    There's a few how too videos on doing it yourself with a tube and empty clear big soda bottle. I did it by myself in 20min. Easy to do. And I'm retired, and it didn't cut into my afternoon beer and nap one bit.
  17. Jun 21, 2016 at 6:53 AM
    chunt5
    chunt5 Senior Citizen Member
    chuck
    Cumming, Georgia
    2015 DCSB, Prerunner, SR5, 4.0
    My Altima maintenance manual states to change the brake fluid every 20,000 miles or 2 years. I will most likely do the same on my Tacoma. Cheap insurance and I can do it myself.
  18. Jun 21, 2016 at 7:02 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Brake fluid is hydroscopic so it absorbs moisture. In areas with high humidity I would change the fluid every 2-3 years. I live in Nevada (the driest state in America) so I usually don't worry too much about it unless it's over 5 years old. The fluid in my 2007 Honda Civic was 9 years old and I had zero brake issues when I traded it in, but I was mad at myself for slacking on that maintenance.
  19. Jun 21, 2016 at 7:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    It really does have some dependence on both how the brakes are used (towing, racing, mountain grades vs leisurely driving), the weather conditions in your area (arid, humid, long heavy freezes). Mileage is a toss up too. For example high miles from long interstate travels is nothing.
    While this article does not prescribe intervals, it does explain why these changes should be considered.
    http://stoptech.com/technical-support/technical-white-papers/brake-fluid
    For a pavement queen under normal conditions, I tend to use 3-4 year changes. Sometimes I'll siphon out the MC and refill with fresh fluid as a partial change. Kinda like a drain/fill on an auto trans. If I have to do a full on brake job at any time, like caliper replacement, wheel cylinder replacement, master replacement, etc., it always gets a flush/bleed.
    On my SCCA rides, brakes were abused and serviced more often, and fluid changes occurred every 6 months to a year when HPDE events were included. Autocross, not as much, because it's more like harsh street driving, but very unlikely to overheat any fluid.
    Age alone say yours could stand to be done. PM if nothing else.
    NAAC3TACO likes this.
  20. Jun 21, 2016 at 8:29 AM
    spitdog
    So do all agree that just dot 3 from the local auto parts store is ok to use.
