Advice from the MT guys, please?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cwdog, Dec 21, 2018.
  1. Dec 21, 2018 at 9:37 AM
    cwdog
    cwdog [OP] Well-Known Member
    Asheville, NC
    2017 Tacoma Limited
    Meguiars Ultimate Wax, Rain-X, Dog Bed, Undercover Tonneau Tri-Fold, Debadged.
    Just wondering at what RPM (typically) do you shift at? Since we AT guys have the option of shifting as well, just wondering for fuel economy sake, where you folks shift. I understand shifting for power is something different. AT folks please chime in as well.
    Looking forward to the responses!
    stealthmode and Nunya Bizness like this.
  2. Dec 21, 2018 at 9:42 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    The responses you get are going to vary. I don't like to lug the engine, so its 1700-2000 for me, on average.
    oconnor likes this.
  3. Dec 21, 2018 at 9:43 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It depends on the situation. If cruising, I'll up shift at as low as about 2k. Post-TSB, there is plenty of torque / power to move along at just over 1k. If I need to accelerate hard, dropping two or three gears is typical realizing that 2nd redlines at just over 60mph. And, 6th to 3rd is an easy drop.
    If screwing around, the rev limiter gets played with.
    Edit: Pre-TSB, I could climb grades and maintain speed in 6th at 40mph, but no less. Post-TSB, 5th works fine at 30 and 6th at 35. The great part about that is the option to either go full throttle to gain a bit of speed or row, row, row the gears all that I want.
    Aww Boo and shakerhood like this.
  4. Dec 21, 2018 at 9:48 AM
    hikerduane
    hikerduane Stove & lantern collector, retired
    Duane
    Meadow Valley, Jefferson USA
    '16 Blazing Blue Pearl TRD Sport AC V6 manual, tow pkg
    RCI sliders fuel tank skid plate, Softopper, tailgate insert
    I think around 2,000 +-, shift by ear.
    Duane
    Pirate1975 and tonered like this.
  5. Dec 21, 2018 at 9:49 AM
    M1Awolf
    M1Awolf Well-Known Member
    Rob
    Montana
    2017 TRD Off Road DCSB M/T
    This unless I am feeling sporty,this will also vary greatly by tire sizes and gears.
  6. Dec 21, 2018 at 9:52 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    It really varies. If I am pulling out onto a state hwy, 1st is ~3500, 2nd 3000 to 3500, 3rd ~2500 to 3ish, 4th up until ~50 to 55mph then I plop it into 6th. Around town ( ihave no stop lights), windy roads, or windy state road, 4th and 5th get used alot more and revs vary depending on the terrain
  7. Dec 21, 2018 at 9:57 AM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    If one needs to watch the tachometer to figure out when to shift, they shouldn't be driving a MT. No insult meant here, just that seasoned MT drivers know when to shift based on the road situation.
    black coffee likes this.
  8. Dec 21, 2018 at 10:08 AM
    CaptainVoodoo
    CaptainVoodoo Well-Known Member
    Charles
    Quebec
    2019 TRD Pro Voodoo Blue M/T
    None yet
    This. That's the thing about MT, you shift whenever you feel is the best to shift at the present conditions, but for fuel economy sake, I would say at the 2000ish mark. Then again, I didn't buy a MT for fuel economy, so more often than not I shift to always keep the engine above 3500 until cruising speed is attained.
    02Duck likes this.
  9. Dec 21, 2018 at 10:15 AM
    TBV
    TBV Well-Known Member
    Oakland CA
    2017 TRDOR 6MT
    The AT gets better MPGs cuz it shifts way earlier than anyone would on the MT.
  10. Dec 21, 2018 at 10:35 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    I usually shift around 3000rpm during normal acceleration. Then cruise around 1500-2000rpm.
    Only issue I have is that 1st-2nd feels a little crunchy if I shift around 3000rpm for some reason... feels better to me to shift 1st-2nd below 2500 or above 3500.
  11. Dec 21, 2018 at 10:49 AM
    dnlskier
    17' TRD SPORT MT
    Maybe - when I had stock OEM tires with the chin strap and tri-fold tonnpro cover, I could easily get 23 to 24 mpgs with summer gas. Winter gas was pretty consistent 21 to 22s. This is not babying it, jsut normal driving weith some redlines here and there. Now I have no chin strap and 265/70-r17 KO-Bros I am down to 18s to 19 on winter gas.
    SilverBulletII and tonered like this.
  12. Dec 21, 2018 at 11:21 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    I keep the revs up personally. 90% of the time I am between 2000-3000 RPMs regardless of gear. Shift at 3000ish if I'm accelerating.
    Tacotoast likes this.
  13. Dec 21, 2018 at 11:31 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It depends on the situation and where i am driving on when I shift. 95% of the time I do skip gears, usually 4th or 5th.
  14. Dec 21, 2018 at 11:42 AM
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    Yep..shift by ear! Don’t even have to look at rpm’s..I do this in all MT’s..Driving an auto makes me cringe when it needs to shift and hesitates..
    dnlskier and tonered like this.
  15. Dec 21, 2018 at 11:45 AM
    eon_blue
    Azusa, CA
    I used to drive a manual Dakota that didn't have a tachometer, it had a light that would flash if you were approaching redline to warn you but otherwise, you just shifted off of feel/sound.
    It also had a 2.5l 4 cylinder in it that was completely and utterly powerless, couldn't even get up the hill into my neighborhood if I had to stop for some reason. Only had that truck for a couple months lol. Was a naive 18yr old impulse buy.
    Rob Daman likes this.
  16. Dec 21, 2018 at 11:46 AM
    eMKay
    eMKay Well-Known Member
    Michael
    Buffalo, NY
    2019 Cavalry Blue DCOR 6MT
    Pro Grill, roof rack, HID headlights, yellow fogs, LED high beams, trailer brake controller
    Lower than I thought I would reading about the “no torque” engine. I had the same engine in a Sienna and usually drive it like I stole it, I’m much more chill in this truck.
    Nunya Bizness likes this.
  17. Dec 21, 2018 at 11:46 AM
    Shellshock
    Iowa
    usually in the 2500-3000 range with the MT
    nevadabugle and Nunya Bizness like this.
  18. Dec 21, 2018 at 11:54 AM
    J_dog
    J_dog Well-Known Member
    Victoria, Canada
    2016 Tacoma Black TRD Sport MT / 2018 Tundra TRD Offroad
    If I am really trying to save gas around 2000. But normally around 2500-3000 or when it feels right. That's currently with stock tires and no lift.
    COSTCOHOTDOG and Nunya Bizness like this.
  19. Dec 21, 2018 at 11:55 AM
    Nunya Bizness
    I always shift at redline :burnrubber:
    Jk. I usually shift around 3k
    J_dog and shakerhood like this.
  20. Dec 21, 2018 at 12:00 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    AT and MT have different ratios so it's no comparison.
    shakerhood likes this.
