Advice needed ASAP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bajaracer, May 26, 2018.
  1. May 26, 2018 at 9:01 AM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Hello... I’m in the middle of a road trip, stopped at my parents house in Yuma overnight. This morning I decided to check the fluids out one more time before I hit the road and noticed that my coolant reservoir was almost all the way to the top. I opened the radiator cap to check the inside and it was bone dry. I was thinking maybe I somehow developed an air bubble so I kept the radiator cap off and turned on the truck with the AC and let it warm up. After 20 minutes the reservoir is still full, the radiator is dry but the temperature gauge is in in the middle, where it should be. There are no leaks, truck idles fine, AC is working great, no overheating whatsoever. I’m very confused?!?
    (I was able to remove the radiator cap while the truck was on after the 30 minutes and still no circulation but the temperature isn’t perfect) Please help...
  2. May 26, 2018 at 9:13 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Look at the seals on the radiator cap. If the one under the cap, itself, is damaged, the system will not pull the antifreeze back from the overflow tank. Fill the radiator too.
    TRDSport10 and MolonLabeTaco like this.
  3. May 26, 2018 at 9:30 AM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    That's bad. You should never have tried that. Take it to a shop before you do more damage than good.
  4. May 26, 2018 at 9:33 AM
    bajaracer
    Charly
    Chandler
    Thank you, i will start with that even though it doesn’t look damaged but I will replace it.
  5. May 26, 2018 at 9:49 AM
    bajaracer
    Charly
    Chandler
    @Bell241b, I know it’s bad but I wanted to eliminate any doubts.
    Changed the radiator cap, water level dropped just a bit, topped off the radiator... No indication of overheating or anything else.
    wilcam47 likes this.
  6. May 26, 2018 at 10:15 AM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Have you checked your oil?
  7. May 26, 2018 at 10:48 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the little rubber hose that goes to the reservoir, make sure it's not sliced open or loose where it connects. Just Like the rad cap seal mentioned above, a leaking reservoir hose could suck air instead of coolant back into the radiator when it cools down
  8. May 26, 2018 at 11:24 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Maybe try running the heat?
    Have you had to add or did you change fluid.
  9. May 26, 2018 at 11:40 AM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Take it to a shop and have the antifreeze in your radiator checked for exhaust gasses. It could be a head
    gasket.
  10. May 26, 2018 at 12:23 PM
    Nomad_Pilot
    Clay
    Ft Collins
    Ohh shit it is an 06 too......
  11. May 26, 2018 at 12:32 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Go to Mr G's. Get some taquitos then take it to a shop and get it checked. The taquitos should help with any bad news that you get . If you have access to a air compressor you can pressurise the each piston and check for bubbles in the radiator. If you have bubbles it's a bad head gasket. Also the spark plug in the piston that is sucking up the fluid will be cleaner than all the others. Good luck
    phx13 likes this.
  12. May 26, 2018 at 1:10 PM
    bajaracer
    Charly
    Chandler
    Oil is clean. I changed the rad cap and added about 10 ounces of coolant. Drove it around and saw that it was a bit hot. Drained the reservoir to the “full” line. Going to drive it again for a bit to see if there is any difference. The temperature is on point.
  13. May 28, 2018 at 8:13 PM
    bajaracer
    Charly
    Chandler
    Hey guys, sorry to keep nagging but still baffled and need further advice. After i drained the reservoir to the "full" line and changed the radiator cap as mentioned, the truck ran as it did before, like a champ! Drove it around, but checked the antifreeze fluid in the reservoir. It didnt change, on the 'full" mark. Checked it again before heading back to Phoenix and still the same But opened cap and it was dry, as far as i could see. I did not add any antifreeze like i did last time for fear of it spewing out like before. Once again, truck drive like a champ a;ll the way home, with AC blowing ice cold. After an hour or so i decided to look again and the antifreeze in the reservoir was now about an inch to inch and half above the "full" line. I checked the oil and still clean, checked the oil cap and no sludge milky crap. I drained it to the "full" line again and added some to the radiator. Ran it again and noticed slight condensation off of the exhaust, condensation and not antifreeze. Havent seen or heard of bubbles and where under the dash or reservoir. So im stumped,,,, Am i forgetting to check anything? Do you guys think my engine is toast (headgasket)? Can anyone PLEASE recommend a reputable trustworthy mechanic to check this out? This is my DD. All info is greatly appreciated.
  14. May 28, 2018 at 8:27 PM
    tcjacado
    tcjacado Well-Known Member
  15. May 28, 2018 at 8:32 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Check hose to the reservoir. If that doesn't work you need to test that the system can hold pressure.
  16. May 28, 2018 at 8:50 PM
    bajaracer
    Charly
    Chandler
    Just checked the hose to the reservoir and it's ok,,,
    @JaCado im trying to get as much info as possible. Im hoping some people from AZ chime in.
    tcjacado likes this.
  17. May 28, 2018 at 8:53 PM
    tcjacado
    No problem.... I would go into the az-bs 5.0 thread for that and to see about a good shop/local mechanic.:thumbsup:
    Sorry I can't be of more help, good luck :fingerscrossed:
  18. May 28, 2018 at 9:42 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Is the water pump leaking at all? You might have to remove the skid plate to get a good look at it. Mine started to leak out of the weep hole on the bottom of the pump. Also check for leaks from the thermostat housing and cooling hose that goes under the intake manifold.
  19. May 28, 2018 at 10:16 PM
    bajaracer
    Charly
    Chandler
    Checked all the hoses (granted is dark) and everything is dry as a bone.
  20. May 28, 2018 at 10:25 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I'd say the next step is to check that the cooling system can hold pressure, you can probably rent the tool at your local auto parts store.
