Advice Needed - Damage remediation from genesis dual battery kit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bigbluetacotruck, Jan 20, 2021.
  1. Jan 21, 2021 at 11:57 AM
    #41
    bigbluetacotruck
    bigbluetacotruck [OP] Member
    has anyone cab mounted their batteries behind the seats? could that be a viable solution for this issue?
  2. Jan 21, 2021 at 2:30 PM
    #42
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    There isn't one. Stop drilling just relieves most of the stress concentrated at the end of a crack, but without reinforcement it does nothing to fix the problem. I didn't think anyone suggested only stop drilling without some measure to support the area that is cracked.
    You should assume less.
  3. Jan 21, 2021 at 2:39 PM
    #43
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    sorry if this sounds dumb, but for my motorcycle, I can replace my 10 lb battery with a 1.4 lb lithium ion battery. I could have googled it, but I'm sure someone on here knows. Do they make a group 24 Lithium Ion battery that weighs a buttload less?
  4. Jan 21, 2021 at 2:43 PM
    #44
    eurowner
    eurowner Duke Sky
    Scoty
    jimmerheck[QUOTED] likes this.
