advice needed for newbie
Discussion in '1st Gen. Tacomas (1995-2004)' started by scottymc, Aug 12, 2010.
  1. Aug 12, 2010 at 7:22 PM
    scottymc
    scottymc [OP] Member
    Whiteford MD
    02 double cab trd
    none yet
    I just ordered billy 5100/5125s. I also got skyjacker 2.5" leafs. At the highest adjustment the Billys will be at 2.5". My question is can I add top plate spacers up front to help level it out or is this out of the question. I am trying to piece together a quality lift that will give me a great look but will have a good ride quality. I think all I still need to get is a diff drop kit and new U-bolts. Any advice or suggestions would be greatly appreciated.
  2. Aug 12, 2010 at 9:57 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Honestly If I were you, since you got the 5100 adjustables for the front & the 5125's for the rear in addition to a new leaf pack , try setting the 5100's for max height so you have a level truck & drive it for a short time (on road & off) & evaluate really how the ride is before going the spacer route .. just my 2 cents....:cool:
  3. Aug 12, 2010 at 10:00 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    I'm certain you'll be too high up front to align properly if you have both. Many have problems aligning right at 1.75" up front. Also, at that angle, you'll put substantially more wear on ball joints, etc. That may matter to you or not.
    My $0.02. Good luck and tell us how it goes!
  4. Aug 12, 2010 at 10:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you were a prerunner you could go higher than 2.5 but being a 4x4 you'll be very near the limit of what your CVs and associated boots can handle and survive very long even with the diff drop kit.
  5. Aug 12, 2010 at 10:18 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    You guys are right in both instances, the reason I suggested the 5100's at full height is because he has a 2.5" leaf pack for the rear & I didn't catch if he's 4x or pre runner, if 2wd not so much of a problem if 4x ,well as stated alot more angle stress on CV's , I gotta tell ya I'm starting to long for my old solid axle SR5.....:eek:
  6. Aug 13, 2010 at 8:07 AM
    scottymc
    Whiteford MD
    02 double cab trd
    none yet
    Thanks for the advice. I think I'll hold off on the spacers and just set the billys to max hieght and deal with it being un-level.
  7. Aug 13, 2010 at 8:33 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    You can always swap out the rear AAL for a smaller AAL to level it.
  8. Aug 13, 2010 at 8:58 AM
    scottymc
    Whiteford MD
    02 double cab trd
    none yet
    I have full replacement leaf packs. I wanted to aviod aals because my stock leafs are arching the wrong way.
  9. Aug 13, 2010 at 8:47 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My guess is that everything will settle out a bit with time. Depending on how all that turns out, you may be able to add in the leveling spcaers without a problem.
    My suggestion would be to keep a close watch on your front axle boots. If they are not near to touching together, you may be able to add in a leveling spacer after everything settles out.
    This is one advantage to having adjustable coilovers. :D
