Advice needed on high mileage transmission oil change.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Akirakodi, May 19, 2015.
  1. May 19, 2015 at 7:37 PM
    Akirakodi
    Akirakodi [OP] Member
    '08 Super White DCSB 4x4
    Hi, I recently purchased a '08 Tacoma from original owner with 173k hwy miles. I've seen service records for regular oil changes but the original owner doesn't remember when the transmission oil was changed. So it was likely done around 60k or not at all.
    I've heard mixed advice from oil change and transmission service guys on whether it's wise to change the oil at this point as it might cause problems. As of now the transmission seems fine other than some "strong" shifting, which seems to be common among Tacoma owners. But if changing the oil would prolong the life of the transmission I certainly want to do it.
    Any advice?
  2. May 19, 2015 at 8:38 PM
    Rx7turbo2
    Rx7turbo2 Well-Known Member
    Canada
    2020 TRD OR DCSB (Current) 2005 TRD OR DCSB (Sold)
    My understanding is that on a higher mileage tranny a drain and fill is more advisable than say a flush and fill.
    My 05 has roughly 100k on its original fluid as well (original owner never did it) my plan is a drain and fill in the next couple weeks, another one mid summer, and a final one before winter. That should get most of the old stuff out and fresh stuff in.
    Akirakodi[OP] likes this.
  3. May 19, 2015 at 9:13 PM
    Akirakodi
    Thanks for the response. I'm not sure yet, I was told by express oil change manager that they couldn't do it and that I should take it to a transmission shop or Toyota. He said DIY would be a major pain. Is this true?
    If it's not much more difficult than a regular oil change I'd like to do it myself.
  4. May 19, 2015 at 9:17 PM
    Akirakodi
    Thanks. I was told by the transmission shop over the phone, that at 173k they don't recommend changing it unless there's a problem. He did say if it was at 100k, It'd probably be safe to change it.
  5. May 19, 2015 at 9:22 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    umm what? that makes no sense.
    at 173k on original trans fluid.... id be inclined to drop the pan, replace the screen / filter (pretty sure the 5 speed auto has one) then fill her back up with all fresh fluid.
    Akirakodi[QUOTED][OP] likes this.
  6. May 19, 2015 at 9:48 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    Not a tranny expert but my experience with 2 different ford's is do the tranny flush at high mileage after never being done before or doing after alot of miles and both tranny blew up within a month later so what I've figured is if it ain't broken don't fix it
  7. May 19, 2015 at 10:08 PM
    Akirakodi
    Thanks for all the replies. This thread illustrates my dilemma very well. There are some seriously conflicting opinions on what to do in this situation. Keep it coming maybe we can come to a majority consensus.
  8. May 19, 2015 at 10:09 PM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Set up a poll for completely flush, slowly change fluid, or leave it alone see what you come up with
  9. May 20, 2015 at 2:26 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I've read 100's of these threads - drain & fill - DON'T flush.
    xcentrk and Akirakodi[OP] like this.
  10. May 20, 2015 at 2:35 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    I have heard these stories. If it were mine I would leave it alone..
  11. May 20, 2015 at 3:17 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Some are saying to drain and fill it. The problem is that most the oil, about two thirds, is in the converter and inside the valves so you are just adding a small amount of new oil to old oil. All you would get out of it would be what is laying in the pan. It would be like draining your motor oil and putting in two quarts of new oil and filling it the rest of the way with the old oil.
    My advice is to leave it alone. As someone said if it ain't broke don't fix it.
  12. May 20, 2015 at 4:58 AM
    gearcruncher
    Canadain bumper technician
    A proper Hot / Cold test drive with a professional scanner at a reputable transmission shop .
    Remove the transmission pan and inspect the debris on the magnets in the bottom of the pan .
    Remove the screen style filter and inspect for particulates .
    Determine what to do once the above has been performed .
    Doesnt matter if the truck is new or has a million miles . This is the " ONLY " way to properly determine the condition of the transmission
  13. May 20, 2015 at 5:55 AM
    Pigpen
    Dan
    Northwest Montana
    this
  14. May 20, 2015 at 6:19 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Frankly I would leave it alone with that kind of mileage I have seen too many that stopped moving a couple of weeks after a change with high mileage. The new fluid will take the deposits off the frictions that has built up and probably lead to clutch failure. If it works fine don't "fix" it.
  15. May 20, 2015 at 7:14 AM
    Akirakodi
    Thanks for all the replies. The truck drives fine, but like I stated it does shift "strong" (for lack of a better term) from 1st to second at times. It doesn't seem like anything is wrong, I just want to do what's best for prolonging the life of the vehicle. Seems like I'll be leaving it alone or proceeding only with a professional diagnosis. Any experience with AAMCO or Mr Transmission type shops? Would Toyota dealer be better?
  16. May 20, 2015 at 8:47 AM
    HAVVOKK
    2014 DGAF Long Bed
    Fucking look it up
    Don't go to aamco took my truck there because it was slipping from 3rd to 4th gear got my truck back from them and couldn't go more than 30 mph it wouldn't shift to 3rd gear anymore I limped it home and bought a junk yard tranny and installed myself fuck aamco
  17. May 20, 2015 at 9:46 AM
    savedone
    Gerald
    Texas
    Like stated above. If it ain't broke don't fix it. No need for paying someone to look at something that is not broke. If it shifts "strong" that is a benefit because most of Toyota's automatics shift too soft and that causes clutch wear. At 173K it means on average you only have about 75,000 miles until it needs rebuilt anyway. Just drive it and enjoy.
  18. May 20, 2015 at 9:53 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Follow gearcrunchers advise. He is in the transmission business.
    Also...note the comment(s) about AAMCO transmission. Avoid any and every AAMCO transmission shop.
  19. May 20, 2015 at 10:04 AM
    Old School
    Old School You are ignoring covfefe by this member.
    Like these 2 posts say, do not flush!
    I had problems start after a flush, higher mileage Tacoma.
    Listen to gc, he knows!
    AAMCO, hell no!
    Worked at one for a half a day, loaded my tools and left!
    When I was young, had a AAMCO diagnose my '72 GMC, they said TH350 trans in it, rip offs, it had a TH400!
    Guarantee the 400 wasn't going back in...
  20. May 20, 2015 at 11:13 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Get new fluid in the transmission, make sure its at proper level. this is not an Ford its not going to blow up with new fluid.
