Advice needed on Wheel bearing replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vram74, Jan 11, 2016.
  1. Jan 11, 2016 at 6:18 PM
    vram74
    vram74 [OP] Well-Known Member
    05 Prerunner SR5
    I think my 05 PreRunner w/117k needs new front wheel bearings. I've got a consistent roar/grinding noise in the front end that changes sound/pitch when I turn the wheel or change speed. You can put it in neutral and take your foot off gas and still hear it. Would anything else cause this noise?
    Called 1 local shop and the dealership. Local shop said they said that if the hub is fine, they could replace both front bearings for around $700. Dealership wants around $870 for the pair. I don't know anything about the local shop other than word of mouth (Foothills Imports), so I'm a bit hesitant to mess with another independent shop. Log story short, I haven't had much luck with anyone but the dealership. So hard to find a qualified, trustworthy mechanic where I live.
  2. Jan 11, 2016 at 8:46 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Consult @BamaToy1997
    He makes hubs and can help diagnose and guide your fix.
    DoorDing, TacoTaco15 and BamaToy1997 like this.
  3. Jan 11, 2016 at 9:38 PM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Your symptoms are definitely those of wheel bearings. If you're mechanically inclined at all, do it yourself and save yourself a ton of cash.
    If you do decide to do them yourself, do as Ed suggested and buy the completed assemblies(hub and bearing) from Bamatoy. I did mine a few years ago before anyone was selling them as whole assemblies, so I had to do all the assembly work myself, and the assemblies that he sells make replacing them pretty easy.
  4. Jan 11, 2016 at 9:39 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Check the brake system. Look at the anti-wear indicators on the brake pads. Also, the shims on back of the pads can break off and fall down where they rub on the rotor; this is not a common occurrence, but it has happened. The point is to rule out the brake system as the noise maker. If all looks good, it's likely one or both wheel bearings.
    Best way to check bearings is to remove the brake pads, use 2 or 3 nuts to tighten the rotor in place, and free-spin the rotor. It should spin smoothly. Next, grab the rotor on the sides and move fore and aft gently; there should be no looseness. If you move too hard, you will get movement from the tie rod ends flexing.
  5. Jan 12, 2016 at 9:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    Thanks for the great words everyone! Yes, @vram74, it does sound like a high possibility of wheel bearings. A simple check is to lift the front end of the truck and spin the wheels by hand. If the noise you are describing is as bad as you as indicating, then you should feel one, or both, having a rough spin, and some noise evident. It should spin freely, and smoothly. Also you can grab the wheel at 12 and 6 with the truck lifted and it should NOT move any when you rock it back and forth. If the wheel and hub move, you have bad wheel bearings. My 4WD units come preassembled with all new parts, and if you check I have great customer service, and a great price. $175 each, including shipping.
    http://www.marionbumper2bumper.com
    TacoTaco15 likes this.
  6. Jan 12, 2016 at 11:38 AM
    vram74
    05 Prerunner SR5
    Mine is a 2wd prerunner. Those were $275 each, correct? Given your rep here, I'm sure yours are much better quality, but I don't have the skills or space to do the work myself and hesitant to bring my own parts to the shop. I don't want to get into a situation where something isn't done right and the shop starts blaming it on parts I brought.
  7. Jan 12, 2016 at 3:29 PM
    jerzeyjoe
    jerzeyjoe Well-Known Member
    New Jersey
    08 Prerunner 2W
    It's very easy to do. I'm sure for a 6 pack, someone here will help you out. Where are you from?
  8. Jan 12, 2016 at 5:38 PM
    vram74
    05 Prerunner SR5
    SC. :)
    Sorry for taking so long to get back. My neighbor is going to come down tomorrow or Thursday and fix it for me in exchange for fixing his PC. Nothing good will come of me touching it except a shit load of screws everywhere and a bewildered WTF face.
    Hopefully the weather cooperates!
  9. Jan 13, 2016 at 7:29 AM
    LnL
    LnL Active Member
    Lee
    Seabrook, TX
    I bought two bearing assemblies and inner seals from you last year. I read some of the threads on how other people have replaced their bearings. I knocked out job on my own rather quickly and easily!
    Turned out that I only had one hub/bearing that was bad, so now I have a spare. I've put probably 12,000 miles on it since then, and no problems at all.
    BamaToy1997[QUOTED] likes this.
  10. Jan 14, 2016 at 1:23 AM
    Chuy
    Lakeside, CA
    Silver Taco
    There are some youtube videos that can help out. The non-4X4 versions of the 4Runner and FJ are just as useful.
    BamaToy1997 likes this.
  11. Jan 14, 2016 at 8:13 AM
    BamaToy1997
    Bill
    Navarre, FL
    The 1st 30 seconds of this video show you how to remove the original 2WD hub assembly. Then you just go in reverse to install my new unit. In the video at the 20+ second mark you will see the tech install a slide hammer to pop the old assembly loose from the truck. You don't have to have a slide hammer, and if you don't, simply use a hammer and a screwdriver, and carefully drive the screwdriver in between the back of the hub (at the flange behind where the bolts pass through) and the dust shield. Drive in a little at a time, moving to all 4 sides, and it will come out.
  12. Jan 14, 2016 at 10:24 AM
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
    @BamaToy1997 Im trying to figure out whats going on with my front driver side wheel. It was thrown out it might be the wheel bearing.
    Im getting small click while turning. When making a turn around a corner the wheel kinda locks into the turn and I need to help it come back to straight. When I hit bumps in the road it feels like the wheel is loose and almost wants to fall off. First I thought it was my uca loosely connected to the spindle but I checked that and its tight. I checked the coil over bolts aswell which are all tight aswell. I dont really know where else to look. Any help would be appreciated
  13. Jan 14, 2016 at 11:12 AM
    BamaToy1997
    Bill
    Navarre, FL
    If you lift the truck up off the front wheels you can wiggle the tire at the 12 and 6, then again at the 3 and 9 positions. Check for abnormal movement in either position. Movement at 3 and 9 can bee steering components (tie rods, rack, rack bushings, etc) and movement at 12 and 6 can be upper ball joint and upper control arm issues, as well as wheel bearings. Wheel bearings will show up as movement at the hub/rotor area. To check the lower ball joint you have to unload the ball joint by using a jack underneath the lower control arm. This takes the force-load off the lower ball joint so that you can check for abnormal movement there.
    snowtank likes this.
  14. Jan 14, 2016 at 11:26 AM
    snowtank
    Andrew
    Arizona
    Great thanks. I will check tonight.
  15. Jan 14, 2016 at 3:05 PM
    vram74
    05 Prerunner SR5
    Thanks for all the info guys :)
  16. Feb 11, 2016 at 5:52 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    is this a 4x4?
  17. Feb 11, 2016 at 6:26 PM
    snowtank
    Andrew
    Arizona
    Yep .
  18. Feb 11, 2016 at 6:33 PM
    wilcam47
    Will
    Bourbon state
    cv axles start to click when they are going/wearing out, wheel bearings would make the roaring sound. I need to do both on my 2000 Tacoma.
  19. Feb 11, 2016 at 6:42 PM
    snowtank
    Andrew
    Arizona
    It was actually all suspension. Figured it out once I got the tire off and pulled the coil over.
  20. Feb 11, 2016 at 6:48 PM
    wilcam47
    Will
    Bourbon state
    good to know...but in my case I think its cv axles and bearings.
