Advice Needed: Portable Power Station & Diesel Heater
Discussion in 'Technical Chat' started by Chukar_hunter, Sep 7, 2022.
  1. Jun 25, 2023 at 10:27 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    How are you connecting the heater to the powerstation?
    What is the max draw of the diesel heater? Your Delta can handle up to 1800W.
  2. Jun 25, 2023 at 10:43 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    OP is probably not running a heater these days but 12v diesel heaters only run an average of 2amps (24watts) between startup and running (8amps to start, then 0.5 while running)
  3. Jun 25, 2023 at 11:32 PM
    Area51Runner
    Thanks, I was actually quoting @21TacoTRDPRO not the OP. He mentioned his Delta wasn't able to run his diesel heater so I was trying to help him out as his Delta should have no issues running it.
  4. Jun 26, 2023 at 8:03 AM
    21TacoTRDPRO
    21TacoTRDPRO Follow my IG @21toyoduh
    ordnaS
    SoCal
    21 Tacoma TRD PRO
    Exterior Gears: 5.29 revolution Lift: @Wescottdesigns UCA: @jbaoffroad Leaf springs: @ivdsuspension Wheels: @stealth_custom_series Tires: @yokohamatire Yoko MT Front Bumper @drtfabrication Rear bumper @outgearsolutions HC with tire carrier Roof rack: @Prinsudesingstudio w/2 Load panels 44" light bar Rock Sliders: @rcioffroad 20 BYND 4X4 tactical camper Bed stiffeners:@ChassisUnlimited @cali_raised_led P/S molle panels and Ditch light brackets Sequential led side mirror turn: @MesoCustoms Cat shields: @cali_raised_led Oil: @FUMOTO oil drain valve AC mod Rear Differential Breather: routed to fuel door CMC: @ironrynofabrication Fender Flare Trim: @21toyoduh Rock lights: @RoughCountry Hood scoop 12" LED amber / white + strove light bar Tailgate power lock/unlock: @toyotausa Hood Struts: @redlinetunninginc Rear recovery points: @nytop.store Rear sway bar: @progressgroupinc Tire carrier: Fishbone Offroad Interior Power Switch: @switch.pros.official Power tray: @powertrays @ragofabrication Center Console molle panels /bridge & wifey mount Footwell lights: @VLEDS front /rear + sunvisor vanity lights @Weathertec floor liners, in-channel guards, hood guard @DongarTechnologies rear view mirror USB @AJTDesign minimalist key fobs On board Air: @viaircorp 400P Wifey Air System CMD Center: @expeditionessentials @3TPAM 4x @RAMmounts GMARS: @MidlandUSA MXT275 GPS/Safety: @Garmin Overlander, Garmin Montana 700i
    I actually got it to work. What I found out is that the cigarette lighter Adapter which has a 30 amp fuse also has a glass tube fuse. That fuse kept popping out so I replaced it with a 30 amp bussman fuse and it's working great
    Area51Runner[QUOTED] likes this.
