Advice needed... raptor lights on a 2016
Discussion in '3rd Gen. Tacomas (2016+)' started by jeffreydepp, Mar 22, 2016.
  1. Mar 22, 2016 at 7:09 AM
    jeffreydepp
    jeffreydepp [OP] Well-Known Member
    Jeff
    Cleveland, Ohio
    2016 TRD Sport Tacoma
    Does anyone know about where to do the wiring to add some led bolts to my new mesh grille. I would love to plug into my daytime running lights. Anyone know a guide or pdf to show me what and where to plug these led bots into? Thanks
  2. Mar 22, 2016 at 10:03 AM
    Dean724
    Dean724 Well-Known Member
    Upland, CA
    As for tapping into your daytime running lights, can't help you there no would I recommend tapping into your factory electrical system while under warranty. The slightest thing goes wrong and you'll have a fight on your hand with Toyota for any electrical warranty work and there have been some quirky issues folks have had with lighting on Tacomas.
    For any aftermarket lighting, you'll need a Power Switch & Relay wiring harness kit. You can buy them on ebay cheap and they all work the same. Do not wire the lights up directly to your battery without a relay/fuse system no matter how small. Directions are pretty straight forward.
    $10 8ft 40A Power Switch & Relay Wiring Harness Kit 12V for LED Light Bar Offroadhttp://www.ebay.com/itm/8ft-40A-12V...ash=item3aab039e77:g:PEIAAOSwYGFUuVzy&vxp=mtr
  3. Mar 22, 2016 at 10:10 AM
    JdevTac
    JdevTac Negative Ghostrider
    Josh
    GA
    2013 DC TRD-OR 4x4 Pyrite Mica
    The relay harness is great for aftermarket lighting but completely overkill if the OP just wants to wire up a couple small individual LEDS to mimic Raptor grill lights. Which was my interpretation of the goal here.
  4. Mar 22, 2016 at 10:25 AM
    jeffreydepp
    Jeff
    Cleveland, Ohio
    Correct... I dont need a switch or anything fancy? Just want my 4 little LEDs to lightup and match when the daytime running leds are on and when I turn my main lights on at night...
  5. Mar 22, 2016 at 10:37 AM
    Dean724
    Upland, CA
    I didn't know $10 relays for aftermarket LEDs were fancy on a $35k truck. Good luck on your "raptor" lights..
  6. Mar 22, 2016 at 10:43 AM
    breader3
    breader3 2016 TRD Off-Road 4x4
    Brad
    Las Vegas
    I was looking into doing the same.
    My thoughts were to tap into either the corner lights, or the fog lights. (Which would give me some control).
    But with my current fiasco of ruining my dome lights in now a little hesitant.
    Let me know what you decide to do
  7. Mar 22, 2016 at 11:36 AM
    JdevTac
    Josh
    GA
    If I had a 3rd gen I'd probably be more helpful but go check out the thread on "raptor grill lights" or whatever the title is, should give you some ideas on how to do it. The thread is on 1st/2nd gens but the process should be the same if you can locate the correct wires to tap.
    You "could" go overkill/fancy and do the whole relay thing but it's not necessary.
    And I've heard of all the crap that goes south with the interior swaps, so it'd make me more leary of tapping into circuits too.
