Advice Needed Re: Toytec
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ohanyan1, Apr 26, 2009.
  1. Apr 26, 2009 at 9:31 AM
    ohanyan1
    ohanyan1 [OP] New Member
    West Michigan
    07 TRD Double Cab 4x4
    I have an 07 DC that I want to put a 3" Toytec lift on.
    There are 2 large four wheel drive shops in my area and both of them will not put on 3" lifts. They tell me that 3" lifts are terrible for driveline components and will cause premature driveline failure.
    Both of these shops will only do 2" spacers or I have to go all the way up to a full 6" lift.
    My question is, are they correct?
    If they are not correct, and I ordered a 3" Toytec lift, how would I go about getting it installed? Will any local mechanic shop be able to do this?
    Please help!!
  2. Apr 26, 2009 at 9:33 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    No, 3" coilovers will greatly out perform spacers. If you install the diff drop as well you will be equal to if not better than stock
  3. Apr 26, 2009 at 9:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! If you are halfway handy with some basic tools, you can do the install your self. Also, Check and see if there are some members in your area that can lend a hand. Many shops will only put spacers on because they are idiots.
  4. Apr 26, 2009 at 9:45 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    x2 ^^^ :D
  5. Apr 26, 2009 at 1:32 PM
    ohanyan1
    West Michigan
    I appreciate the responses.
    I think I am going to call Toytec tomorrow and see what they recommend.
    Also, with this type of lift, do I also need to swap out the UCA's?
    What is reccommended?
    Thanks!
  6. Apr 26, 2009 at 1:38 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It is recommended you get some aftermarket UCAs- Better travel proper alignment and general badass-ness factor. But it is NOT required.
    Welcome to the board and good on yo for not taking what the shop said and going on that...
  7. Apr 26, 2009 at 1:44 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Yeah what they said, WELCOMEE!
  8. Apr 26, 2009 at 3:47 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Find a new shop and do what I did. GO WITH TOYTEC. I love everything about mine, especially the ride.
  9. Apr 26, 2009 at 3:53 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Love my toytec 3" . Oh and I have stock control arms.
