Advice needed. Vibration when turning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco06, May 3, 2022.
  1. May 19, 2022 at 6:16 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yeah thats a bit odd only getting the vibes in neutral and turning.. Based on your first post I tend to think drivetrain, and maybe the turning part is a just a coincidence. Low hanging fruit in the drivetrain would be carrier bearing and u-joints. Give all 3 rear u-joints a good shot of grease until you see it start to leak out. If that helps, probably your issue. If thats not it a carrier bearing is only ~$70-80 and may need to be replaced if its original.
    The turning part makes me think front wheel bearing, although from what I have read on here thats usually more of a noise and less of a feeling. Also (again based on what I read here) front wheel bearings in these trucks can be shot but still pass the push/pull test, so keep that in mind.
  2. May 19, 2022 at 7:40 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    That’s why I was thinking it’s not driveshaft related
  3. May 19, 2022 at 7:41 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    FWIW my carrier bearing has play and has 125,000+ miles on it and no issues
  4. May 24, 2022 at 3:07 PM
    taco06
    taco06 [OP] Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    How much would you say you can move it? I haven't been around another truck to check
  5. May 26, 2022 at 8:08 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Shoot I would guess 1/2” but I can get under there this weekend and give a better answer if you need me to. 1/2” total play meaning like 1/4” forward or 1/4” back if that makes sense
