Advice needed wiring LED light bar
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GuyGadois, Jan 20, 2017.
  1. Jan 23, 2017 at 9:05 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    The 7.5 amp fuse goes at the bottom of the stack to protect that factory circuit.
    SB
    Kremtok likes this.
  2. Feb 9, 2017 at 5:54 PM
    Gnarman
    Gnarman Well-Known Member
    Southwest
    2016 dbcb trd off road quicksand lb
    ARB Shell, BP51, 255/85/16 ST MAXX, SCS Ray 10 Matte Bronze, Caliraised led 32 inch/side shooter/amber pods, floor mats, start x remote start, auxbeam 8 gang switch panel, diode dynamics hid lows, Australian Shepherd
    What size add a fuse do you need to run?
  3. Feb 9, 2017 at 5:56 PM
    Sagebrush
    Gens 1, 2, 3, and 4
  4. Feb 9, 2017 at 5:58 PM
    Gnarman
    Southwest
    @Sagebrush gotcha and then would I just use the tail slot and use a 20 amp one if I want to piggy back two switches off of it?
  5. Feb 9, 2017 at 6:04 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    I'm not sure what you mean by this?
    SB
  6. Feb 9, 2017 at 6:20 PM
    Gnarman
    Southwest
    Sorry I mean use the same add a fuse to power two switches
  7. Feb 9, 2017 at 6:24 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    Two switches to the same bar? Yes, as long as you're running the bar's power through a relay switch.
    SB
  8. Feb 9, 2017 at 6:29 PM
    Gnarman
    Southwest
    @Sagebrush sorry I mean using the two switches grabbing powered from the same add a fuse to power ditch lights and their own relay and another switch with abbar and its own relay
  9. Feb 9, 2017 at 6:30 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    I think that would be fine. A relay only takes about .1 of an amp.
    SB
  10. Nov 21, 2017 at 12:13 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I got a follow up question to this. What's everyone using for their dimmed contact on the switches? So that they dim when the dash lights dim? Also, is there a main ground under the driver's dash? Or just pick an arbitrary ground on the metal frame under the steering column?
  11. Nov 21, 2017 at 5:00 PM
    Sagebrush
    Gens 1, 2, 3, and 4
    Run your ground to the tan wire behind your cargo light switch. Connect the hot wire to the green wire there. Oddly it's the ground that controls the dimmer.
    SB
  12. Nov 23, 2017 at 11:51 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    So can the rest of the switches (2 more in my case) be Daisy chained off that ground / hot from the cargo light? That leaves just two wires per switch running through the firewall right? One for the fused hot and on to the relay? Or can that fused hot be Daisy chained as well?
  13. Nov 23, 2017 at 11:54 AM
    Sagebrush
    Gens 1, 2, 3, and 4
    I don't know about adding more switches that run relays to this circuit. I suppose it depends on how many amps the relays draw.
    And yes, two wires per switch through the firewall. Assuming I understand the question.
    SB
  14. Dec 15, 2017 at 6:01 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    @Sagebrush you seem a bit more electrically incline than I, so I had a quick question. So I plan on running all my dimmed circuits Daisy chained from the bed lights (4 total). Then add a fuse will power a front facing camera, and 2 relays. That leaves just one wire leaving each switch as the trigger wire for relays. See anything wrong w that?
  15. Dec 15, 2017 at 8:06 AM
    #35
    Sagebrush
    Gens 1, 2, 3, and 4
    In full disclosure, I don't understand how the dimming circuit works since it's controlled by the negative side. It makes no sense to me. I don't know if there are lots of dimming circuits or just one...
    I think it might work. That's assuming you are using relay switches. You'll know if it doesn't blow a fuse somewhere. If it does, scrap the idea. Don't try fixing it by adding a higher amp fuse.
    SB
