Advice needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by Assforkr, Jan 15, 2016.
  1. Jan 15, 2016 at 8:26 AM
    Assforkr
    Assforkr [OP] Well-Known Member
    MA
    03 taco
    Just finished welding up and installing the relentless bumper and the nose on my 03 4x4 v6 with stock shocks is diving in the turns. Want to upgrade the front springs and shocks but the plan for the rear end is messing me up
    Idea is
    Front: 5100s with 883s to handle 75lbs of extra bumper. Adjustable later on if I decide to lift.
    Rear: 5100s in the rear to replace aged bilsteins. My frame got swapped a year ago so I think my leafs are ok but the 5100s are supposed to not work with stock height. So do I go AAL and keep things cheap or go with General HD leafs and gain an inch or so and more weight capacity.
    I don't really offroad so I don't need a massive set up and the the 265/75/16s on the truck look soooooo good at current height that I don't want lift, just less rake than when I make turns with the cow catcher up front.
    Feel free to make any suggestions on tweaks etc. Thanks for looking.
  2. Jan 15, 2016 at 8:46 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    do you plan on running skids or a winch? maybe consider the 882 coils with the nitro ome shocks, i hate 5100s but thats just my experience.
  3. Jan 15, 2016 at 8:53 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If you don't want lift you don't want 882 or 883 coils. Get 881s.
  4. Jan 15, 2016 at 9:05 AM
    Assforkr
    MA
    03 taco
    Definitely no winch. If I wanted to eventually do a lift I would likely go no higher than 2". Though I really do love the look now.
    Regarding additional weight, my rear bumper is rotted through and I'll likely weld up steel a steel tubing bumper to replace it.
    Regarding ride quality, I'm looking to reduce body roll and keep the nose from diving due to extra weight.
  5. Jan 15, 2016 at 9:07 AM
    Assforkr
    MA
    03 taco
    Even with the weight of the bumper(s)? I put it on last night and the weight is very noticeable in the turns. The rear leafs look like they were replaced with the frame but the front and rear shocks and coils do not look new. 113k on the clock.
  6. Jan 15, 2016 at 12:50 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea if you don't want lift, the 881s are what you want. They give about 1.5-1.75'' of lift on a stock truck. So should be fine with the bumper.
    the 883 will give you almost 3'' of lift even with the bumper. Settle to 2.5'' or so. So you'd have to lift the back too.
  7. Jan 15, 2016 at 2:34 PM
    Assforkr
    MA
    03 taco
    Gotcha! Would the ride be firmer with the 881s and the bumper or equivalent to stock after the extra weight?
    Second quandry, every site states that the rear 5100s are sized for a minimum 1.5" lift and everyone hates on the stock leafs. For road travel the general HDs look like my best option with minimum to no lift and no axle wrap. Any other suggestions to keep the height and match the 881s or 882s?
  8. Jan 16, 2016 at 8:48 AM
    Assforkr
    MA
    03 taco
    Gentlemen, I know you're all covered in grease changing shackles and shit but me and my taco are all sad and shock-less. Please help a taco in need!
  9. Jan 16, 2016 at 7:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    It'll probably be close to stock. Not very stiff anyways. The shock valving has more to do with that though.
    You can get 5125s that are made for OEM applications. As in no lift.
  10. Jan 30, 2016 at 4:54 AM
    Assforkr
    MA
    03 taco
    Finished install of 881s and 5100s front and rear last night. Front went from 35 1/4 to 39!!! Sitting a little higher in the front than the rear now and desperately hoping they seat themselves and "settle." Not looking to do leafs until next year or so.
    Sitting here now getting it aligned. Do you guys get he trucks realigned again after a couple of hundred miles?
  11. Jan 30, 2016 at 6:23 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Did ou move the retainer ring on the the 5100 downtown the lowest setting? It sounds like the coils are precompressed. That is way too high for 881s
    Get an alignment ASAP. Or your tires will be destroyed.
    They will settle.
  12. Jan 30, 2016 at 1:17 PM
    Assforkr
    MA
    03 taco
    Lowest. Had them pre-assembled by wheelers. Measurement was taken with zero miles on the springs so maybe I'll measure again and see if there's any movement after 200 miles. Truck has 113k on the clock so the fronts may have been shot. I can definitely tell the dampening is monumentally better now when I slam through pitted roads.
    May have some new front end clunk to investigate. Any ideas?
  13. Jan 30, 2016 at 6:55 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Haha then your stock suspension was just so clapped out it is just higher then normal. Should settle after some abuse.
  14. Jan 30, 2016 at 8:03 PM
    Assforkr
    MA
    03 taco
    Quite likely. I know the rears we're rusted and the upper belows was misaligned and slamming into the oil reservoir, so I'm glad I installed the lot. May have also tracked down the clunk. The plate bumper sounds like it's pinning the underside of the grille or rubbing on the front sheet metal. Guess I'll see tomorrow during the skid weld sessions. Anyways thanks Blackdawg.
    Blackdawg[QUOTED] likes this.
  15. Feb 1, 2016 at 6:07 AM
    Assforkr
    MA
    03 taco
    37 7/8ths after 200 miles. Rears still 1.5" lower.
    More useless updates coming up in the future.
  16. Feb 1, 2016 at 6:15 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Not useless information at all. It will be interesting to see how long it takes to settle (or at least the initial significant settlement)
  17. Feb 1, 2016 at 9:22 AM
    Assforkr
    MA
    03 taco
    Thanks. Also clunk corrected. Relentless bumper needed to be shimmed away from the fender.
  18. Feb 1, 2016 at 10:51 AM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    Keep the updates coming! I'll be in the same boat of picking new front and rear shocks and springs soon. This thread is a help
    Assforkr[OP] likes this.
  19. Feb 1, 2016 at 12:27 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    good thing you didn't get 882/883s..be at least an inch higher haha
  20. Feb 1, 2016 at 7:22 PM
    Assforkr
    MA
    03 taco
    Truth. If there's anything to gather from this thread it's that unless you have a winch and an ARB kangaroo murdering cow catcher bumper you should not exceed the 881 coils. The ride hasn't become cush by any measure of the imagination, so more preload on the beefier 82-83- eibach coil reduces from the positive effect of the new parts
