Advice on 2012 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by windyb, Nov 23, 2021.
  1. Nov 23, 2021 at 7:33 PM
    windyb
    windyb [OP] New Member
    Hey All,
    New here, was wondering if there is anything I should specifically look out for on a truck I'm going to look at tomorrow.
    Its a 2012 TRD Double Cab, Manual, 134k KMs. Have looked around here/elsewhere and nothing has jumped out, but thought I would ask the experts.
    Thanks!!
  2. Nov 23, 2021 at 7:35 PM
    Bishop84
    Bishop84 Well-Known Member
    2012's specifically have issues with air pumps, inquire if they've completed the recall or had any issues with it.
    Otherwise, check for frame rot. Surface rust is ok.
    2012 is likely 15,000$++ so get an inspection done on it for sure.
    Dm93, TnShooter and tcjacado like this.
  3. Nov 23, 2021 at 8:31 PM
    windyb
    Great thanks. Have been reading up on the air pump issue. The truck is at a dealer, I'm not sure what info they will have on it from whoever traded it in. Any advice on whether a PPI would be better done through an indy or at the Toyota dealer next door (the truck is at a separate dealer next door).
  4. Nov 23, 2021 at 8:33 PM
    Bishop84
    When in doubt go by google reviews and pick the best of the two. PPI is a bit of a hose job depending on where you get it done
  5. Nov 23, 2021 at 8:36 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If it's a 4wd make sure the 4wd system works like it's supposed to.
  6. Nov 23, 2021 at 8:48 PM
    goonsquad08
    goonsquad08 Well-Known Member
    Michigan
    ‘12 DCLB Tacoma
    Bought my 2012 four years ago from a Toyota dealer.
    Mine didn’t have rear headrests. Assuming previous owner took them off to fold rear seats down and forgot about them.
    20 miles into the trip home, tpms lights came on. Called them and they said it was normal and would go away since it was flashing. Never went away. Came from out of state so didn’t bother going back.
    Had the air pump issue last year. Local dealer resolved/replaced it in a couple days.
    I’ve enjoyed mine. Less miles.
  7. Nov 23, 2021 at 8:51 PM
    goonsquad08
    Michigan
    ‘12 DCLB Tacoma
    Would also try to give brakes a quick look if able and tires.
    assuming you’ll look under at the frame as well. I still have a couple years before the extended frame warranty expires (2012 as well, believe it was 12 years from first registered date). Can check my papers when I’m home.
  8. Nov 23, 2021 at 8:54 PM
    windyb
    Thanks for the replies.
    Im assuming for the air pump there isn't anything you can visually inspect to tell if its been addressed? Is it an ongoing thing, or once it becomes an issue there is a more permanent fix for it now?
    Also, for the frame, and specifics spots/issues to keep an eye out for? Or just severe rust?
    Thanks again for the responses!
  9. Nov 23, 2021 at 8:57 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
  10. Nov 23, 2021 at 8:58 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Where are you from? Rust can be a non issue or a major issue depending on what part of the country the truck lived in.
  11. Nov 23, 2021 at 9:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    MNMLST[QUOTED] likes this.
  12. Nov 23, 2021 at 9:14 PM
    windyb
    Located in Alberta, Canada. It's dry, but lots of snow.
    Thanks again for the other replies, I'll probably ask for a PPI at the Toyota dealer next door, assuming everything else checks out.
  13. Nov 23, 2021 at 9:15 PM
    MNMLST
    Earth
    and…
    check the carrier bearing ‘freeplay’.
  14. Nov 24, 2021 at 10:15 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    check is 4x4 works, if it is a 4x4.
    4x4, 4LO, diff lock. etc.
    check oil fill cap to make sure it doenst look like a milkshake (head gasket)
  15. Nov 24, 2021 at 10:47 AM
    Sharpish
    Brian
    Oil fill cap will always have a creamy film from condensation. 2012 don’t have head gasket issues.
  16. Nov 24, 2021 at 1:00 PM
    goonsquad08
    Michigan
    ‘12 DCLB Tacoma
    my 2012 usually has a bit of cream color on oil cap. Has been since I’ve bought it. More so on short trips, longer drives it’s less noticeable. Have been using full synthetic oil and no issues.
    Had me worried when I first noticed it
  17. Nov 24, 2021 at 5:56 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Why is that? Is the 2012 more prone to this? Going through that right now, even though the carrier bearing was replaced as part of safety last year before I bought it.
  18. Nov 24, 2021 at 5:59 PM
    MNMLST
    Earth
    They sometimes wear out ‘prematurely’… can lead to other drive train troubles if they’ve been wobbling around, unaddressed.
    Marc70[QUOTED] likes this.
  19. Nov 26, 2021 at 7:29 AM
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    No problem with my air pump at 146k miles yet. Milkshake was eliminated after I got my oil separator installed.
