Advice on a lift.
Discussion in 'Suspension' started by deer slayer 11, Jan 4, 2010.
  1. Jan 4, 2010 at 9:01 AM
    deer slayer 11
    deer slayer 11 [OP] Well-Known Member
    jay
    st.louis mo
    tacomo
    Let me start by saying thanks for all the great threads on tw. I have learned a ton of information on here. I am a newbie. I just got my first Tacoma 5 mo ago and I love it. So since I have seen all the AWESOME pic the mod bug has bitten. I have A 07 Pre-runner 2wd 4.0 double cab and I want to do a 3 in lift. I am thinking of doing the OME suspension lift kit from toytec with 885 coils , top plate spacers and aal in the rear. I will also installing a tc uca because I want to do it right. So my question, Is this all I need. Will I need new brake lines,will my abs be ok,Am I going to have vibration in my drive shaft and if I go from a 265-65-17 OEM to a 285-70-17 do I need to re gear. I don't need to burn rubber but I don't want a turd either. I would rather go with a smaller tire than re gear. Any information would be great.:D Thanks!
  2. Jan 4, 2010 at 9:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You shouldnt need to regear. THough, Thats more of a personal decision. Brake lines will be fine, and as long as its installed propperly, you shouldnt have any vibes.
  3. Jan 4, 2010 at 9:11 AM
    deer slayer 11
    jay
    st.louis mo
    tacomo
    :)Thanks for the help. I will get pic up when I in stall it. should be march, April. waiting on tax return.
  4. Jan 4, 2010 at 9:23 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I pretty much have that lift you want with the 885's, rear AAL's, TC UCA's, but I also swapped out all my shocks with 5100's. You should be able to run those tires just fine but you might need wheel spacers, that I'm not positive of. You will also need to do some minor trimming on the front fender wells. I did not need new brake lines on mine and did not re-gear.
  5. Jan 4, 2010 at 9:38 AM
    deer slayer 11
    jay
    st.louis mo
    tacomo
    So can I do and this I would rather have 5100.[​IMG]
  6. Jan 4, 2010 at 9:42 AM
    deer slayer 11
    jay
    st.louis mo
    tacomo
    And I will get new rimes with a positive backspacing. So no spacers right?
  7. Jan 4, 2010 at 9:49 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah that will work. Thats is the setup I am running.;) I have a -12mm offset. I think that equals to like a 4.5" backspacing. But I am running 285/65-18"s instead.:cool:
  8. Jan 4, 2010 at 10:00 AM
    deer slayer 11
    jay
    st.louis mo
    tacomo
    Cool. I will do the 5100. Thanks for the info. I cant wait to get it done as soon as the weather warms up. 9 degrease to day. to cold to get started.:lalala:
  9. Jan 4, 2010 at 10:05 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I hear yah!! Well make sure when you install the front coils and 5100's that you leave the shock setting a 0" height. The coils provide the lift.;)
  10. Jan 4, 2010 at 10:09 AM
    deer slayer 11
    jay
    st.louis mo
    tacomo
