Advice on attaching box to bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stormyday, Mar 26, 2009.
  1. Mar 26, 2009 at 4:44 PM
    stormyday
    stormyday [OP] Well-Known Member
    Morganton, NC
    14 Taco Double Cab Pre-Runner
    I have a 09 Access Cab. I am trying to figure out how to install a Pro Tuff Bin in the bed. I want it against the cab. Right now I have a bolt that goes through the box and bed and then I use 2 toilet anchors to attach it to the bed rail.
    This install is ok, but it is a pain to get under the truck to but the bolt in. Does anyone have an suggestions on how else to attach it? I want to be able to put it in and take it out easily.
    It looks like: 020027003402.jpg
  2. Mar 26, 2009 at 5:12 PM
    Brunes
    Brunes abides.
    Rotorhead
  3. Mar 26, 2009 at 5:49 PM
    stormyday
    Morganton, NC
    I am wanting something that is somewhat secure with all of the attachment being hard to get to without getting into the box. My ideal way would be something that attaches to the bed rail (the toilet bolts do not work too well) and a threaded place in the bed to run one or two bolts through. When I remove the box, I want there to be nothing left in the bed (except a hole) if at all possible.
  4. Mar 26, 2009 at 6:18 PM
    Brunes
    Brunes abides.
    Rotorhead
    I think you are going to be doing a custom fab job then. I can give you some other ideas. But if you are set on THAT box and not having anything left in the bed when you remove it- You gotta hit up a hardware store and/or a auto parts store.
    Find a nut set in a rubber grommet (they make them for motorcycle windscreens) and a bolt with a head large enuf to sit in the bed rail the way you want them too.
    Not much help-I know...but it's going to be a toughy to get help over the internet.
    Good luck bro!!
  5. Mar 26, 2009 at 6:35 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Toyota sells a tool box for our trucks.....a bit pricey tho....
  6. Mar 26, 2009 at 6:55 PM
    Hydrabyte
    Hydrabyte Well-Known Member
    Florida
    2012 Tacoma & 1987 4Runner
    Just picked a similar model up from Wally world weeks ago. Small hole through the composite bed, done. Well I also have a thick bed matt so that'll hide the hole when not bolted down.
    Then took a piece if 1/4" plywood about a foot long by 10" wide and place inside bottom of box, insert bolt through wood (box doesn't move as much) add a few washers and a nylon nut - viola - mission complete. Can remove / install in less than 5 minutes.
  7. Mar 26, 2009 at 7:41 PM
    stormyday
    Morganton, NC
    The way I have it installed now is 1 bolt that comes up from the bed, washer & nut, into the box with a washer and nut. I also have 2 toilet bolts that are in the bed rail (they only catch on the top). Yes the box is slightly higher than the bed.
    The problem with this setup is that I have a bolt sticking up 2 inches off the bed unless I take the nut off, then I have to get back under the truck to put it back in. The toilet bolts will come loose just by bumping the box without the bolt in the bed.
    The only other though that I had (i really don't want to do it) was to make a steel plate with a nut welded to it then put this under the bed and screw it in with flush screws. Then I could take a bolt from inside the box and screw it directly in. (Hard to explain)
    I am a big boy and it is hard to get under the truck especially since mine is a 2 WD.
  8. Mar 26, 2009 at 9:06 PM
    raskal
    raskal Well-Known Member
    B.C.
    2013 DCLB TRD MGM
    my plan (doing a similar thing) is to attach some cheap d-rings to the box (well supported) and use a cable lock to lock it to my d-rings in the bed.
    might look a little crappy, but it'll work.
    Another option might be to attach a bolt sticking out from the side rails. Then put a hole in your rubbermaid thingy and slide the box into position over the bolt. Then slip a nut onto it. Or have a hole in the bolt and put a pad-lock through the hole (this is all on the inside of the rubbermaid)
  9. Mar 26, 2009 at 9:41 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    Sparks, NV
    2011 TX TRD 4x4 DC
    OME Lift W/886 Coils/LR UCA's/BAMF LCA Skids/Daker Leaf Packs Fab Fours front bumper/Warn M8000 winch Relentless Fab Rear Bumper/Tailgate Skin/Front skid plate DB Fab Grille Insert with Baja Designs Cube LED's 285/75/16 Nitto Terra Grapplers N-Fab Steps Compustar remote start UWS low pro box Carhartt Seat Covers/Door Inserts/Console Cover OEM Bed Mat Bulletproof Fab Engine Tray/Lower Grille Insert .50 Cal Antenna/Valve Stem Covers Custom Fab Console Lock Box Custom Shift Knob Dash Mat Window Tint Rugged Ridge Floor Mats Blacked Out Emblems Color Matched Grill Surround G-Tek Door Sill Protectors Wheelskins Steering Wheel Cover EGR In Channel Vent Visors FJ emblem on the tailgate Northstar battery TRD battery tie down Illuminated 4X4 switch Bed stiffeners/Bed Extender with custom mounts Redline hood struts Relocated rear diff breather Console Molle Boards Lot's of patches!
    Pricey the Toyota box is but I love mine!!
  10. Mar 26, 2009 at 10:07 PM
    stormyday
    Morganton, NC
    I like to Toyota one but 1. I didn't want to spend that much money 2. I only use it every couple of weeks 3. I drive close to 100 miles a day to less weight is better.
  11. Mar 26, 2009 at 10:56 PM
    SuperD
    SuperD Mall Cruiser Pilot
    Texas
    '09 White TRD Sport DC LB 4x4
    ProComp 6" Stage II, 18x9 Moto Metal 955's, Cooper Discoverer STT 305/60R18, K&N FIPK, Go-Rhino Stainless side steps, Redline Elite hood struts, Magnaflow muffler, Delta Alum. Toolbox, Husky Liners F/R, Window tint
    You can mount your box this way. Remove the wing-nut, remove your toolbox and the mounting bolt stays put in the bed. That way you only have to install them once.
  12. Mar 27, 2009 at 4:54 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    Rep'd for a great idea! :headbang:
  13. Mar 30, 2009 at 9:57 PM
    stormyday
    Morganton, NC
    I went to my local Fastenal store today. They ordered me some rivet nuts. I will take some picture and post updates when I get them installed. They will be here on Wednesday but the tool to install them will not be here until Friday.
