Advice on basic tools to carry in truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bacon_st, Jan 15, 2024.
  1. Jan 15, 2024 at 3:54 PM
    #41
    RichochetRabbit
    RichochetRabbit Bing Bing Bing
    As others said ... ratchets in common-use size. 2 ft breaker bar. Pliers, needle-nose pliers. Wide-blade 1 ft screwdriver makes a good pry-bar. Fuses. Ground tarps. Rain ponchos fold up small. I like a large maglite flashlite with C/D cells ... steel makes good hammer. Zip ties, large. Duct tape. Collection stores in small spaces
    I also keep spare low-beam bulbs in the glove box in case they burn out and some cop is being a d^ck. Even have a spare brake light bulb from replacing only one.
    I have $40 in dollar-coins (coins do not fly in the wind) to buy a few gallons of gas and food/drink if the plastic is lost or corrupted.
  2. Jan 15, 2024 at 5:42 PM
    #42
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  3. Jan 15, 2024 at 6:01 PM
    #43
    RichochetRabbit
  4. Jan 15, 2024 at 6:01 PM
    #44
    tcjacado
    tcjacado Well-Known Member
    A pair of panty hose will also work. Light and compact.
    I usually use a large beach towel. Thick and warm. Also doesn't take up a ton of space.
  5. Jan 15, 2024 at 6:02 PM
    #45
    tcjacado
  6. Jan 15, 2024 at 6:04 PM
    #46
    RichochetRabbit
    I have physically burned memory cells in my brain to forget some of the issues. :annoyed:
    Shellshock and tcjacado[QUOTED] like this.
  7. Jan 15, 2024 at 6:06 PM
    #47
    tcjacado
    Lol.... me tooo:rofl:
  8. Jan 15, 2024 at 6:18 PM
    #48
    tomatogrower
    tomatogrower Well-Known Member
    2013 tacoma crew cab 4x4
    none
    i carry two cell phones with different carriers... due to spotty service... i know it sounds excessive... no satellite phone so far...
  9. Jan 15, 2024 at 6:29 PM
    #49
    twtaco$
    twtaco$ Well-Known Member
    Everyday just a cheap ratchet set and cheap flashlight. Mainly because they’ll probably just get stolen.
  10. Jan 15, 2024 at 6:36 PM
    #50
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
  11. Jan 15, 2024 at 7:08 PM
    #51
    RichochetRabbit
    Even cell phones without a contract dial 911. Assuming you have a signal.
  12. Jan 15, 2024 at 7:19 PM
    #52
    PooTaco
    PooTaco Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
    I think you can take apart 90% of a tacoma with a 10mm lol.
    tcjacado likes this.
  13. Jan 15, 2024 at 7:24 PM
    #53
    Shellshock
    Iowa
  14. Jan 15, 2024 at 7:26 PM
    #54
    Shellshock
    Iowa
    I have a phone and a garmin inreach
    RichochetRabbit likes this.
  15. Jan 15, 2024 at 7:37 PM
    #55
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Tire plugs as mentioned and a wide assortment of hose clamps. I came upon a guy who blew an auto transmission hose off in the middle of nowhere. I gave him a hose clamp and he was back in business
    Never seen a fellow so happy. I carry all my stuff in a 24" toolbag and add to as neccesary. I always keep a floor pump in the truck for sports balls, bicycle tires, air bag suspension, you name it.
    I carry a shovel, two 2x10"x6' pieces of wood (always come in handy) a blanket, a liter of water, bunch of dried food. Lots of lighters, a recovery strap, Silky type pull saw.
    Vlady likes this.
  16. Jan 15, 2024 at 7:41 PM
    #56
    tcjacado
    If you get E rated tires, you better have a drill, and a bit. A hammer and all my tools on board could not solve the problem. Could not get a plug in to save my life.
    Woofer2609[QUOTED] likes this.
  17. Jan 15, 2024 at 7:48 PM
    #57
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Interesting. Did you have the auger?
    I haven't had to plug a E rated tire yet. That being said some e rated tires are more bombproof than others
    My 56lb bfg KO's would probably take a hammer to insert a plug in. They're tough! My new Firestones, although e rated, just don't seem as rock solid. Half the time I run my 2nd wheel set with P rated tires.
    tcjacado[QUOTED] likes this.
  18. Jan 15, 2024 at 7:55 PM
    #58
    tcjacado
    All I know is I tried the tools with plug set. That tool would not /barely drill the hole for the plug. I barely got it in after 2 hours, but then had to drive to a tire shop to get a patch done.
  19. Jan 15, 2024 at 7:58 PM
    #59
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    That sucks! Must have been one helluva strong nail or screw to puncture that tire. After reading this, I'm ok never finding out if my kit can plug a E rated tire!
  20. Jan 16, 2024 at 7:05 AM
    #60
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    :smack:You better hope my wife doesn’t read this!
    dfanonymous[QUOTED] likes this.
