Advice on buying a 2013 Toyota Tacoma Pickup 4D 5ft (that is how it's listed)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maddiiiiii_lite, Aug 25, 2024.
  1. Aug 25, 2024 at 1:05 AM
    maddiiiiii_lite
    maddiiiiii_lite [OP] New Member
    Going to look at a 2013 Tacoma 4D 5ft rear (that's how it's listed). It has 138,490 miles and they are asking $22,449.. thoughts on this price, year body, etc. This is my first tacoma, I have a Jeep Wrangler now and possibly looking to trade it in.
    I'm going to test drive this 2013 yota tomorrow and it is listed for $22,449, it has 138,458 miles on it, 4L & V6. I've looked up the Vin # and didn't find any real info about this truck. Is this worth the price, any known issues from anyone on here? This is my first Toyota, I've been driving a Jeep Wrangler for the last 10 years and have done a lot of work on her. I'm just ready to get something I don't have to continuously work on. I'll attach the link to the truck below...thanks in advance.
    https://www.autokings.com/auto/used-2013-toyota-tacoma-pickup-4d-5-ft-near-bend-or/93727462/
    Smills91 likes this.
  2. Aug 25, 2024 at 1:21 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Thats about right for year, and mileage. Look for frame rought! That will tell if price is worth it. Check coolant make sure its pink, check rear main seal, valve covers and vvt timing covers for leaks. Make sure 4x4 works, toyotas electrical system is finicky.
    maddiiiiii_lite[OP] likes this.
  3. Aug 25, 2024 at 3:00 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    You should have a good shop inspect for frame rust. So many people end up on here with a truck they just bought only to find out that it has frame damage. Don’t be one of those people. Get a pro to look at it.
    Clearwater Bill, SWPA Tacoma and Dm93 like this.
  4. Aug 25, 2024 at 5:30 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I haven't kept up with what they sell for anymore. Plus there is a huge difference in value in different regions of the country. I paid $28K new in 2007 for mine so $22K for one that is soon 12 years old is hard to wrap my head around, but I guess that is the new normal. But those are pretty bulletproof trucks.
    I'll hit 250,000 next week with basically the same truck. Mine is a TRD Offroad. Mechanically the only difference is that mine has a rear locker. Other than normal stuff like brakes, tires, battery etc. I've done very little to mine. It needed a new alternator and one U-Joint at about 170,000 miles. I replaced the headlight housings about 3 years ago, they were faded and I needed to replace the latch on the console recently. That's it.
    herecomesace and Naveronski like this.
  5. Aug 25, 2024 at 5:57 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Frame rust is going to be your main concern - that's a pretty good year otherwise.
    I'm with @Marshall R - price seems high, but maybe that's just what they cost now.
  6. Aug 25, 2024 at 6:03 AM
    Smills91
    Smills91 Well-Known Member
    I just bought a 2015 with 176000 mile on it. I paid 18500 for it. 19250 out the door with tax title and license. It's a trd off road double cab short bed non jbl.
    I looked and looked and looked and I found 3 tacos that were I felt a good deal.
    The first was a 2014 trd off road in dcsb for 24500. It had 3rd gen rims, a bed topper and only 84000 miles on it. I flew up there and the thing didn't work when I got there. It was stained on the seata with ink. To me it was indicative of the previous owner not taken as good of car of a vehicle like they ought to. So i declined on that one even though on paper it was the best buy. The salesman was a legit dude and he put me up in a rental car to drove home.
    To which I drove to the next location and test drove a 2013 t/x baja with 120000 miles on it. They wanted 22500. It also had the bead lock rims. It was fine. But I just got the heebie jeebies about it while I was there. Can't explain it but other than it just felt wrong.
    The third was the one I went with. I drove in the rental to the third location test drove it and bought it on the spot. It just felt right and it's in dang good shape for 176k. I might even take it it to a toyota restore place im using for my 1986 HJ60(diesil) Land Cruiser resurrection that im in the middle of just to rejuvenate my new to me taco at some point.
  7. Aug 25, 2024 at 6:56 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Look at the mods they have done, could give you a clue on how they treated the truck. The fog lights are aftermarket replacements, how were those wired in? Did they use adapters to the harness or just cut and splice? If they cut & spliced how does it look? To install the rear bumper they had to trim the fenders, what's the trimmed edge look like? Looks like there is a lift, is it blocks or did they change the springs?
    I see they want $500 for the LoJack, is that the going rate? Are LoJacks still worth it?
    SethM likes this.
  8. Aug 25, 2024 at 7:05 AM
    SethM
    Seth
    Los Angeles ca
    Good luck, and make sure you hear the tacoma tick, and see that tacoma lean, LOL! I paid $21,000 out the door 2 years ago on a 2011 ttd sport lbdc, with 200,000 miles was 1 owner all dealer maintained and records kept. Am at 223000, nothing major thats not offroad related. Blew out driveshaft, which cracked charcoal canister, and changed 4x4 actuator about 6 times do to high water crossings and mud.
  9. Aug 25, 2024 at 7:17 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Judging by the front skid plate check underneth for any damage.
  10. Aug 25, 2024 at 8:35 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Yup that sharp crease is concerning. What could have caused that???
    My .02 = The mods on that truck combined with the condition of some things says, to me, that the past owner had their priorities out of order.
    • Cloudy headlights but had a light bar installed?
    • Aftermarket fog lights? Why? The OEM ones are more than adequate for fog, unless the lift on the truck made the normal headlights aimed too high so the owner had to run fogs also to illuminate properly at night?
    • Seemingly random camo inserts on the front door arm rests, but the center console lid is bulged/damaged from leaning on it too heavily.
  11. Aug 25, 2024 at 9:19 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    22k,PASS
  12. Aug 25, 2024 at 1:09 PM
    maddiiiiii_lite
  13. Aug 25, 2024 at 1:29 PM
    spitdog
    You can do better. Another one will show up. Look for a non modded truck.
    ridefreak likes this.
  14. Aug 25, 2024 at 1:49 PM
    Dogota
    Dogota 2015 DCLB
    Mark
    Seattle, WA
    What he said.
    Come up towards Seattle, I think you will find better choices. And, a true Pac NW vehicle often has minimal rust.
  15. Aug 25, 2024 at 2:05 PM
    maddiiiiii_lite
    Thank you all for your input and advice! I walked on this one, they wouldn't come off the price at all saying they were a "haggle free" dealership. Good luck to whoever buys that thing im sure there will be a dummy out there who doesn't do research and buys it lol. I'm definitely going to look outside of Bend, OR and see if I can find some better options!
    Thanks everyone!! This was extremely helpful!
    spitdog likes this.
  16. Aug 25, 2024 at 2:20 PM
    spitdog
    Next truck you look at , get the vin # while you there. It’s helpful to see possible repairs , service ect.
  17. Aug 25, 2024 at 3:07 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    15k at best.
    GilbertOz likes this.
  18. Aug 25, 2024 at 7:04 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Jeez that’s nuts given I paid like 24k for my 2011 with 10k miles on it.
  19. Aug 26, 2024 at 7:07 PM
    lynlan1819
    Tacoma
    Lifted
    They did you a favor,let them smell it to some fool that over pays for it.
    Black is the worst color anyway.
  20. Aug 26, 2024 at 9:25 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    22K maybe for a super-clean, STOCK unmodded Taco w/ all service records and 120K miles on it.
    For that modded-out blacked-out thing, 15-16K max.
    And what's going on with that fine mesh bug-screen front grill replacement? Looks like it seriously impedes air flow to the radiator. That's bad.
