Advice on buying a OBDII scan tool?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Coolidge, Aug 7, 2017.
  1. Aug 7, 2017 at 3:20 PM
    Coolidge
    Coolidge [OP] Well-Known Member
    So Cal, Ca
    2003 Pre Runner
    King coilovers frt +3". Bilstein 5100 shocks rear w/AAL, K&N FIPK, Magnablow exhaust, Billet grill, clear corner lights, Sony stereo, JBL, Sub etc.
    Hi. Ive been getting check engine lights on a fairly frequent basis. I have a K&N FIPK kit, replaced plugs, wires, both O2 sensors, clean MAF sensor, throttle body, fuel filter and cleaned injectors. Truck runs well (most of the time) but does get a intermittent bog with poor fuel mileage. Truck is 03 PreRunner with V6 and Im suspecting the Throttle Body or TPS.
    Anyway I was checking OBDII scan tools and found they vary a lot, especially price, and right now money is tight. There is a scan tool for under 40.00, but they go way higher than that.
    Question, will the 40.00 tool get me in the right direction to find the problem? I realize, "you get what you pay for" but was hoping to get some feedback on this. I know a lot of 1st-Gen Taco owners have experienced what Im going through, and was hoping for a little advise?
    THANKS in advance
  2. Aug 7, 2017 at 4:26 PM
    Slickster
    Slickster greentaco
    2002 pre
    Dalandser likes this.
  3. Aug 7, 2017 at 5:13 PM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    I have used this BAFX OBDII bluetooth tool https://www.amazon.com/BAFX-Product...02150893&sr=8-1&keywords=obdii+bluetooth+bafx along with my Android phone and the https://play.google.com/store/apps/details?id=org.prowl.torque&hl=en Torque app for a few years. I have used the BAFX tool with both my Tacoma and wife's Ford. If you run Apple products, I believe you need to buy a OBDII scanner that uses WiFi since Apple doesn't open their BT up enough.
    They have helped me diagnose a MAF sensor and O2 sensor. Can't beat the setup for $22 (OBDII tool) and $5 (app).
    A little off topic..... one of the best changes I made to my truck was to get rid of the K&N "cold air" intake/filter that was on the truck when I bought it. Throttle response was much more crisp after I found a stock air box to put on it.
    Coolidge[OP] and Dalandser like this.
  4. Aug 7, 2017 at 6:08 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    ive had both aforementioned adapters. the bafx adapter is by far better. but the small blue one still gets the job done just as much, just not as fast. if you're looking for general dianostics and code resetting get the blue one. if you want to monitor voltages and readings in near-real time get the bafx. or just get the bafx since it's not that expensive to begin with and will pay for itself on your first diagnostics repair.
    don't forget to get torque app!
    also, don't buy a tool from a brick and mortar store. entirely over glorified.
  5. Aug 7, 2017 at 6:17 PM
    Indy
    Indy Master of all I survey.
    $5 China bt obii, torque app for free.
  6. Aug 7, 2017 at 9:08 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I too have the bafx obd2 scanner and the torque app for my phone. i bought the $5 "pro" version, because, well, it was $5 and I be rollin in cash... lol...
    Anyhoo, I like it. Actually thinking of getting a 2nd one for my '17 4runner. I've never had a problem connecting, and the app itself is pretty cool, and easy to use. I was bummed when I realized I can't track trans temp in my 4runner, tho.
    Coolidge[OP] likes this.
  7. Aug 7, 2017 at 11:00 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
  8. Aug 7, 2017 at 11:02 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    I second the BAFX adapter and torque app. Works great for me.
  9. Aug 26, 2017 at 4:03 AM
    freighter72
    freighter72 Member
    George
    Southern California
    2016 Tacoma TRD OFF-ROAD Extended Cab
    Husky floor mats, Toyota bed mat, Bed Header rail,
    I have an Autel AL619 that I ordered through Amazon. It was less than $100 and it works on all of my Toyota vehicles. On my 2016 Tacoma it pointed out a failing CPS. (Crankshaft Position Sensor) It has also caught a bad TPS (Throttle Position Sensor) and a few O2 sensors. You won't make a living with this scanner but it will help find problems when your MIL (Malfunction Indicator Light) comes on.
  10. Aug 26, 2017 at 12:52 PM
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
    I will second the notion that getting rid of the K&N filter will solve some of your codes. It caused more problems than what little "gains" I got from it. I went back to the OEM air box and an AFE drop in filter. The BAFX scan tool is a good product also.
  11. Aug 26, 2017 at 1:11 PM
    pulldo
    pulldo Well-Known Member
    houston, texas
    95 dlx, 2.7l, 4wd, 5 spd.
    Car manufacturers spent a lot of money developing the motor and what it needs to operate,,, and it should be adequate,,, IMHO. Better filtration is way more important to me than having something that might leak and let something get by into the motor. Most people don't take care of their K&N the way it should be anyway.
  12. Aug 26, 2017 at 2:12 PM
    herbertgerg
    Gary
    The issue with the K&N filters is that it uses OILED cotton. That oil gets sucked down the intake tract and gets all over everything, especially Throttle Position Sensor and MAF- which are critical to ECU operations. K&N FIPK on TAcoma 2.7l or 3.4l are notorious for throwing codes. If you want to leave it on there, keep the tube and boot (clean out all the filter media oil) and get a dry filter.
  13. Aug 27, 2017 at 6:52 PM
    Glamisman
    Glamisman Well-Known Member
    this is a very difficult thing to advise on since not all scan tools are the same. I have 3 due to the many different vehicles that I own / tinker on. One tool might allow you to reset some but not all of the maintenence lights, some will cycle the ABS pump so that you can bleed the brakes, some will only check engine issue and not ABS issues. You are going to have to determine what vehicles you can use it on and what you think you might use it for. Lots of Auto Parts stores have scan tool that you can use, some might let you take it home, after all, they want to sell you parts even if they dont fix the problem.
