Advice on center caps falling off
Discussion in 'Wheels & Tires' started by NightShades, Nov 16, 2011.
  1. Nov 16, 2011 at 10:44 AM
    NightShades
    NightShades [OP] Well-Known Member
    Tallahassee, FL
    05 PreRunner
    Bug Deflector, Bed Extender, Roof Racks
    Hello all, i have a 05 Taco, and the stock wheels suck... The center cap clips break very easily and fall off... To fix this problem I pulled all of the center caps off of my truck.... Now it doesnt look so fresh, but atleast im not stuck buying a 40.00 center cap that is poorly made and will fall off again.
    Question is.... Do they make wheels with better center caps that dont attach with flimsy clips?
    I was thinking of buying some 4 Runner wheels and sticking them on my Taco.. But i dont wanna run into the same problem that i had before.. with plastic crappy center caps...
    Do manufacturers make metal center caps?
    What about the 4 runner wheel center caps do they fall off easily?
    Please advise...
    Thanks
  2. Nov 16, 2011 at 10:47 AM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    i use black electrical tape to hold mine in place. can't hardly see it unless your up close. i have black covers and rims so it blends in real nice.
  3. Nov 16, 2011 at 10:47 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    I don't mean to sound like a dick, but I would never look at replacing my wheels just so I could get center caps that didn't fall off.
    The center caps should not be falling off period. Which stock rims do you have? Pics?
    Fink
  4. Nov 16, 2011 at 11:02 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Are you talking about these? I haven't had any problems with them.
  5. Nov 16, 2011 at 11:04 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    trdparts4u has caps for $7. Silicone them on that way you can remove them if needed. Ive never lost one and cracked 2 of my 4 on rocks/trees.
  6. Nov 16, 2011 at 11:24 AM
    NightShades
    Tallahassee, FL
    05 PreRunner
    These are the wheels.
  7. Nov 16, 2011 at 11:27 AM
    NightShades
    Tallahassee, FL
    05 PreRunner
    And guys, when i get my tires rotated at the place they have to remove the caps and put them back on, and the prongs that hold them on get bent and break eventually.. then the caps fall off.. tell me this doesnt happen to you all?
  8. Nov 16, 2011 at 11:34 AM
    Fink
    Orlando, FL
    That's odd - I've never had center caps break that easily.
    I guess the electrical tape idea is going to be your best bet until we can come up with something else.
    Fink
  9. Nov 16, 2011 at 11:44 AM
    NightShades
    Tallahassee, FL
    05 PreRunner
    Caps are purely cosmetic correct? Ive been fine leaving all 4 off... Better gas mileage less weight to turn the wheels!
  10. Nov 16, 2011 at 8:39 PM
    907taco
    Bobby
    Alaska
    my stockers would not come off, even with 1/2 the tabs broken off. I was talking about my pro comps 7089 caps.
