Advice on changing manifold on 2005 4Runner?
Discussion in 'General Automotive' started by Mr.Tacoma, May 17, 2020.
  1. May 17, 2020 at 1:07 PM
    Mr.Tacoma
    Mr.Tacoma [OP] Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    Hey folks
    Seems like driver side exhaust manifold is leaking, leaks during accelerating & also at cold /high idle. Anyone changed manifold on T4R, need some advice I know it's a pain, moderate skills needed...wanna see if I can handle. Check engine light is ON as well. Haven't had a chance to run the codes yet.
  2. May 18, 2020 at 2:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Its not that bad, there's some vacuum lines at the back i believe, you should be able to remove the throttle body and set it aside without disconnecting the coolant lines and losing coolant.
    I wouldn't pull anything apart until you read the codes though
