Advice on dealing with The Dealer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ShawaiianS, Oct 7, 2022.
  1. Oct 7, 2022 at 3:34 PM
    ShawaiianS
    ShawaiianS [OP] Active Member
    Shawn
    Seattle
    Taco Time, Hawaiian style
    6" RCD lift, 5.11 ECGS front and rear, 33" Grabbers
    Aloha gents (and lady) I humbly ask your opinions regarding the predicament I now find myself in with my new-to-me- but- not-NEW-new-but-new-enough-with-factory-warranty '20 3.5L 4x4 auto w/ just north of 20k mi. My problem? The truck has what I can only describe with my caveman level knowledge of electrical engineering as a "ground" or "short." This "thing" that it just started doing, ran perfectly every since I bought it a month ago or so, which causes her to turn over normally, run great for a time and then it starts stumbling, choking, very nearly dying then "resetting" (Tacoma thingy in the dash display resets, all warning lights cycle on/off as when you first put the key in and start) springing right back to running perfect... for 2-30 sec, then the shit Rollercoaster starts all over again. Solve for X until it eventually dies however many min later. No codes. Not that I can pull, anyways. So, to the dealer, right? Well, here's my question. 2nd owner, me, bought the truck with the 4" lift, tires, and rock lights already installed on the truck. All of which appear to be done proffessionally as there is an additional fuse panel mounted very tiddy like in the engine bay for the rock/ditch lights and all wire loomsare crimped and heat shrinked appropriately. Even look like they have stock switches in the overhead, no wires ran across the dash or anything like that.
    Thinking that they could be the culprit (the rock lights, I mean) I disconnected them and fired her up, but alas, no change. She's still doing her muck about thing. Should I remove the aftermarket lights completely b4 sending it to Toyota, being as an electrical issue almost certainly is the culprit and can (or would) Toyota blame the light additions for the issue? Its going to Toyota no matter what, but hopefully some insight on if she goes with or without the lights would be greatly appreciated
  2. Oct 7, 2022 at 3:37 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    If you bought the truck with those lights, leave it
  3. Oct 7, 2022 at 3:40 PM
    PahalaTacoma
    PahalaTacoma Well-Known Member
    Tucson, AZ
    2017 Tacoma TRD PRO
    Try remove the wire from the addtl fuse panel going to the + of battery. Should tell you if that is the culprit.
    tonered likes this.
  4. Oct 7, 2022 at 3:40 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    IF your sole reliance for service will be the dealer then yes. I would eliminate, if you can, any wrong doing from the past owners
    Doing so will save you the cost per hour that at the dealer someone might have to sift through the mess.
    GL
    Chew likes this.
  5. Oct 7, 2022 at 3:47 PM
    ShawaiianS
    Shawn
    Seattle
    Tried removing the lights from the system i.e. disconnected the add. lights relay from the battery terminals, but she kept acting up the same way
  6. Oct 7, 2022 at 3:50 PM
    ShawaiianS
    Shawn
    Seattle
    wfo479 My only resource as she should still be under the 3 yr 36k mi warranty from Toyota (not a salvage/ rebuilt title, no engine modifications) so I don't want to upset the Toyota Gods by taking it to anywhere else. That's my thinking anyways
  7. Oct 7, 2022 at 3:55 PM
    McFly'sRide
    McFly'sRide Well-Known Member
    Los Angeles
    2022 DCSB Off Road 4x4
    Icon RXT Leafpacks rear, TRD Lift front, 17 inch Methods, Wildpeaks, Heritage Grill, Leer 100XR, Blackout Package
    I think you may be SOL with the electrical mods. I wouldn't remove anything as it would be futile - and the dealer would see evidence of it anyway. Bite the bullet and take her in and pay for the repair. Have you reached out to the prior owner?
  8. Oct 7, 2022 at 4:15 PM
    Silver Jacket
    Silver Jacket Well-Known Member
    Howie
    2022 Silver TRD OR 4x4 MT
    This might not be an electrical problem. If the car starts normally and runs, then stumbles and dies several minutes later, it sounds like a potential fuel/spark/ignition problem. A lift or lights shouldn't affect that at all. With any car, I'm assuming Tacomas as well, you can completely disconnect the battery after starting it and it will continue to run without stumbling or dying as long as your alternator is functioning. The turning of the alternator provides enough spark to the plugs, and everything else is fuel and air flow.
    Of course in modern cars electrical or electronics can come into play via the ECU which controls the flow of fuel and timing of spark. Affecting these parameters can cause your car to stumble and die. Before getting into all that fanciness, with the symptoms you describe I'd be looking at fuel. How long has this been going on? If since the last fill-up, I'd get some new gas in there and see if the problem persists.
  9. Oct 7, 2022 at 4:29 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Leave the lights on it.
    Why? Because it will help the Tech if he/she has a problem in the circuit where the lights are installed.
    Other wise, they might spend more time chasing the wiring.
    There’s no need in hiding it, if the dealership blames the lights, and it actually “wasn’t” the lights.
    They were going to blame you anyways.
    But, contrary to popular belief, most dealerships aren’t out scam you.
    They are just expensive.
  10. Oct 7, 2022 at 6:01 PM
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    We’re 2020’s on the list for fuel pump recalls ?
  11. Oct 7, 2022 at 8:45 PM
    ShawaiianS
    Shawn
    Seattle
    I haven't checked the SBs yet. Is there a known fuel pump issue on previous yrs?
  12. Oct 7, 2022 at 9:24 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Wouldn’t a fuel pump through a code?
    I’m thinking it could be the alternator. But usually the battery will keep things going for a bit. I’d check voltage on the battery with the engine running. Quick and easy and worth doing to rule out trouble in that department.
  13. Oct 7, 2022 at 9:54 PM
    ShawaiianS
    Shawn
    Seattle
    I just bought a brand new optima battery, and now that Im thinking about it, it ran perfectly for the first hr or so, and then the issue began to occur more frequently... and I'm guessing with the amount of electronics on this truck, any fluctuations in current amperage would send it into a hissy fit i.e. exactly what she's doing... God damnit, is it normal for alternators to burnout after 20k mi?
  14. Oct 7, 2022 at 10:03 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    20k is on the short side for failure but not imposable
    any signs of rodent under the hood?
    Canadian Caber likes this.
  15. Oct 8, 2022 at 5:39 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Did this have the problem before new Optima battery?
  16. Oct 8, 2022 at 5:52 AM
    adamceckhardt
    adamceckhardt Well-Known Member
    Just a thought- regardless of what you do before bringing it to the dealer, it might be helpful if you have a friend take a video of what's happening... more than once if possible, just so the tech can see it before trying to duplicate it. Maybe if you posted the video here someone smarter than me could help you out!
    saf023 likes this.
  17. Oct 8, 2022 at 7:00 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    2020s were not included in the fuel pump recall.
  18. Oct 8, 2022 at 7:33 AM
    daveeasa
    David
    PNW
    I personally ran an Optima D35 as my primary battery for a couple of years, since switched it to the aux location. Some have reported quality issues with them. But regardless of brand, a bad battery can happen. Also battery terminals can have poor conductivity. That type of stuff is at least easy to rule out and I’d imagine there is a warranty on the battery itself.
    The alternator can fail but 20k is very early. I had one go on me on the NJTP when I was in college. It was stressful and scary.
    Both of those problems, albeit somewhat costly, are better than something within the main harness. So they are the things to rule out first, before diving into the really hard stuff.
    @caribe makaira may have more sage advice as well. I would just start with the basics. But maybe someone who has experienced fuel pump trouble can chime in on those symptoms.
  19. Oct 8, 2022 at 8:06 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    this, some ooooh and ahhh over aftermarket parts on used vehicle, I run!
    sorry OP, I know that's not much help, but it sounds like you have aftermarket doodads previous owner wired up, correct? what mods?
    You might try disconnection much of it and start using the process of elimination.
  20. Oct 8, 2022 at 8:38 AM
    Silver Jacket
    Howie
    Having bought a heavily-modded truck, and now trading it in for a brand-new Tacoma, I'm glad to be finally rid of the previous owner's mods that I never would have chosen myself. However, my experience with the used truck was a good one. The mods never caused any serious problems, and I enjoyed them. It just never really felt like MINE.
