Advice on driveshaft (vibration after lift)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by navynuke, Jul 3, 2019.
  1. Jul 3, 2019 at 6:24 AM
    navynuke
    navynuke [OP] Well-Known Member
    Lake Wylie, SC
    2014 TRD Off Road DC
    I installed Bilstein 6112/5160 and Dakar HD leaf packs about a year ago. I did install a CB drop, but have had take off vibes from day one. Nothing crazy, but still noticeable. Recently I've developed a vibration at 45-55mph, which I assume is probably from CB wear.
    I called a local driveshaft shop, it's a well known shop for off road vehicle drivelines, they told me to fix Tacoma vibes the basically extend the stock driveshaft and that takes care of the issue. They told me going to a single piece is something they did like 5 years ago, but don't do anymore.
    Conversely I can buy a single piece from Tom Woods and the consensus on TW is most of the time the vibes go away.
    I don't plan on ever having to re gear, I don't do much wheeling (only enough to get me around when I'm hunting out west), I do tow a boat that's about 3500lbs total weight.
    If anyone has some advice on which option would be the best let me know.
  2. Jul 3, 2019 at 6:29 AM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    The vibrations that you get at 40 - 50 mph should go away if you switch to 4hi. If it does then it is the front diff drivers side needle bearing. East coast gear supply has a replacement bushing that fixes the vibration.
    I just did 5100s with 877 springs in the front with extended 5100s and Dakar HD springs in the rear.... About 3.5" total lift and got the vibes after about a day.
  3. Jul 3, 2019 at 6:32 AM
    navynuke
    Lake Wylie, SC
    Forgot to mention, ECGS bushing was installed when the lift was installed.
  4. Jul 3, 2019 at 6:35 AM
    redz80
    Brampton, ON
    Does the 40 - 50 vibe go away when in 4hi? Maybe the bushing has worn out and needs replacement? I still need to order the bushing fix.
  5. Jul 3, 2019 at 6:38 AM
    navynuke
    Lake Wylie, SC
    I’ll have to check that out. I’ve only put about 7000 miles on the bushing. I suppose it could be failing, but that doesn’t seem likely.
  6. Jul 3, 2019 at 7:07 AM
    navynuke
    Lake Wylie, SC
    I can confirming shifting into 4 hi does not stop the vibrations.
    redz80 likes this.
  7. Jul 3, 2019 at 7:44 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    I would probably try axle shims in conjunction with your existing csb drop. You may be able to get away with no csb drop and just the axle shims but I would start at the cheapest solution first before spending money on a driveshaft.
    SR-71A likes this.
  8. Jul 3, 2019 at 7:54 AM
    navynuke
    Lake Wylie, SC
    Yeah that’s what I would consider, but if I can just spend the money and not chase the problem i would prefer that. I’d imagine at this point my CB is shot so that would have to be replaced anyway.
  9. Jul 3, 2019 at 10:05 AM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Well if that were the case, you wouldn't be on TW and the truck would be in the shop for diagnosis! The truth is, every setup is different and it basically boils down to your drive line angles due to the lift. An extended driveshaft will only do just that, extend the driveshaft. With the shims, you modify the angle of the driveshaft to differential to a lesser degree and reduce vibrations.
    Alot of the advice given here on TW has saved many people hundreds of dollars. Spend $20 on the shims, install them and see if that cures your issue. You may have just saved a bunch of money for other mods vs spending money on the drivetrain when all that was needed was a minor driveshaft angle adjustment.
    SR-71A likes this.
  10. Jul 3, 2019 at 10:16 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    It's simple geometry. All you have to do is buy an angle finder and measure to know what to correct. The angle of the diff must match the slope of the first drive shaft. You also want to make sure that the CB is centered laterally.
  11. Sep 26, 2019 at 4:17 PM
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    Any update OP? I’m in the same place, but with access cab 2015
    really tempted to try the Tw single piece....
  12. Sep 26, 2019 at 4:36 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Going to a single piece driveshaft is a pretty drastic change from stock engineered configuration. I would much prefer to dick around with the angles first and only do the shaft as an absolutely last resort. When i did the Dakar HDs I installed the shims and CB drop. I have very slight takeoff vibes (my stick shakes for like 3 or 4 bumps back and forth and it's gone) and it's totally livable. No other vibes.
  13. Sep 26, 2019 at 4:47 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Do as you want and read the forum. Everyone has an opinion.
    I got sick of all the BS from Toyota so went with a Tom Woods 1 piece regular u-joints and have 5100s and Dakars and all is fine.
    Stocks tires 265-70R15 and front 5100s set at 2" and alignment works perfectly stock front arms.
    Pull a boat a lot and Dakars handle that well with no squat and no spring wrap changing the driveshaft angle.
    No vibrations and steers straight with no front tire wear.
    Have full 3/8" skid plates underneath to. Good luck.
    cedarpangolin likes this.
  14. Sep 26, 2019 at 4:50 PM
    navynuke
    Lake Wylie, SC
    Did you have to cut the CB bracket?
  15. Sep 26, 2019 at 4:53 PM
    cedarpangolin
    Christian
    I’d love to second this opinion, but I’ve got 2.5” spacer lift and 1” rear block with 1.75” torch aal, and I’ve tried shims, cb drop, etc with no help. I’m switching to The Billie 5100 all around and keeping just the add a leaf in the rear, fronts set to full 2.5” on stock coil overs.
    I really feel like I’ve wasted enough money and I’m hoping a single piece is the saving grace....
  16. Sep 26, 2019 at 4:53 PM
    cedarpangolin
    Christian
    Cut!? It literally just unbolts doesn’t it?
  17. Sep 26, 2019 at 5:33 PM
    muddog321
    FL
    Yes simply unbolt and drop that CB and 2 piece shaft in the trash - no actually keep it in case Toyota pays for a real factory fix - oh that would be probably be another partial fix and worse than the TW shaft fix - after years of BS I do not ever expect them to really resolve their problem. If you have a DBLB a 1 piece shaft exceeds the max length for 1 piece. DCSB are OK like mine. Note that if you buy a 1 piece TW shaft but do not beef up the rear springs nothing is cured as stock springs are too soft. When towing or loading heavy with weak stock springs a 1 piece may hit the tunnel. So new TW shaft, new Dakar or other rear springs, and then a 2' lift in front to level it (5100s do it). Not cheap to do it all correctly. Cheap out and you keep chasing that factory fix - as your blood pressure climbs and cursing increases!
