Advice on FX-R order from TRS
Discussion in 'Lighting' started by TwoTacos, Jan 23, 2014.
  1. Jan 23, 2014 at 11:39 AM
    TwoTacos
    TwoTacos [OP] Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    I emailed theretrofitsource.com for an order I want to place concerning compatibility and I haven't heard back from them, so I figurred I would post here and hopefully somebody would know.
    What would you change to the order shown below, or does it look ok? There are so many options and I want to see what memebers who have FX-R's think.
    Thanks! :D
    ________________________________
    Bi-xenon FX-R Stage IV Kit
    Advanced Install Universal Retrofit Kit
    Edit
    Projectors : 1 x FX-R 3.0: (2.5" Lens/LHD) $0.00 Ballasts: 1 x D2S: Denso Slim $0.00 Bulbs: 1 x D2S: Osram Xenarc 66240 $5.00 Shrouds: 1 x Apollo 2.0 Flat $0.00 Wire Harness: 1 x MotoControl Bixenon: H4/9003 $0.00 Halos: 1 x 100mm Amber $50.00 Glue: 1 x OCI Butyl Rubber Glue $10.00
  2. Jan 23, 2014 at 5:03 PM
    boltstaco
    boltstaco Well-Known Member
    eric
    oceanside, ca
    panty droppa
    AFE intake, 3" spacer w blocks in rear
    Looks fine to me. I pretty much have same set up except I used morimoto ballast/bulbs
  3. Jan 23, 2014 at 7:25 PM
    InSight Retrofits
    InSight Retrofits Closed
    Should be fine with 0 ballast issues. Careful of those damn Halos. Another members failed after a few uses and only lights up 2/3.
    I kept my retro simple for less change of problems
