Advice on how to repair my "first scratch."
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maui NoKaOi, Mar 25, 2019.
  1. Mar 26, 2019 at 5:34 AM
    Inverted
    Inverted Well-Known Member
    I’d get it repaired, as these trucks go forever and you seem to take pride in keeping yours pristine. I have a 5th gen 4Runner I offroad. Each time I get back, I buff out the scratches I can and do a full wax. I’ve had it for 9 years and I know what you mean about the attachment.
    I was sideswiped a year ago by an inattentive driver . I thought about pocketing the the insurance money but eventually opted to have a body shop repair the damages.
    I’d consider repair or plasti-dip as others have mentioned
  2. Mar 26, 2019 at 6:08 AM
    psmura
    psmura Well-Known Member
    Paul
    Syracuse, NY
    2018 TRD OR MT
    Some of that lower scratch can be buffed out. Hit both areas with some good compound of your choice. Clean both areas really good and get a bottle of touch up paint and few small painters brushes. Carefully fill in the scratched area with small layers until you build it up to meet the existing paint level. Let it dry and eventually wax the area.
    You will get more scratches on your flares from instances like this or flying road debris. After one winter I couldn't believe the number of rock chips on the leading edge of my rear flares. Better to have damage to plastic bits rather then into your metal panels. When mine get to be in real bad shape I will remove them all and either bed line or line-x.
    Maui NoKaOi[OP] likes this.
  3. Mar 26, 2019 at 6:12 AM
    Fiesta346
    Fiesta346 Well-Known Member
    PA
    2013 Tundra rock warrior
    Find someone local who deals with auto paint/body work. They should be able to mix you up a small container of touch up with your paint code or vin# and it will match exactly. Don't use no store bought crap
  4. Mar 26, 2019 at 6:55 AM
    Tacoma6MT
    Tacoma6MT Well-Known Member
    Oscar
    Bay Area
    2019 Cement DCSB O/R 6MT
    That looks awesome man, I vote OP paints his fender flares instead of fixing the scratch.
    Vanderjdm likes this.
  5. Mar 26, 2019 at 8:34 AM
    BBPSR54X4
    BBPSR54X4 Well-Known Member
    2017 SR5 DCSB 4x4
    Try to touch it up with a paint pen or brush. If it doesn't look good and you still want it repainted by a pro, it won't cost you any more than it would before the touchup was done.
    Or leave it.
  6. Mar 26, 2019 at 8:47 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    We have a winner.
  7. Mar 26, 2019 at 8:54 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Disagree because it's usually way less noticeable at a glance but YMMV
  8. Mar 26, 2019 at 9:04 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Seriously doubt paint thinner will take that paint off.
  9. Mar 26, 2019 at 9:20 AM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    Looked it up. He used paint STRIPPER.
    2016Tacoman[QUOTED] likes this.
  10. Mar 26, 2019 at 11:03 AM
    Maui NoKaOi
    Maui NoKaOi [OP] Active Member
    Maui
    2018 SR5 V6 DCSB 4x4 3.5L
    Right? I thought so too! But the reality is there are many more BBP here than I would have imagined. I'm sure some of it has to do with awareness, noticing others with the same color.
  11. Mar 26, 2019 at 11:05 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The first scratch is the hardest.
    psmura and Maui NoKaOi[OP] like this.
  12. Mar 26, 2019 at 11:22 AM
    TacoRN
    TacoRN Active Member
    Brad
    VA
    2022 TRD OR DCSB
    None yet.
    OP, check out Touchupdirect.com. My Dad had a similar issue with his truck and ordered from there. Unless under the right light the repair virtually unnoticeable.
