Advice on installation products
Discussion in 'Audio & Video' started by rb11701, Sep 23, 2010.
  1. Sep 23, 2010 at 7:29 PM
    rb11701
    rb11701 [OP] Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I am looking to be pointed in the right direction for power/ground wire as well as speaker wire.
    As of right now, I will be using the stock HU. Not sure if it will be wired into a Audiocontrol LC6i, Audiocontrol EQX or RF 3sixty.2. Anyways, I would like some info on what wire I should be looking at. Gauge size, brand etc.
    I will be running a set of Pioneer TS-D1720C powered by an older RF Punch 60.2.
    I would like something flexible and easy to work with. What should I get to attach the power wire to the stock battery? And what size and type of fuse. I do not need the best of the best, but I don't want bottom feeders either.
    Is there a kit I can buy? Or am I better off getting seperate parts.
    Thanks!
  2. Sep 24, 2010 at 5:59 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    For a 60.2 i'd recommend 8 gauge wire
    match the fuse to that of the fuse on your amp
    Buy a kit, it's cheaper. Kicker makes really good kits and they are priced pretty low
  3. Sep 24, 2010 at 1:00 PM
    rb11701
    Rob
    I did see some kicker kits and they were priced relatively low. Those and kits from Stinger I was looking at. Would it be wise to run 4ga from the battery to a d-block and then 8ga to the amp in case I go with s bigger amp?
  4. Sep 25, 2010 at 3:44 PM
    SagWagon
    SagWagon Well-Known Member
    Geoff
    Portland, OR
    2018 TRD OR
  5. Sep 26, 2010 at 6:52 AM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    I just went to Lowe's and bought some 4AWG wire. They will cut off however many feet you ask for from their giant wire spool carousel thing. I got 30' and it was enough but tight for running from the battery to behind my rear seat with both positive and ground. If you don't run the ground all the way back to where the battery is you'll need less. If I was to do it again I'd buy 35'.
    Then of course you'll need to get connectors... but the fuse I got from Best Buy. It is a screw down in-line fuse holder and I stuck it right next to the battery. That should only cost you a few bucks.
  6. Sep 26, 2010 at 4:27 PM
    rb11701
    Rob
    That's a good idea. Never even thought of that. I would imagine the electrical wire is just as good as a wire I got from a car audio place, no?
    Also, did you just buy a ring connector and crimp it on? What did you use on the amp side? Spade type?
  7. Sep 30, 2010 at 10:44 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    I used ring lugs and a big ass Greenlee crimp tool for the battery side connections (I do electrical for work so I had the tool). The amplifier connections are screw down barrier strip type connections so no connectors were necessary.
  8. Sep 30, 2010 at 10:47 PM
    RMTacoguy30
    RMTacoguy30 Well-Known Member
    Jay
    Murrells Inlet, SC
    10 DC Prerunner Sport TRD
    EGR in channel Vent Visors, Flowmaster American Thunder Dual Exhaust, Thule ToolBox, AFE Pro Dry Drop In Air Filter, Weathertech Floorliners, TC UCA's, Camburg Spindles, AllPro 3" rear.
    Whatever you do I wouldn't buy a kit from Bestbuy. Theres are really expensive. I got a kicker kit from sonicelectronix that was the same exact one at Bestbuy for half the price.
  9. Sep 30, 2010 at 11:06 PM
    dreamnz
    dreamnz Well-Known Member
    SoCal
    PreRunner
    Suspension: Camburg Spindles, Bilstein 5100s, Deaver Leafs, BFGs Audio: IDQ 10 in "Marv" box - Hybrid Audio L6 mid bass/ L4 mids / L1 ProSE tweets - RF Power / Arc Amps...BitOne.1 to control it all.
    For ground, don't waste your time running a separate wire all the way to the battery. I drilled a hole in a piece of the cab near where my rear seat seat belt spooled and bolted the ground wire to it. I just used my dremel with a wire wheel end to expose the metal around the hole I drilled. It's a couple feet from my distribution blocks anyways. 3 amps and a Bitone all ground from here and there's no problems at all.
    Also, 4 gauge power from the battery, 4 gauge ground to blocks and 8 gauge to all the amps from there.
    I used a Stinger kit from http://www.hifisoundconnection.com
    Good quality and cheap. That's the trick. You don't want to have to go rewire things in a couple years or smell smoke because the shielding is rotting off, but you don't need to waste $ either.
    Good luck.
