advice on lift/needed parts
Discussion in '1st Gen. Tacomas (1995-2004)' started by shortround13, Dec 10, 2014.
  1. Dec 10, 2014 at 10:09 PM
    shortround13
    shortround13 [OP] Well-Known Member
    Sacramento
    04 DblCab TRD 4x4
    Hi all, new to the forum and have been reading for a while trying to glean what information I can before posting. Feel like I have an idea of what I want to do, but there's so many interrelated systems that seems like as soon as you make 1 change you have a few more that are needed. so, I'd like to run a rough draft of some of my ideas and see what everybody thinks. Thanks
    basics, 2001 Taco TRD 4x4 access cab, pretty much stock. has a K&N filter and camper shell but that's about it.
    intended usage: as of now, daily driver/light off-road for fishing/hunting/camping, not so much crazy extreme rock crawling, but ya never know right?
    lift I'm looking at: Toytec BOSS 3", with complete rear spring pkg and diff. drop
    I'm going to build as I go, so a winch/bumper could be in my future, but not right away....will the med (600lb) accommodate the weight, or will I need the heavy (650lb) coils
    will most likely add the UCA option as well
    http://toyteclifts.3dcartstores.com/BOSS-Suspension-System-for-955-04-Tacoma_p_784.html
    Tires: for now, gonna leave the stock 265s on. down the road possibly 285s, or 32/33? backspacing required for any of these with a lift?
    it also seems 2 routes for increased tire clearance would be to either trim, or body lift. If I went small, like 1" body lift, is that a bad idea, better off doing the fender/wheel well trimming?
    I know body lifts may not have the best rep, but I would use a reputable brand, and keep it small with HD grade 8 hardware....
    with these mods will there be anything else potentially needing changed as well?
    thanks!
  2. Dec 10, 2014 at 10:47 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    With plans for a winch and bumper (and skids and sliders?) the 650 lb coils are a better choice in the long run. The 600 lb coils will not hold up with all the extra weight.
    I started with 650s and have now gone to 700 lb coils because even the 650s weren't enough.
  3. Dec 10, 2014 at 10:50 PM
    shortround13
    Sacramento
    04 DblCab TRD 4x4
    how much extra weight are you running on the front...and what accessories?
    I'm kind of clueless when it comes to how much stuff I may be adding actually weigh....
  4. Dec 10, 2014 at 11:01 PM
    Digiratus
    Roaming the PNW
    The RedHead
    If you add up all the heavy pieces (2 sliders, aftermarket skid plates, plate bumper and winch), I guestimate about +300 lbs over stock.
