Advice on picking a lift
Discussion in 'Suspension' started by Pat, Jun 19, 2008.
  1. Jun 19, 2008 at 5:35 PM
    Pat
    Pat [OP] Well-Known Member
    San Diego
    05 PreRunner Access Cab
    King Coilvers, 285 BFG A/T's, Moto Metal 951b's 17"
    Im new to the lifting of trucks and Im looking to lift my truck 3 inches. I have searched this forum and others alike and I have got many different opinions on different lifts and pricing. I want a nice level lift of some sort. I just read this...
    http://www.customtacos.com/tech/index.php?article=137
    Which gave me a lot of good information. I don't have tons of money to spend on this but I want to make sure I don't buy into a bunch of work down to road. The spacers seemed to be what I was leaning towards more but I still do not have much of an idea.
    My Taco is a 2005 Access Cab 2wd. Any help would be appreciated and if you have any other ideas, Im open to anything. Thank you all for your help!
  2. Jun 19, 2008 at 5:37 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Do you want it level or lifted?
    Whats your budget and how do you use the truck?
  3. Jun 19, 2008 at 5:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What are you looking for? Looks? Off roading? Spacers are good for looks. Coils springs are better for street/off raod. Coil overs are best for off road, and good for street. WIth a 3" lift you may also want to consider some UCA's that correct for the loss of caster when lifting. :)
  4. Jun 19, 2008 at 5:45 PM
    Pat
    San Diego
    I want it to be more leveled and not having the front be pointing up. From the prices I have seen my budget I would say is around $1000 but it would depend on what would work best for me.
    I don't go off roading much at all. Just the dirt road with some small ruts in is about how far I go. I do more around town driving. Thanks for the help
  5. Jun 19, 2008 at 6:44 PM
    rick
    rick `
    check the link right above 05TacoTRD sig pic. good info there.
  6. Jun 19, 2008 at 6:51 PM
    Pat
    San Diego
    Are there any Coil Over Lift kits in particular that I should look into?
    Edit: From reading other threads on this forum it seems to me that the Toytec Coilover Kit seems to be the best. (Second item down on the page I think is the right one)
    If I were to purchase that and get a local shop to instal it, I would get the 3 inch lift and the truck would be level correct?
    And it has several options to pick from for the kit. Which one would be the best to choose? I don't really understand what they mean by some of that information. And would I need anything else on the truck besides that kit?
    Sorry for all the questions, but thanks for all of your help.
  7. Jun 19, 2008 at 8:02 PM
    Khaos
    Khaos Big Member
    Bryant
    Since you don't off road, a coil over set up would be extreme over kill.
    If all you want is level, get some Bilstien 5100s. They will lift the front of your truck up to 2.5" and only cost $269. They are also a huge improvement in ride.
    If you still want more height, then I would get a OME coil lift ($300) up front and Alcan leaf pack ($600) in the rear.
  8. Jun 19, 2008 at 8:09 PM
    Pat
    San Diego
    If I were to get the coilovers that I had the link to above, how much do you think it would be to get them installed? I know the price will vary heavily but if anyone has an approximate price it would be helpful.
  9. Jun 20, 2008 at 1:38 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    when I was searching to get my lift I found that the cost of instillation was the same as pruchasing the lift. Lift costed 460 bucks and the install was gonna be 400. I asked if they were crazy. I just couldn't see it taking that long to do or being that darn expensive. So I did it myself. I believe in your case you may be better off with the 5100's they will allow you to level your truck, it will be cheaper and you should get a nicer ride.
  10. Jun 20, 2008 at 1:52 PM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    I was looking for a lift not too long ago and I really didn't want to spend too much money. The folks here at TW were very helpful. I don't offroad much, but I wanted a lift for looks and bigger tires.
    I opted for the 3" ToyTec lift with black spacers and rear AALs. I also got the differential drop kit and rear shims. Total cost was $300. I was going to do the install myself, but didn't have the spring compression tools and I had a small garage...well, to be honest, I was just lazy.:rolleyes: Installation was $350 with alignment.
    I am very happy with the results. Ride is kind of like stock, but a little stiffer. I have an 08 TRD Sport Double Cab Shortbed 4x4. You can check out my pics in my gallery to get an idea of what the lift did.
  11. Jun 20, 2008 at 2:03 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    You can rent the spring compressors and autozone or O'riley's. Here you leave a 25 dollar deposit which you get back in full upon returning the compressors. Thats great, couldn't believe it was actually free.
  12. Jun 20, 2008 at 2:17 PM
    Banchi94
    Ron
    Parker, CO
    Dang it! Now I wished I wasn't so lazy. I could have used the $350 on a bull bar. Oh well...live and learn.
  13. Jun 20, 2008 at 2:47 PM
    Pat
    San Diego
    Banchi, you got the 3" Lift - Front Coil Spacers from Toytec right?
    Im almost leaning towards getting the spacers now and the AAL's in the back.
  14. Jun 20, 2008 at 2:52 PM
    Banchi94
    Ron
    Parker, CO
    Hey Pat,
    No, I actually have the black anodized spacers and AALs - yes, the 3" ToyTec. I would do the spacers and AALs as you described, just like I did. You'll be very happy with it, and you save some money, too.
    Good luck, and let's see some pics when you get it done!
  15. Jun 20, 2008 at 2:57 PM
    Pat
    San Diego
    You bought the spacers from Toytec right?
  16. Jun 20, 2008 at 3:14 PM
    Banchi94
    Ron
    Parker, CO
    Yup, just buy the kit that they offer. The actual 3" lift kit is part number TAC3-05-AL, front differential drop kit is TAC-DR-05, and rear shims TT-RS. Call ToyTec and ask for Kirk, if he is around - any of their techs are great and very helpful. Also, when you order the kit, make sure you ask for the black anodized spacers...they look a lot better than the silver IMHO.
    The actual 3" lift kit comes with the spacers, the AALs, and the hardware needed. I recommend also getting both the drop kit and the shims.
    I didn't have to pay for shipping since I live in Colorado and ToyTec is only about 20 minutes away.
  17. Jun 20, 2008 at 3:19 PM
    Pat
    San Diego
    I think that is exactly what I will do. Thank you all for your help. I know it will take a bit for me to get the parts and have them installed but when I do Ill post up some pictures. Thanks!
  18. Jun 20, 2008 at 3:20 PM
    Banchi94
    Ron
    Parker, CO
    Anytime! Good luck!
  19. Jun 20, 2008 at 3:45 PM
    Pat
    San Diego
    I just called TAG Motorsports which is a local truck shop that does lifts in the San Diego area and the tech told me that the AAL's wouldn't really be necessary for the lift. I thought that was interesting. He told me the truck would sit just about level also.
  20. Jun 20, 2008 at 4:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmmm......May need to take it to the dealer fot that! :D
