Advice on preventive maintenance regarding coolant leaks in engine (4cyl - high mileage)
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazytacoman, Jul 24, 2019.
  1. Jul 24, 2019 at 9:06 PM
    crazytacoman
    crazytacoman [OP] Well-Known Member
    Tacoman
    Taco World
    02 2.7 doublecab & 07 4.0 doublecab
    Color Wheels
    I saw a post earlier on here in which OP had the 1st gen 2.7L with about 250k miles and a coolant leak in the engine. It got me wondering about mines, and trying to find out the best ways to prevent such a thing from happening.
    I'm asking for anyone on here who is knowledgeable in such things to please let me know on what specific maintenance would best help prevent such a thing from happening to one of these engines. Thank you!
  2. Jul 25, 2019 at 9:35 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    TacoSchell and crazytacoman[OP] like this.
  3. Jul 25, 2019 at 10:03 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    That is for V6. 2.7 does not have it.
    The only thing really bad related to the coolant leak is head gasket. Keep coolant in good condition (flush the system as required and use Toyota red) and never let the engine overheat. The head gasket will go eventually anyway (mine was at 302k) and no maintenance will stop it.
    Water pump in 2.7 is very robust and you will only need to replace it when it goes (my at 320k miles is still as good as new). Same with thermostat. Basically the only preventive maintenance is flushing cooling system and using Toyota Red every 50-100k miles. And fix what is broken.
  4. Jul 25, 2019 at 10:06 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    I agree with above.
    cruxofthebisquit likes this.
  5. Jul 25, 2019 at 10:49 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
