Advice on Rear Tire Rub When Flexing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SlickFly, Dec 16, 2024.
  1. Dec 16, 2024 at 12:22 PM
    SlickFly
    SlickFly [OP] Member
    Brandon
    Cedarpines Park, CA
    2013 Tacoma TRD Sport
    Bilstein 6112/5160, Elevate Suspension Uniball UCA's, Method 701's, Falken Wildpeak AT4's 255/80/17
    Does anyone have any suggestions regarding better clearance of the rear tires when flexing hard?
    I've got a 2013 TRD Sport DCSB, Bilstein 6112/5160s, Elevate Uniball Tubular UCA's, Icon 3 Leaf AAL, Method 701's with 255/80/17 Wildpeak AT4's.
    I did some wheeling this past weekend, the most I've done since adding 33's.
    I noticed my rear tires are now rubbing inside the fender at near max articulation to the extent I think I'm losing traction.
    I'm hoping someone here may have some decent advice on what and where to cut and maybe some other options.
    Just did the CMC on the front end and it's riding great.
    Thanks in advance.
  2. Dec 16, 2024 at 12:51 PM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Curious how rubbing makes you lose traction?
  3. Dec 16, 2024 at 1:04 PM
    Clearwater Bill
    Billy
    Largo Florida
    This. ^
    And specifically where inside the fender?
  4. Dec 16, 2024 at 1:54 PM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    How high is your lift? How do you rub in the rear? I had same issue but was due to blown rear shocks.
  5. Dec 16, 2024 at 2:03 PM
    SlickFly
    Brandon
    Cedarpines Park, CA
    To be honest, it's probably just the joys of having open diffs. But there was at least the perception that I would tend to start getting wheel spin at the exact same time my other wheel felt firmly jammed into the wheel well.
    The spin may have still happened regardless but it definitely seemed to play a part. And even if I'm wrong and the effects are negligible, I would still prefer not to drag a tire if I can prevent it.
    SethM and YF_Ryan[QUOTED] like this.
  6. Dec 17, 2024 at 5:43 PM
    SlickFly
    Brandon
    Cedarpines Park, CA
    I want to say around 2.5 in the front and I think 1.5 in the rear. The 5160's are good. Suspension was installed in June and I haven't pushed my truck that hard in the time since.
    The rub is only when getting serious articulation in off camber situations. Until now I was mostly concerned with the front suspension. But I was pretty impressed that my IFS handled as well as it did even with the sway bar installed.
  7. Dec 18, 2024 at 8:06 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    4 options or any combination thereof:
    body lift
    Increase bump stop length
    New wheels with different backspacing
    Cut fender
    Strictlytoyz likes this.
