Advice on replacing lower control arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hornedfrog53, Feb 22, 2018.
  1. Feb 22, 2018 at 5:15 PM
    Hornedfrog53
    Hornedfrog53 [OP] Well-Known Member
    2020 TRD PRO
    Ive looked all over on here for write ups. I found one YouTube video. Anyways. I’m replacing my lower and upper control arms. Moog lowers and jba uppers. Uppers seem fairly simple. Any advice on the lowers?? I don’t have rust issues but got new bolts on stand by just Incase. Also bought new wheelers super bumps so that’s also one less thing to worry about. Thanks as always.
    JDawg562 likes this.
  2. Feb 22, 2018 at 5:20 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    There's probably the same amount of work (possibly less) in replacing the LCAs as it is to replace the UCAs. It should be pretty straight forward once you get in there. I've done it without removing the coilover, but what's another three bolts if it makes install easier for you? A floor jack will help you align everything once you start putting everything back together.
    Hornedfrog53[OP] and Drainbung like this.
  3. Feb 22, 2018 at 5:21 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Easier to do the LCA. Remove two cam bolts, remove two 19mm spindle bolts. Remove shock bolt and done
  4. Feb 22, 2018 at 5:28 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Make sure you mark your cam tabs with a good paint pen so you can get it as close to the same alignment until you get to a alignment shop
  5. Feb 22, 2018 at 7:55 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Hornedfrog53[OP] likes this.
  6. Feb 22, 2018 at 8:40 PM
    Pigpen
    Dan
    Northwest Montana
    I had to cut mine off. I threw them away.
  7. Feb 23, 2018 at 4:27 AM
    Hornedfrog53
    2020 TRD PRO
    Thank you for finding that video! That doesn’t seem to awful. I’ve had my alignment done like 5 times over the last 2 months so hopefully mine aren’t to bad.
    Drainbung[QUOTED] likes this.
